Custom Awesome Bumper
Rating: |
Product Information
| MSRP: |
$1,000.00 |
| Average Price: |
$686.15 |
| Manufacturer: |
Custom |
| Recommended? |
Coffeeman99's Reviews
Price: $100.00 Pros: Strong, (I think) stylish. Cons: heavy. Recommended? No
Comments: Custom bumper bought locally from a fellow enthusiast.
timmyjx209's Reviews
Price: $20.00 Pros: mows down anything in its the path and protects the body Cons: none Recommended? Yes
Comments: i took a section of 5 and 1/2 foot section of a semi frame rail drilled where the stock mounts and secured them with grade 8 bolts also welded a custom winch plate to the front and has held up well
mrJ's Reviews
Price: $450.00 Pros: Hardcore Cons: Kinda like a beak Recommended? Yes
Comments: local welder put it together. we'll see how it holds when i start winchin
Luke94XJ's Reviews
Price: $380.00 Pros: mounts a winch, its solid, I made it Cons: I had to make it, made the wife mad. took a while. Recommended? Yes
Comments: Fabbed it up using cardboard. Wasn't sure how the radius corners would turn out, but me and some friends made it all work. It uses 1/4" plate steel as the brackets. bolts through 7 holes on the passenger side and 7 on the drivers side. The winch mounting area is also 1/4" steel, as well as its angled supports, but the rest of the bumper is 3/16" steel, it has some sweet angles and nice radius corners. All coated in a smooth satin black finish.
The cost of taking the wife out every 3 nights really didn't make up for the money I saved building my own, but Its the way I want it to look.
SpikeTJ's Reviews
Price: $350.00 Pros: great protection Cons: ..... Recommended? Yes
Comments: its a 1/4 in think bumper that will stand up o anything and my winch mounts perfectly on to it
Fordman1014's Reviews
Price: $4.00 Pros: all custom built to my liking Cons: none Recommended? Yes
Comments: 4x6x 1/4'' tubing rear with spare tire swing gate rear. 1/8'' plate front. both painted black
3vze28's Reviews
Price: $300.00 Pros: Solid Steel Construction, Beefy, well built Cons: rusting internally, poor powder coat, old style mounts without supports Recommended? Yes
Comments: C4x4 rear xj bumper 97+
I will say that I am disappointed that this bumper is rusting internally quite bad, and im going to deal with that this summer, but even with that its pure beef. YOU DO NOT WANT TO BUMP THE BACK OF MY JEEP CAUSE THIS BUMPER IS NOT MOVING AND WILL DESTROY ANYTHING IT TOUCHES.
countrybuck's Reviews
Price: $100.00 Pros: Great deal Cons: None Recommended? Yes
Comments: Great rear bumper with tire carrier. I used 2x2 steel for the tire carrier portion and 2x4 for the base. Picked up a trailer spindle and bearings from Tractor Supply for the hinge and made a custom latch mechanisim. Hasn't failed yet. I currently have 35" on it with no noises at all.
Price: $100.00 Pros: Hit many deer with the front bumper and not even as much as a ding or dent Cons: Nothing Recommended? Yes
Comments: It is a custom job done by myself. Great for plowing deer over.
kittyhawk's Reviews
Price: $400.00 Pros: Built to last Cons: My buddy is not building them any more..... Recommended? Yes
Comments: Hell bent Front and rear bumpers.
cbossio's Reviews
Price: $300.00 Pros: Fort Knox > Sherman Tank > This bumper Cons: Heavy, dent in the front from a telephone pole pissing contest Recommended? Yes
Comments: Literally torn the front end of a stratus off. Sheared the everything in front of the radiator clean off with out a scratch. Sometimes use it to bulldoze small trees.
basivey's Reviews
Price: $31.00 Pros: great approach angle great strength looks awesome. Cons: ugly welds though they are strong but not pretty Recommended? Yes
Comments: I built this bumper from my own design... good luck with yours!
thedirtman's Reviews
Price: $100.00 Pros: one off custom built it myself Cons: weld burns on my legs for welding with shorts on Recommended? Yes
Comments: took about a week to build after work. I love to fab items did both bumpers and the rock rails. All are coated with rustolum spray on bed liner.
jeepjoe4's Reviews
Price: $25,000.00 Pros: strong protects the grill and short so as not to get hung up on rocks Cons: no protection for the frame rails Recommended? Yes
Comments: custom front bumper so it was mad just how i wanted it. it sits flush with the frame rails and is about 2 to 3 inches shorter so as not so snag on obstacles
ExodusX7X's Reviews
Price: $57.00 Pros: looks kick ass and works great Cons: weighs 8 tons Recommended? Yes
Comments: friend and I saw a picture of a similar bumper online for 600+ we built it for under 100 and had it powder coated for $45.... home grown ftw
srhcherokee24's Reviews
Price: $1.00 Pros: keep the front end of my xj saft from damage Cons: going to be a pain to put a winch on Recommended? Yes
Comments: i have a custom from bumper with a stinger. the base of the bumper is a air tank best thing i have installed on my xj
Green_tj's Reviews
Price: $172.00 Pros: I can take pride in my own work Cons: wish i had a tube shark Recommended? Yes
Comments: Its a bad a$$ stinger on a procomp classic crawler bumper
jis4jeep's Reviews
Price: $99.00 Pros: Its mine and I love it Cons: NA Recommended? Yes
Comments: Took a 99$ Smitybilt simple bumper. Removed 2 inches from the ends and re-welded the end caps. Made a grill hoop then a front stinger with kicker.
KFXHELLRAISER's Reviews
Price: $0.01 Pros: I made it! Cons: Still not the bumper I want! Recommended? Yes
Comments: I just shortening the bumper down and made some ends caps. Looks better with my cut fenders!
Toliver09's Reviews
Price: $0.01 Pros: more than enough front protection Cons: blocks a little bit of the headlights Recommended? Yes
Comments: the bumper i made for my ZJ has 2x4 1/4" steel beams for mounts and mount very similarly to factory tow hooks. and the bumper was custom made for a 74 bronco and was perfect width for the zj, but a little too short. I can hit a deer at 60mph and be fine though, so thats a plus
