Notices
Jeeperman Jeeperman Bumper (not swingaway) Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Bumpers Next Product
Rating:
Product Information
MSRP: $344.84
Average Price: $269.61
Manufacturer: Jeeperman
Recommended?
Yes: 3 / No: 0
(From Manufacturer Website)
Bumper features:
*3/16" thick and fully boxed unit with no open face back.
*CNC machined crossmember bracket for departure and hitch height adjustment.
*Standard modular frame mounts further strengthen the factory crossmember and included.
*Fully recessed 2" receiver with lock pin holes located behind the bumper.(Some hitches may need trimming and/or new hole for pin drilled.) Weakest point on this system has been tested and rated to 40,000 lbs. While we cannot rate your Jeep to pull that much,(2,000 lbs. for Wrangler and 3,500 lbs. for Unlimited) you can be assured that the bumper will far exceed the Jeep's capacity tow ratings.
*Laser cut dual (hidden on the backside) safety chain points (receiver and chain points can be reversed to outside for no extra charge as a custom option)
*Radiused 3/4" thick D Ring shackle mount tabs welded to the front, then through the depth of the bumper and then welded again to the backside. We intentionally leave them visible, so YOU know that it's triple welded for maximum strength
Cardinal Semi gloss black finish powdercoating. (All grade 8 bolts and new hardware that is required is included) Looks just like our swingaway bumpers, but do not include any hinge post, latch provisions or ability to add a Jeeperman Swingaway in the future.
None
Toine
Toine's Reviews
09-12-2011, 04:25 AM
Price: $339.00
Pros: Clean looks , 6 point bolted
Cons: Very Strong, also wenn hitting on rocks
Recommended? Yes
Comments: Almost ten Years on my Jeep now, still good looking - plain, simple
and strong
zapimpulse
zapimpulse's Reviews
04-29-2008, 08:30 PM
Price: $125.00
Recommended? Yes
Comments: I wish I bought the swingaway bumper as this cannot be added later without welding the swingout on. Good product altogether but somewhat unclear instructions. The powdercoating flakes off once chipped.
mpyusko
mpyusko's Reviews
07-31-2006, 10:51 PM
Price: $344.84
Pros: Promotes Body Lift and Departure Angle. STRONG!!!! Well made. STRONG!!! Flush 2" receiver.
Cons: Tight fit for receiver pin and Drawbar. Need to Cut/Drill Drawbar.
Recommended? Yes
Comments: Heavy! Strong! Well manufactured Bumper. I use it for towing and recovery. Worth every penny and then a few! Works Great! Had to modify my drawbar to accomidate the tight fit. I also has to cut my Lynch-Pin to fit. Bolt it on and it might as well be a new crossmember.
ThreadForumRepliesLast Post
Jeeperman JS Jeeperman TJ/YJ/CJ Swingaway Bumpers 13 02-10-2015 07:43 PM
Jeeperman Frame Mounted Sliders for TJ Rocker Guards 7 10-18-2012 12:12 PM
Jeeperman 54H Jeeperman Receiver Winch Bumper Bumpers 8 10-18-2011 09:12 PM
Raingler Jeeperman Rocker Skidz Rocker Guards 5 03-09-2008 07:38 PM
Jeeperman JBST TJ/LJ Jeeperman Rockers Skid Plates 1 11-07-2006 09:28 PM
