Notices
Truck and Winch - Tuff Stuff Spyder XRC Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Bumpers Next Product
Rating:
Product Information
MSRP: $179.00
Average Price: $214.67
Manufacturer: Truck and Winch
Recommended?
Yes: 3 / No: 0
Company Website: http://stores.ebay.com/TUFF-STUFF-WINCH-and-OFF-ROAD
SPYDER XRC JEEP WRANGLER FRONT WINCH BUMPER W/ D RINGS 97-06 JEEP TJ + UNLIMITED
The SPYDER "XRC Style" front winch bumper is designed specifically for your 1997-2006 Jeep Wrangler TJ. With its maximum ground clearance and timeless looks given by its high degree approach angles and raised corners, this bumper is sure to turn heads on or off the road.
With SPYDER'S integrated winch mount, designed to hold the most popular winches on the market (up to 12,750 lbs) and a stylish 1.75" stinger tube with light tabs to hold up to 9" lights, the SPYDER front bumper is sure to be a smart and affordable choice for any Jeep enthusiast. SPYDER'S "XRC Style" bumper also incorporates 2 useful D-ring / Bow Shackle mounts that have been robotic ally welded on the inside & out. SPYDER'S bumpers are protected using a durable 2 stage matte black crinkle powder coating so your bumper is sure to last for years to come.
Whether you own a winch or plan on installing one in the future, the SPYDER "XRC Style" bumpers heavy duty winch mount and higher ground clearance will instantly transform the look of your ride by taking your Jeep to the next level!
BUMPER SPECS:
Uses Standard 10" X 4.5" winch mounting pattern
10" centered Fairlead Mount
NO Welding or fabrication required for installation
2 Light Tabs
3/16" thick construction
Includes 2 Silver 4.75 ton D rings
FEATURES & BENEFITS
• Angled 1.75" Stinger light bar for maximum winch/Grille protection
• 2 tabs for Off-Road Lights (Up to 9" Diameter)
• Manufactured from 3/16" black textured powder coated cold rolled steel
• Raised bumper corners for better entry and exit with larger diameter tires
• Solid 3/16" center plate that wraps around the frame horns and lower cross member sections
• Built in winch plate to hold up to 12,750Lb winch with elongated bolt pattern to adjust winch placement
• All Welds have been robotic ally ground & Polished for a 1 piece appearance
• Two Stage Matte Black Crinkle Powder Coated Finish for long lasting rust free life
• Exclusive SPYDER 3 year Limited Warranty
• Provides maximum clearance for rock crawling
• D-Ring Mounts robotic ally welded from inside & out
• QTY. 2 - 4.75 ton D-Rings included
None
MavJeeper8
MavJeeper8's Reviews
10-24-2013, 12:47 PM
Price: $265.00
Pros: Very study and good looking bumper for the price. Pre-made with winch mounting plate and two light tabs.
Cons: Holes didn't quite line up on one side, had to widen to allow bolt to feed through. Not a big deal.
Recommended? Yes
Comments: Very nice addition to my yj for looks and functionality. It's very sturdy and pretty heavy. Has a black powder coat finish to really make it "jeep" looking. Only problem was the tabs to connect the bumper to the frame were slightly aligned wrong. Just had to drill to make it wider. Definitely a good purchase.
Seuf
Seuf's Reviews
06-07-2013, 03:27 PM
Price: $200.00
Pros: Thick and Easy to install
Cons: None Yet
Recommended? Yes
Comments: Highly recommended it's tough and has a built in wench plate.
4x4rox
4x4rox's Reviews
03-21-2012, 09:52 AM
Price: $179.00
Pros: Cheaper than Smittybuilt XRC. Easy to install. Looks Amazing!
Cons: None.
Recommended? Yes
Comments: Installation instructions were a little bare and lacking in description, but it the front bumper. You can't screw it up. Came with new hardware including bolts for a fairlead.
ThreadForumRepliesLast Post
Ruff Stuff Specialties Ruff Stuff Differential Cover Differential Guards 15 11-01-2013 08:32 PM
Poison Spyder - Bombshell Diff Cover Differential Guards 4 10-05-2012 06:53 AM
Poison Spyder Customs Tail Stinger Bumpers 1 05-03-2011 06:19 PM
Tuff Designs - Tuff Designs Tire Carrier Bumpers 4 08-24-2010 05:03 PM
Poison Spyder Customs Trail Corners Skid Plates 3 11-29-2009 03:30 PM
