Notices
Pro Comp (Genuine Steel) Front Bumper w/ D-Rings, p# EXP66162 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Bumpers Next Product
Rating:
Product Information
MSRP: $159.00
Average Price: $116.36
Manufacturer: Pro Comp (Genuine Steel)
Recommended?
Yes: 21 / No: 1
Rock Crawler front bumper
* 1976-06 TJ Wrangler, Rubicon, and Unlimited
* Constructed with 1/4" plate steel
* Designed for high departure and approach angles
* 1 pair of D-rings incuded
* Gloss Black powdercoat finish
None
Page 1 of 2 1 2 > Last
HighRoller02TJ
HighRoller02TJ's Reviews
03-30-2013, 02:01 PM
Price: $150.00
Pros: d rings
Cons: had to drill big holes for the flat winch plate
Recommended? Yes
Comments: i like it, its a good bumper, i recommend it. so go out and buy one and you will be happy
dsiegel5151
dsiegel5151's Reviews
04-26-2012, 09:19 PM
Price: $185.00
Pros: Look okay
Cons: Don't fit as well as the Warns.
Recommended? No
Comments: I'd pay extra and get the Warns if I could go back in time. I don't like the fact that these bumpers only utilize the front bumper mount bolts on the frame. This makes anything else you need to mount on the bumper uneven, unless you jerry-rig a spacer in there or something. Pretty poor design.
MidTnSahara
MidTnSahara's Reviews
11-13-2011, 10:00 AM
Price: $25.67
Pros: Thick steel easy install
Cons: Only uses 2 bolts per side
Recommended? Yes
Comments: It's an ok bumper. Awesome for the price and will make a good base to build my bumper on
hefightsfire
hefightsfire's Reviews
04-23-2011, 10:55 PM
Price: $135.00
Pros: Looks great, decent fit, seems heavy duty, will update once I get to try it out.
Cons: None yet.
Recommended? Yes
Comments: Good looking cheap bumper. Seems heavy duty but I haven't gotten to try it out yet.
vbohannon64
vbohannon64's Reviews
03-06-2011, 09:13 AM
Price: $90.00
Pros: Cheap and lightwieght
Cons: Does not use both top holes to mount
Recommended? Yes
Comments: Powdercoating is great and the bumper looks good. It only uses the two lower and two top forward mounting holes. Seems pretty strong though. Good lightweight bumper if you don't want a heavy bumper up front.
dixiedooly
dixiedooly's Reviews
11-30-2010, 05:22 PM
Price: $250.00
Pros: Very Sturdy
Cons: none at the time
Recommended? Yes
Comments: I bought a used Pro Comp bumper. It is a bit dirty and needs some sanding and re painting, but it is very sturdy
Nberry90
Nberry90's Reviews
09-21-2010, 04:56 PM
Price: $149.99
Pros: looks great, strong 1/4" steel
Cons: None Yet
Recommended? Yes
Comments: if you want a beefy looking front bumper with D-Rings, then this is the one. i had chrome tube bumpers before and i didnt like that i had to take them off before offroading. with these, i can hit trees and roll over rocks without having to worry they will crumple like a piece of tin foil.
wakeTJ
wakeTJ's Reviews
02-26-2010, 10:34 PM
Price: $100.00
Pros: Good looking
Cons: Don't works with flat winch plate.
Recommended? Yes
Comments: I don't have the D-rings. Made of 3/16 steel. Strong enought for beginning.
Got it for 100$CAN
1980ranger
1980ranger's Reviews
02-23-2010, 12:24 PM
Price: $100.00
Pros: Well made and very strong.
Cons: Not available with any kind of light bar or stinger.
Recommended? Yes
Comments: The bumper is very well made and came with d-rings attached. Easy installation however top of bumper could be wider to cover both mounting holes of the factory toe hooks.
1980ranger
Price: $100.00
Recommended? Yes
Green_tj
Green_tj's Reviews
02-07-2010, 04:23 AM
Price: $112.00
Pros: easy insatll, looks great, good building base for a stinger
Cons: mine didn't have d-rings haha
Recommended? Yes
Comments: i bought mine cause it was a cheap bumper but i ended up using it as a building platform for a stinger and love it
famousstar1026
famousstar1026's Reviews
01-11-2010, 11:27 AM
Price: $90.00
Pros: very easy install 20 min
Cons: n/a
Recommended? Yes
Comments: easy install uses stock bolts make a good winch bumper
Dhofstet
Dhofstet's Reviews
05-16-2009, 02:53 AM
Price: $1.00
Pros: Seems to be a good solid bumper. Looks capable of taking a beating.
Cons: It is a little wider than i would want. I might trim it down a little.
Recommended? Yes
Comments: This bumper came on my YJ so i do not know the price. I just realized it was an after market bumper. It seems to be pretty solid. It is kinda long, it almost sticks out in front of the tires. Most people trim down the stock bumpers so they do not cover up the Tires.
rock-rocker
rock-rocker's Reviews
03-26-2009, 10:43 PM
Price: $130.00
Recommended? Yes
Comments: When installing did it along with a winch. Could have used an additional pair of hands.
taquito971
taquito971's Reviews
03-13-2009, 06:15 PM
Price: $100.00
Recommended? Yes
Comments: Simple and effective. And it looks way better than the chrome double tube that was on there!
mtr5360
mtr5360's Reviews
02-15-2009, 03:57 AM
Price: $159.00
Recommended? Yes
Comments: Easy fit, d-rings included. Not a bad product for the price. Would get a Rokmen or Redrock4x4 if I did it over again.
ScottHarr_TJ
ScottHarr_TJ's Reviews
10-30-2008, 09:46 AM
Price: $120.00
Recommended? Yes
Comments: So far its good. very strong and sturdy. good for the budget build im on. i look for cheap stuff, but i dont waste my money on something that wont last. hopefully these will last. ive heard all good things
RobsYJeep
RobsYJeep's Reviews
10-12-2008, 01:04 PM
Price: $150.00
Recommended? Yes
Comments: still waiting on delivery, UPS must hate me!! they seem to take forever to get to my place
1968olds98
1968olds98's Reviews
08-19-2008, 03:02 PM
Price: $50.00
Recommended? Yes
Comments: I got mine used for around $50, it was bent just a little bit (make sure you have all 4 bolts in and tight before you try to tow out with the d rings)
I was able to fix it with a little love from a BFH
distortedtj
distortedtj's Reviews
07-20-2008, 09:11 AM
Price: $120.00
Recommended? Yes
Comments: It's a nice thick and stout bumper. I do however do not like the disign of the d-ring tabs. They surfice welded them to the front of the bumper instead of weld through tabs.
ThreadForumRepliesLast Post
Smittybilt Classic Rock Crawler Rear/Tire Carrier Bumper with D-rings by Smittybilt - Bumpers 38 01-04-2016 11:53 AM
Warrior Front Bumper w/ Brush Guard & D-rings 56051 Bumpers 10 10-27-2015 08:32 PM
Smittybilt Classic Rockrawler front bumper w/D-rings Bumpers 19 03-03-2014 03:46 PM
Pro Comp (Genuine Steel) Crawler Rear Bumper Bumpers 17 04-27-2013 06:55 PM
LOD TJ/LJ 54" Front Bumper Bumpers 5 05-24-2012 07:37 AM
