Smittybilt Classic Rock Crawler Tire Carrier
Rating: |
Product Information
| MSRP: |
$375.00 |
| Average Price: |
$298.08 |
| Manufacturer: |
Smittybilt |
| Recommended? |
* 1987-06 Wrangler
* Heavy duty 1/4" steel plate design
* Three point mounting system supports over-sized tires
* Special lock design keeps tire carrier secure while off-roading
* E-coat undercoated with dual stage textured black
Therosa's Reviews
Price: $280.00 Pros: Solid construction, looks great, can mount bike carrier to tire and still get into back without having to unload everything, tow rated. Cons: Can be noisy, must remove gas tank to install properly. Recommended? Yes
Comments: After some extensive research I decided on this bumper/tire carrier beacause it is one of the few bumpers that is actually tow rated that would fit into my budget of a lot less than $1000. I can attach my bike carrier and open the back without unloading all the bikes. The construction is much stronger than the stock setup and I don't have to be afraid of the gate hinges getting messed up when I go to a larger tire size. Installation was a peice of cake after dropping the gas tank. It might be possible to install without dropping the gas tank but you would have to have some magical socket swivels to get the inner bolt of the drivers side installed. If you decide to install without dropping the tank I would recommend using a step bit to avoid drilling a hole in your tank.
nwco4x4's Reviews
Price: $339.00 Pros: Well priced holds a 35" tire Cons: Rattles fit and finish bad grease zirk for tire carrier hit tail gate hinge and broke right away Recommended? Yes
Comments: Overall not bad it gets more rattles the longer it's on and the grease zirk broke of the tire carrier hinge the first time I opened it
hotelconucc93's Reviews
Price: $299.99 Pros: Looks decent, good price Cons: has tow mount and chain mounts yet says not rated? Install is best suited no gas tank, no body on jeep Recommended? Yes
Comments: Install is a pain in the rear and their instructions DO NOT make sense for the hardware and physics of install. See my rebuild thread. Looks decent but not rated for towing. Does not come with adequate hardware for install. For the price however, you get what you pay for and this is a good looking cheap bumper.
yjjeepn92's Reviews
Price: $279.00 Pros: fairly easy installation Cons: drilling required, threads strip very easy. Recommended? Yes
Comments: Some drilling required but pretty straight forward install. can be done with 2 people in about a hour. materials could be better, but it is something you will have to keep tweaking until you get it as close to perfect as possible. wouldnt recomend for a 12.50 tire because im not sure it can handle the weight off road. However, my swingout seems to be holding my 33x12.50 ok, it leans due to a broken part beside the latch, but this can be fixed i believe
MountainGrizz's Reviews
Price: $225.00 Pros: cheap price, looks good Cons: Rattles, sags with a larger tire in time, back bolts impossible to intall with out droping the fuel tank, no add on accessories avalible. Recommended? No
Comments: I had it on my Jeep for one month before the Rattles started, tire rack starting to sags with a larger tire in time, back bolts impossible to intall with out droping the gas tank, no add on accessories avalible like Safari Rack, Gas Can Holder and HiLift Jack Mount. Price is the cheapest around so you get what you pay for, I wish I got another brand.
Bear215's Reviews
Price: $279.00 Pros: Holds up to a 35" spare Cons: Time consuming to install Recommended? Yes
Comments: Works well I have a 33" spare on a 15x10 wheel and it holds it great. The top tube rattles if it's not against the tire.
mario figueroa's Reviews
03-02-2009, 09:23 PM |
Price: $242.00 Recommended? Yes
Comments: Well built sturdy,and looking good however the intall hardware was not matching and had to soent a few bucks on new bolts.
whitie_08's Reviews
01-28-2009, 09:35 PM |
Price: $237.43 Recommended? Yes
Comments: great product for the price. it says it is not tow rated, but my jeep has been yanked out by it no problem. it looks good too. bought it on sale and picked it up at 4wheelparts, savved ~$150
Viperus's Reviews
01-06-2009, 01:49 AM |
Price: $350.00 Recommended? Yes
Comments: Quite a pain to install, the screwthread didnt hold on most of the screws, looks great thou.
hoghandler's Reviews
01-05-2009, 05:54 PM |
Price: $330.00 Recommended? Yes
Comments: love the way it looks, it just holds the spare really high and renders your rear view mirror useless
ckhanna71's Reviews
12-22-2008, 11:58 AM |
Price: $300.00 Recommended? Yes
Comments: Great foundation for a rebuild. I ripped it apart and modified and only reused the lower bumper and spindle.
BM20's Reviews
07-30-2008, 05:59 AM |
Price: $279.00 Recommended? Yes
Comments: I am sure its not the best out there but it works for me. Went together fairly easy. The rattle can be fixed by adjusting the existing rubber bumper out about a 1/4" to contact the swing arm.
CO98TJ's Reviews
07-03-2008, 10:26 AM |
Comments: I love it! Great Bumper,hitch receiver,and tire carrier in all! Black Powdercoating looks great and durable as well!
NYTJ's Reviews
06-08-2008, 03:58 AM |
Comments: Really easy to install, works great! Good value for the price. Small rattle but fixed it easily by shimming the bumpstop.
stevenmh's Reviews
06-04-2008, 02:45 PM |
Comments: came with the bumoer and tire carrier, yet again like the front fabtech its clean and sleek, not bulky and is powder coated. has 2 inch reciever
vtjeepthing's Reviews
04-14-2008, 09:54 PM |
Comments: Finally an affordable rear carrier.
kb9qdi's Reviews
04-13-2008, 09:01 PM |
Price: $375.00 Recommended? Yes
Comments: Mine's the tublar bumper but basicly the same. Great product for the $$.
Rocky5's Reviews
04-10-2008, 02:42 AM |
Comments: Again great product for the price. nice and simple not over engineered.
