Notices
Nth Degree/AEV Dana 44 Slider Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Differential Guards Next Product
Rating:
Product Information
MSRP: $249.00
Average Price: $231.20
Manufacturer: Nth Degree/AEV
Recommended?
Yes: 5 / No: 0
These smooth differential skid plates not only keep you from getting hung up on your differential, but also protect the vulnerable U-joint and Yoke on TJs and the lower CV Joint on JKs. Each unit is specially designed to fit specific axles and take up virtually zero ground clearance. Slider is built primarily from 1/4″ steel and comes with a black power coat finish with all hardware. Simple hand tools required. Applications currently include all TJ and JK Dana 44 rear axles and TJ Dana 44 and 30 Front Axles. All models are suitable for mounting our Stinger for the ultimate in traction.
https://secure.aev-conversions.com/store/merchant.mvc?Screen=PROD&Product_Code=NTH242
None
05-Rubicon
05-Rubicon's Reviews
12-27-2011, 03:40 PM
Price: $249.00
Pros: heavy, not hard to install, black, will save your rear yoke on serious blows.
Cons: can be tricky, depending on your rear sway bar connection, or if you have a truss. WAAAAAY Pricey!!!!
Recommended? Yes
Comments: get it if you go on rocks, not slick rock, saved my yoke from destruction last trip. I hit a ledge so hard, I flew straight up 3 inches, no damage to the rear diff, yoke, just a whack on the slider, paid for itself, in one trip!!!!!!!!!!!!!!!!!!
Skorpio
Skorpio's Reviews
01-02-2011, 05:22 PM
Price: $150.00
Pros: heavy sucker. Rear diff slider does a great job in the rocks
Cons: heavy sucker. Front diff slider won't work with long arm suspension lift.
Recommended? Yes
Comments: Simple, effective, easy to install item for the rocky trail climber that you can install and forget. The only environment that would require Frequent cleanout might be deep mud where the mud buildup might insulate and cause an increase in temperature of the differential.
USMCEOD
USMCEOD's Reviews
01-24-2010, 10:15 PM
Price: $259.00
Pros: Indestructible
Cons: Heavy
Recommended? Yes
Comments: I've slid my differential sliders over lots of volcanic rock in southeast california. Havent yet seen bare metal behind any scratches. My entire undercarriage is armored by AEV/Nth Degree in conjuction with my Nth Degree 6" Long arm Lift. I like all of their products. Very stout construction.
RockyClymer
RedRock4Wheeler
RockyClymer's Reviews
06-17-2009, 11:44 AM
Price: $249.00
Pros: Built solid, easy to install
Cons: pricey
Recommended? Yes
Comments: See previous comments
jetter
jetter's Reviews
03-25-2009, 02:15 PM
Price: $249.00
Recommended? Yes
Comments: Very strong construction and easy to install. Came with good instructions. Nice protection for the yoke and u-joint as well.
ThreadForumRepliesLast Post
Nth Degree Mobillity Oil Pan Skid (4.0L) Skid Plates 31 09-16-2013 01:18 PM
Rear Differential Slider Skid Plates 4 12-08-2012 06:35 PM
Nth Degree/AEV DANA 35 Rear Differential Slider Differential Guards 1 03-18-2009 11:47 PM
Nth Degree/AEV DANA 30 Front Differential Slider Differential Guards 1 11-30-2008 02:26 PM
Nth Degree/AEV DANA 30 Rear Differential Slider Differential Guards 1 11-30-2008 02:25 PM
