Notices
Body Armor 59" Rear Bumper w/ Swing Away Tire Carrier Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Bumpers Next Product
Rating:
Product Information
MSRP: $1,500.00
Average Price: $788.40
Manufacturer: Body Armor
Recommended?
Yes: 31 / No: 2
This no drill bolt on application installs easily with simple hand tools. Standard features include welded shackle mounts with included 5/8" D-rings and a 2" receiver. Bumper sections are made from 2" x 5" 3/16" thick rectangular tubing. Features a black powder coat finish for maximum protection against rust.
None
Page 2 of 2 1 2
bushwacked
bushwacked's Reviews
02-23-2009, 09:02 PM
Price: $600.00
Recommended? Yes
Comments: i was told i whould pay someone to install this for me but it took me only 2 hours with a little help from a floor jack A++ preoduct
YukonJack1
YukonJack1's Reviews
02-15-2009, 07:07 PM
Price: $800.00
Recommended? Yes
Comments: This has been a super rear bumper. I have two new style Jerry's that required a fabbed addition to support the bottom, and the design is very clean.
scubamc
scubamc's Reviews
10-13-2008, 10:58 PM
Recommended? Yes
Comments: Well made bumper. bumper holes did not line up with factory holes. Took a little work, but they fit and look great.
pcjeeper
pcjeeper's Reviews
09-30-2008, 07:14 PM
Price: $1,500.00
Recommended? Yes
Comments: Another Solid Bumper the Tire swing gate works smooth and will hold up to a 44" tire plus hi-lift and 2 jery cans
pryde551
pryde551's Reviews
07-24-2008, 01:37 AM
Price: $1,000.00
Recommended? Yes
Comments: I actually have the front and rear 54" bumbers. The rear is the swing away, and the front has the double hoop. I have smacked them hard a few times, and the paint hasn't even chipped. A little heavy though. I lost almost 1/2" of clearance all the way around. Excellent protection!!
Parker1599
Parker1599's Reviews
03-29-2008, 12:35 PM
Price: $999.99
Recommended? Yes
Comments: 54" accually. make sure you grease the hell out of the pin!
FmrVette
FmrVette's Reviews
03-09-2008, 09:41 PM
Price: $1,000.00
Recommended? Yes
Comments: Works well. One person install. After 2 Detroit winters the swivel pin worked it's way out of the hinge; had to lubricate.
default_user
It's a Roobicon
default_user's Reviews
02-23-2008, 02:14 PM
Price: $1,000.00
Recommended? Yes
Comments: Actually I have the 54" bumper/tire carrier. I wanted the capability to carry two jerry cans and hi-lift. Very solid construction and easy to install (a second set of hands is a big help). Rattle free, but I had a high pitched squeak that was driving me nuts for a few weeks. Turns out the bolts on my hard top rear window needed tightening and that took care of the squeak. Rear latch and jerry can latches require adjustment with install, but are worry-free afterward. Frame tie-ins are solid and easy to install.
tj kevin
tj kevin's Reviews
01-16-2008, 07:43 PM
Pros: look great holds s gas cans,jack,cb ant.
Cons: needs grease fitting!! very heavy
Recommended? Yes
Comments: I've had this bumper on my 2006 for almost 2 yrs. it gets hard to open after a while.needs a grease fitting.
Kulae
Kulae's Reviews
12-19-2007, 11:12 PM
Price: $998.00
Pros: Looks good, hi-lift mount, gerry can mount and cb mount
Cons: Newer Jeeps require a little wedge to straighten it out and lock nuts hard to install.
Recommended? Yes
Comments: It's a little expensive but when you throw in the free rocker guards, it makes it affordable. Like my cons say, the newer Jeeps require a 1/8" wedge to make the hinge line up with the back of the tailgate. It tells you this in the instructions but you have to order the wedge. Just get a 1/8" washer that you have laying around the house and put it in. Easy to install, even by yourself. I like it!
case'sjeep
case'sjeep's Reviews
05-28-2007, 10:19 PM
Pros: carries big tire, gas cans, jack...
Cons: the installation holes didn't match up with the frame.
Recommended? Yes
Comments: Over all it has been a good bumper. But it took like 4-5 hours to get it on. i had to drill out the holes so the bolts would fit. It sucked!! But when it was all finished it looked sick.
It worked fine for about 2 months, then one day after wheelen' the tire carrier part was hanging off at a 70degrees. The pin that you screw into the hinge pin to keep it together sheared off. The hinge pin was half way out of its slot. So I just welded it together so I donít have to worry about it anymore. I also painted the bumper with a roll on bed liner. it worked out great.
Ichabod1960
Have Jeep, Will Travel
Ichabod1960's Reviews
01-07-2007, 06:16 PM
Price: $1,000.00
Pros: Heavy duty construction, built in jerry can holders, can be locked
Cons: a little expensive, rattles from the tire carrier, needs a grease fitting for the hinge, bigger shackles
Recommended? Yes
Comments: I am very happy with this bumper. I've had it installed since last July and aside from some minor issues this is a great bumper.
The installation was straight-forward. The kit comes with some reinforcing brackets that provide an additional supporting connection between the bumper and the frame.
Now for the minor issues; I'd like to see bigger shackles supplied with the bumper. Body Armor supplies 5/8" shackles but I think 3/4" shackles would be more appropriate. The tire carrier rattle was easily fixed by putting in a pinch bolt. The hinge needs some way to grease it. WD-40 works but some kind of grease fitting would be a better solution.
Page 2 of 2 1 2
ThreadForumRepliesLast Post
Fab Fours Rear Swing-Out Tire Carrier Bumper Bumpers 2 03-05-2015 11:27 AM
Rock hard rear bumper with tire swing Bumpers 7 02-04-2015 10:48 AM
Grant 4x4 Rear Bumper w/ Tire Swing-out and Trail Basket Bumpers 8 05-26-2010 08:31 PM
Nates Rear Bumper / Tire Carrier Bumpers 3 02-26-2009 12:20 PM
SMF SMF Rear bumper w/ swing-away tire carrier - Canadian Bumpers 1 04-29-2007 07:38 AM
