Go Back JeepForum.com > Reviews > Armor > Bumpers > A Incline Winch Bumper for WJ
Jeep JK Wrangler 3" Suspension Lift Kits $439.99 deliJeep XJ Cherokee Ulitmate Sliders now available!JcrOffroad: New XJ Rear Crusader Bumpers available!
A Incline Winch Bumper for WJ Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Bumpers Next Product
Rating: None
Product Information
MSRP: $1,300.00
Manufacturer: Lone Star Racing
Company Website: http://www.lsracing.com/view_gallery.php?gallery_id=9
FEATURES:
STRENGTH:
Built from a combination of 1/4" and 1/8" thick steel plate and TIG welded to protect you from the trail. You won't have to be afraid of touching the rocks any longer!
Heavy duty mounting brackets laser cut and TIG welded from 4130 chromoly steel plate to ensure the bumper remains in place no matter the level of abuse.
1" thick D-ring mounts for ultimate strength during recovery operations.
Winch is mounted to chassis using all 1/4" thick steel plate to provide secure and safe recovery operations.
Metric grade 12.9 fasteners used throughout.
PERFORMANCE:
Designed to be held as close to the chassis and body work as possible, but still provide ample protection from the trail.
Holds an 8000 lb winch in an unobtrusive manner and still greatly improves approach angle and tire clearance.
Design enables use as a glide plate to get you up over obstacles and support the weight of the front end should you happen to slide down on it.
Light mounting ports are designed to protect the lights from the trail and can be aimed straight or angled for desired light output.
The side plates can easily be trimmed to match fender trimming if needed to clear larger tires.
Lower tube section provides ample radiator protection without sacrificing air flow and supports the weight of the front end.
STYLE:
Finally you can have all the strength and performance you need, along with great looks for your Jeep WJ. The bumper lines follow body lines unobtrusively, and still provide the protection and ground clearance needed to keep you inclining and moving forward. Fully designed using 3D CAD software and manufactured with CNC Laser cutters to ensure optimum fit, finish and quality. All outer edges are sanded smooth for a clean look. It is 100% American Made in our facility in Mesa, Arizona.
DETAILS:
Compatible with most 8000 lb winches, including Warn M8000, XD9000, and Smittybuilt XRC8000 or any winch with 4.5" x 10" mounting and fits within a 24.25" x 6.5" footprint. Set up for Hawse type fairlead, 3/4" sized D-rings, and 5" Lights (ProComp 55).
Custom color powdercoating available at the factory for additional cost.
D-Rings, Hawse Fairlead, Winch and Lights not included.
None
ThreadForumRepliesLast Post
nates4x4 Winch bumper model 2 Bumpers 11 03-17-2013 06:59 PM
JCR Offroad Front Winch Bumper Bumpers 5 11-28-2012 01:42 PM
Nates 4x4 XJ Slimline Winch bumper Bumpers 4 03-26-2010 06:01 PM
Nates 4x4 Winch Bumper model 1 Bumpers 7 12-10-2009 07:56 PM
Nates4x4.com Nates's XJ winch bumper Bumpers 6 09-03-2009 05:16 AM
