Go Back JeepForum.com > Reviews > Armor > Bumpers > Rock Hard 4x4 Parts Rear Bumper Tire Carrier
SALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30 1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with FullIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Rock Hard 4x4 Parts Rear Bumper Tire Carrier Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Bumpers Next Product
Rating:
Product Information
MSRP: $995.00
Average Price: $742.63
Manufacturer: Rock Hard 4x4 Parts
Recommended?
Yes: 11 / No: 1
Rock Hard Jeep Rear Bumper/Tire-Carriers are made out of 3/16" x 2" x 4" thick tubing with ends that are boxed in. They have 2 sets of holes which mount to your Jeep frame in a standard position or can be raised 1" to increase departure angle and/or compensate for body lift. This bumper also comes with (2)-5/8" x 2-1/2" CNC D-Ring shackle mount with tabs that are welded on front, go through bumper and then welded on the backside too. A CB antenna mount and horizontal Hi-Lift Jack mount with padlock provision comes standard. The swing out tire carrier will hold up to a 38" tire. All needed hardware is furnished for installation.
ktroth
ktroth's Reviews
02-03-2012, 07:48 PM
Price: $800.00
Pros: 2" hitch, great construction
Cons: heavy
Recommended? Yes
Comments: good bumper overall. very stout. had one on my tj and first thing i installed on my jk
svjeep
Junior Member
svjeep's Reviews
06-25-2011, 09:27 PM
Price: $0.01
Pros: ?
Cons: hitch
Recommended? No
Comments: Receiver hitch depth not enough. Hits frame, had to cut down receiver hitch extension. Not sure if a locking pin will fit in there and I've already lost one pin with a retaining clip.
dcope17
dcope17's Reviews
08-06-2010, 02:00 PM
Price: $656.00
Pros: Precise instructions, Adjustable for no body lift or up 1" if you have a body lift. Everything bolted up perfectly. Well packaged, not a scratch on it.
Cons: Have to drill 4 holes ( which really makes the mounting stronger ) Not really a con...
Recommended? Yes
Comments: 4 wheel parts 10% off deal is where I bought it. Install was straight forward. You can adjust everything even if it did start rattling... you can shim all the rubber stops to fix it. Great product...
Poor Boy
All Around Nice Guy
Poor Boy's Reviews
04-19-2010, 10:05 AM
Price: $1,400.00
Pros: Solid, easy to install, has everything i need in a rear bumper
Cons: nothing for a scepter fuel can (more readily available around here), but so what?
Recommended? Yes
Comments: on my 2007. got it with the gerry can mounts and luggage rack. came with hi-lift, cb antenna, hitch and clevis mounts, fits up to a 38" tire (with accessory mounts). what more do you need in a rear bumper, really? I can't remember exactly, but i want to say i paid 1300-1400 shipped for bumper and all the goodies.
VanBCguy
VanBCguy's Reviews
04-01-2010, 02:32 PM
Price: $650.00
Pros: Best on the market
Cons: None
Recommended? Yes
Comments: This is the most solidly built rear swing away I've ever seen or owned. It has an excellent latching system, a great hinge, locking mechanism to prevent it from swinging back and "pinching" you between the heavy weight of the tire and carrier and the Jeep itself.
Read all the positive comments below my post. You'll get the idea.
I can't say enough good things about it. Just buy it!
sar50
Newbie
sar50's Reviews
12-14-2009, 06:30 PM
Price: $700.00
Pros: Solid Design, No rattles, multiple accessori options
Cons: not inexpensive
Recommended? Yes
Comments: strong design got the tie in brackets and rack. Works well.
limeking
limeking's Reviews
11-05-2009, 09:47 AM
Price: $750.00
Pros: Heavy duty
Cons: Instructions not so hot.
Recommended? Yes
Comments: The bumper has taken some rock hits and still looks good. I am not impressed with the latch but it has not released on it own either. I did not like the reusing the bumper on the tailgate. I also had the same problem with the 3rd brake light and had the same trip to wallys. I just by chance changed the wires and it work. I would like to see a better way to attach the 3rd breaklight wiring.
Danegerous
USAF Trained Killer
Danegerous's Reviews
10-05-2009, 02:21 PM
Price: $799.00
Pros: Totally amazing construction. Solid idea, super solid execution. Smooth operation and super sturdy.
Cons: None
Recommended? Yes
Comments: This thing is seriously awesome. Everything about it is super solid and everything I had hoped for.
Mystifire
Mystifire's Reviews
07-07-2009, 11:32 PM
Price: $689.00
Pros: Virtually indestructible with the frame tie-ins.
Cons: Lackluster directions. Frame tie in only came with bolts, no nuts. I had to reuse 4 from my old bumper and purchase two more.
Recommended? Yes
Comments: This bumper is fantastic.
Two tips:
1) If you have to drill the four inner holes on the back of the frame, line them up between the frame and the gas tank. I centered the holes in the middle of the slots and it was a PITA. If you have already done this and need help pulling the bolts through, I tied teflon tape to the end of the bolts and pulled them through.
2) If you purchased the optional 3rd brake light (may as well, its only $12.99 and it keeps you legal), don't assume that black wire connects to the black wire and the white wire goes to the white wire. That cost me a midnight trip to wally-world for 20A fuses.
crashdnt
crashdnt's Reviews
12-11-2008, 11:27 PM
Pros: Solid, Ease of installation and operation
Recommended? Yes
Comments: Outstanding quality. Easy operation. Recommend buying the extra frame supports.
ZektheJeep
ZektheJeep's Reviews
10-21-2008, 09:06 PM
Price: $995.00
Recommended? Yes
Comments: Tuff as nails, never rattles and never has done anything except do its job-hold my jack and my spare.
ApexWrangler
ApexWrangler's Reviews
09-30-2008, 04:20 PM
Price: $729.95
Recommended? Yes
Comments: Great solid bumper. Built-in receiver hitch is awesome. Latch is easy to open with one hand.
ThreadForumRepliesLast Post
Smittybilt Classic Rock Crawler Rear/Tire Carrier Bumper with D-rings by Smittybilt - Bumpers 23 12-26-2011 06:47 PM
Rock Hard 4x4 Parts Front Bumper w/ Angled Hoop 46" Bumpers 3 01-31-2010 09:49 AM
Nates 4X4 Rear Bumper / Tire Carrier Bumpers 3 02-26-2009 01:20 PM
Grant 4x4 Rear rock bumper with tire carrier and high lift jack mount Bumpers 1 07-05-2008 05:17 PM
Rock hard rear bumper with tire swing Bumpers 3 05-27-2008 05:37 AM
Glock Forum
