Go Back JeepForum.com > Reviews > Armor > Bumpers > Ground Pounder Fab Frame Tie-in brackets
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Ground Pounder Fab Frame Tie-in brackets Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Bumpers Next Product
Rating:
Product Information
MSRP: $1.00
Average Price: $1.00
Manufacturer: Ground Pounder Fab
Recommended?
Yes: 5 / No: 0
Here is the TJ Frame Tie-in Kit you've been looking for. Made from 3/8" thick steel it is designed to bolt up in the rear corner of your TJ's frame to strengthen that rear crossmember when you bolt on an aftermarket bumper. Definately required if using the Jeep for towing. Also great for offroading when the rear bumper is used as a pulling point. Helps to make sure bumper stays where it belongs... on your Jeep! Some aftermarket kits just supply the brackets and a few nuts and bolts. They can be a bear to install as the upper hole in the frame is very hard to reach. I've made it easy for you by welding a flat strap onto a Grade 8 bolt so the bolt can be inserted up through the hole in the bottom of the frame. The same strap will then keep the bolt from spinning while you tighten downt the nut. Take a look at your TJ's frame and see if you'd rather struggle inserting a bolt thru the hole or if you'd rather do it with my kit. My kit comes with Grade 8 hardware to mount the bracket to the frame. You reuse your bumper's attaching hardware thru the crossmember. If you decide this is the TJ Frame Tie-in Kit for you, I accept Paypal, Money Orders, Cashier's Checks and even Personal Checks (must clear prior to shipping). As always, thank you for looking and good luck!!!! GROUNDPOUNDERFAB@VERIZON.NET
Coiz
Coiz's Reviews
11-18-2011, 12:03 AM
Price: $1.00
Pros: Rock solid tie-ins. Thick, reinforced with gussets and beautiful welds. Price included with my rear bumper.
Cons: None.
Recommended? Yes
Comments: I got two sets to attach my rear bumper with swing out tire carrier because I had also beefed up the rear crossmember by 3/8". I use a pair of these on the inside and outside of the frame rails. Eddie is super easy to work with and provides a great product!
bzoerb
bzoerb's Reviews
03-12-2010, 04:30 AM
Price: $1.00
Pros: heavy duty
Cons: none
Recommended? Yes
Comments: Eddie is a great guy to deal with and his products are top notch
Schwalby
Schwalby's Reviews
04-24-2008, 12:55 PM
Pros: very easy install
Cons: went so quick i didn't have time to finish my beer
Recommended? Yes
Comments: Very easy quick install. The metal tabs welded to the bolts make it so simple to place the bolts and tighten them down.
Fatman
Fatman's Reviews
03-29-2008, 07:31 PM
Price: $1.00
Recommended? Yes
Comments: Eddie's Bumpers ARE the best!
BoonDoggy
BoonDoggy's Reviews
01-04-2008, 09:01 PM
Pros: tough, they fit, genious straps welded to bolts
Cons: none
Recommended? Yes
Comments: Feel confident towing with these tie-ins that fit great. Easy to install. Most bumpers with hitches only attach to the weak stock cross-member. These beasts make your recovery bumper a part of your frame. And he only sells what he has in stock. Took 3 days to get mine.
ThreadForumRepliesLast Post
Ground Pounder Fab Rear Receiver Bumper w/ 1" Clevis Tabs Bumpers 7 01-13-2011 12:13 PM
Ground Pounder Fab Front Receiver Bumper w/ 1" Clevis Points Bumpers 5 03-25-2009 12:46 PM
Ground Pounder Fab 44" Stinger Bumper Bumpers 1 12-20-2008 05:32 PM
Ground Pounder Fab Roll cage Roll Cages 1 04-29-2008 11:18 AM
Ground Pounder Fab Front bumper with stinger and winch plate Bumpers 1 04-29-2008 08:24 AM
Glock Forum
