Notices
Currie Enterprises ramped HD cover for Dana 44 front differential Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Differential Guards Next Product
Rating: None
Product Information
Average Price: $118.50
Manufacturer: Currie Enterprises
Recommended?
Yes: 2 / No: 0
front differentials take a lot of abuse in desert racing and rock crawling applications. Installation of the ramped heavy duty differential cover will prevent damage such as puncturing of the cover. It uses 1/8"-thick plate steel for the guard, and also acts as a rock ramp to help the front end glide over obstacles. Covers include gasket and fill plug.
http://www.currieenterprises.com/cestore/product.aspx?id=1274
None
LeeMasterGT
LeeMasterGT's Reviews
03-01-2015, 01:26 AM
Price: $115.00
Pros: Stock clearance Excellent protection
Cons: Fitment issues.
Recommended? Yes
Comments: I never have to worry about my track bar, tie rod, etc hitting my diff cover! It's got plenty of beef down on the lower half of the cover where I'll be able to drag it over rocks when needed. My only complaint is that the bolt holes didn't easily line up and it made it difficult to install (required two people to install a simple cover). My guess is this was due to the cover warping when it was welded. Now that it's on, it's fantastic and has held up well.
RubiOR
RubiOR's Reviews
10-15-2009, 10:13 AM
Price: $122.00
Pros: Beefy but not insane. Should clear the trackbar as good as the stock cover.
Cons: You need an extra-long hex socket (1/4") to get into some of the bottom bolts.
Recommended? Yes
Comments: Time to change the diff fluids & since I'll pull the cover I might as well upgrade. The cover is solid but not stupid-heavy like some. Comes with instructions (!), new bolts, an optional paper (?) gasket and RTV. With the armor only on the bottom half it should clear the trackbar (aftermarket or stock) as good as the stock cover. This is a big plus for my LCG plans. I have a LubeLocker gasket to go with it so that I can chuck the RTV. I'll report back later if I have any issues with leaking or interference with the stock Rubi locker's air tube.
ThreadForumRepliesLast Post
Currie Enterprises Currie Enterprises Rock Ribz Rocker Guards 3 07-02-2016 10:17 PM
Currie Enterprises RockJock 45 Wide V-Front Bumper for 97-06 Jeep Wrangler TJ & Wrangler T Bumpers 4 07-02-2016 10:14 PM
Rockcrusher Dana 30/35/44 Differential Cover Differential Guards 33 04-17-2011 06:20 PM
Currie Enterprises CE-9031F - Front YJ Spring Skid Plate Skid Plates 1 11-03-2008 02:55 PM
TKH Fab Dana 30 Differential Cover Differential Guards 3 09-18-2007 09:04 AM
