RockHard Ultimate Sport Cage Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Roll Cages Next Product
Rating:
Product Information
MSRP: $1,100.00
Average Price: $686.07
Manufacturer: RockHard
Recommended?
Yes: 30 / No: 3
This is the main Sports Cage which includes everything from the factory bar forward to the dash and it fits hard tops or soft tops. Dash brackets are mounted to the bolt below your dome light switch and the 2 bolts above the switch. All Sport Cages are complete bolt-in, you do not remove any of the factory sport cage to install our unit! This means no drilling, no welding. The Sports Cage fits Soft and Hardtops. All hardware is included and comes unpainted. Rear Bars, Angle Bars, 5pt Harness Bars, Frame tie-ins, and padding kits are also available.
None
Page 2 of 2 1 2
kolten493
kolten493's Reviews
01-25-2009, 11:19 PM
Price: $560.00
Recommended? Yes
Comments: super easy install, very stout and built well. havent used it yet but im sure it could take a flop no problem
CopperCJ7
CopperCJ7's Reviews
12-28-2008, 08:30 PM
Pros: They make bolt-on knuckles for any custom removable cage application
Cons: None
Recommended? Yes
Comments: I purchased four knuckles and their dashboard mounting plates for my removable front cage section. Much easier to make the section with Rockhard's DIY pieces. I like being able to remove my front section so that working behind the dash is easier. If I had to remove the entire cage each time, it would take at least three guys to to it. They assured me that they have tested the strength of these parts with roll-over testing.
snowcrash
snowcrash's Reviews
11-12-2008, 06:42 PM
Price: $800.00
Recommended? Yes
Comments: For a bolt in cage its great! Easy install and from what I have seen from the bolt on ones it looks to be the best out there. Not a weld on one so not as strong as those but looks like it will do its job.
bigtowdaddy
bigtowdaddy's Reviews
10-02-2008, 01:07 AM
Price: $1,100.00
Recommended? Yes
Comments: MUST HAVE!! this system is grate, my wift and i fill safer and the jeep fills stronger on the rocks.
WKENDWARIOR69
WKENDWARIOR69's Reviews
07-15-2008, 09:40 AM
Price: $850.00
Recommended? Yes
Comments: Well it takes some thought as to the steps you need to put it in. The hardest part was getting up the courage to cut the stock padding. out side of that I hope I really never have to test it.
NEVERSWEAT
Northman
NEVERSWEAT's Reviews
06-29-2008, 10:38 PM
Price: $575.00
Recommended? Yes
Comments: Painted Rubi white and it is pure sweetness.. I bought the wrap around diagonals.. becasue of speaker pods and the rear stabilizer making for all around solid platform.
rickw450
rickw450's Reviews
06-05-2008, 08:14 AM
Price: $475.00
Recommended? Yes
Comments: About two hours to install. came as bare metal so it needed to be finished prior to installation. Fit great and looks great. Also allows several radios to be mounted on the center posts betwee the windshield and the factory crossbar above the seats.
BrokerDon
BrokerDon's Reviews
05-04-2008, 06:17 PM
Price: $600.00
Recommended? Yes
Comments: Extremely well made, basically bolts right on, looks GREAT, LOTS of options (rear cross bar, speaker bars, dash bar, floor mounts, etc.)
SurfnSnow
SurfnSnow's Reviews
04-29-2008, 07:44 PM
Pros: Easy install, great customer support
Cons: price might frighten a few
Recommended? Yes
Comments: This install took me an afternoon and was pretty easy. I did a write up on it (with instructions) so if anyone needs that shoot me a pm. The cage did come with a tap and its a good idea to clean out the threads before you tighten everything down.
edmond
edmond's Reviews
04-23-2008, 03:28 AM
Pros: Great workmanship, everything fit well
Cons: none
Recommended? Yes
Comments: Really like the ease of install (a bit time consuming, but good instructions)
-=Gar=-
-=Gar=-'s Reviews
02-01-2008, 11:33 PM
Pros: Very well made and easy to install with a friend's help.
Cons: $1000.00 price tag (before powder coating!)
Recommended? Yes
Comments: Came very rough finished. Needed to take an angle grinder to it to get it ready for paint. Needed to have a muffler shop fill a hole in one of the welded seems (small job and they did it for free).
Installed in a 1999 Jeep Cherokee limited in a few hours with a friend's help. I was impressed with how well it fit (even with an overhead console). My sun visors still work, just needed a little modification to the wing tips (cut them off). Cost me $225 to have it powder coated. Over all I really like it. Have had many compliments, even from professional fabricator that do weld in only kits.
FireMedicZ
FireMedicZ's Reviews
12-11-2007, 09:40 AM
Price: $200.00
Pros: Bolt-on= easy install, Looks good when the tops off, better than stock
Cons: Its a bolt-on, needs the expensive frame tie-ins to even get remotely close to being as durable as a weld-in cage
Recommended? Yes
Comments: I got mine super cheap from a partout job. It came with the angle bars and the rear bar. Install was fairly simple, even without instructions (can't download them from RockHard's website either). Just make sure all the bars are in place before you start tightening things down. Work from the inside out. I emailed RockHard about a torque spec for the bolts and they said there wasn't one. I got this setup because it was super cheap and because I do medium wheeling and need that extra insurance in case i go over. If I wheeled KNOWING I would go over then I would have gotten a weld-in frame tied cage. I plan on adding the frame tie-ins on mine for peace of mind but hate paying more for those parts than I did for the whole cage.
This is just my 2 cents, Do a needs assessment before you buy a cage and see which one suits your needs, bolt-in or weld-in. If you choose bolt-in then RockHard is a good choice.......flamesuit on.
Page 2 of 2 1 2
ThreadForumRepliesLast Post
custom awesome sport style cage Roll Cages 11 12-23-2015 10:42 AM
OR Fab Sport Cage Roll Cages 20 02-10-2015 08:06 PM
RockHard Rear Bumper w/Swing Arm Bumpers 11 08-28-2013 09:59 AM
RockHard Rock Guards Rocker Guards 10 02-13-2013 08:35 PM
Rockhard Rear Bumper with Swing Arm Bumpers 4 09-20-2011 07:23 PM
