Bestop HighRock 4X4™ Front Jeep Bumper for Wrangler & Wrangler Unlimited, 97-0 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Bumpers Next Product
Rating:
Product Information
MSRP: $699.00
Average Price: $441.90
Manufacturer: Bestop
Recommended?
Yes: 35 / No: 1
Developed specifically for the hard core rock crawler, the HighRock 4X4™ Front and Rear Jeep Bumper feature high-access design for greater off road clearance.
Optional tubular Grill Guard for front bumper protects grill and headlights and is available in textured black or stainless steel.
Sturdy winch plate on front bumper accommodates most standard-sized winches.
Front and rear bumpers Offer attachment points for D-Ring and other recovery equipment.
No-drill installation.
Optional Approach Roller mounts to front bumper while optional Departure Roller mounts to rear bumper to get over the toughest obstacles.
Rear bumper includes a Class 2.5 receiver hitch that accepts many popular 2" hitch accessories. (Warning: Do not exceed vehicle manufacturer's recommended towing capacity.)
Optional HighRock 4X4™ SlideAway™ (97-06 vehicles) offers dual purpose storage and step unit.
None
Page 2 of 2 1 2
xantasm
xantasm's Reviews
06-07-2009, 05:40 AM
Price: $660.00
Pros: Its a very rugged bumper and mounts very well to the frame. It provides a very good surface for winch mount, and the approach roller is fairly stout.
Cons: The winch must be mounted to the bumper before the bumper is mounted on the vehicle making this a very heavy bumper to install. The tubular grille gaurd sits a bit low making any mounting of fog lights without accesory brackets very difficult.
Recommended? Yes
Comments: This bumper is made from heavy steel plating and the welds are very solid. The paint is scratch resistant if there is such a thing. The mounting brackets for the approach roller include slots for clevis pins at the top which is a plus and the brackets are thick and run from the bottom of the bumper to the top for added strength. The approach roller is a heavy grade steel cylinder with a milled center roller shaft. The bolt kit provided with the approach roller is inadequate in that it did not come with spacers to act as retainers for the center roller shaft. The winch plate and fairlead bracket is good quality but again could have added ligh brackets to make it a better setup. This bumper although fairly heavy was easy to install.
Ben_88Jeep
Ben_88Jeep's Reviews
03-30-2009, 11:07 PM
Price: $699.00
Recommended? Yes
Comments: Great looking front bumper. The hoop is bolted on to the main bumper... might not be a bad idea to weld it in place for strength.
R1Blueboy
R1Blueboy's Reviews
03-29-2009, 09:35 PM
Price: $500.00
Recommended? Yes
Comments: Very cool looking!! Not to impressed with the bolt on grill guard tube..It is stainless steel..Def helps with ground clearance..Need winch!!
xenocryst
xenocryst's Reviews
03-25-2009, 09:58 PM
Pros: Looks great! Heavy duty.
Cons: Poor fit. Expensive
Recommended? No
Comments: It's sooo close to being great! I really can't recommend it though until they align the bottom holes. Like some other people above, mine had that same issue.
Alexia
Alexia's Reviews
03-08-2009, 01:32 AM
Price: $250.00
Recommended? Yes
Comments: Solid bumper with options, easy to install. Could not install lower mounting bolts since they were drilled too far back in the bumper for my LJ's stock positions even though it is listed as compatible.
jmathis2
jmathis2's Reviews
03-03-2009, 09:25 PM
Price: $400.00
Recommended? Yes
Comments: dont know why it says 97 and up i got it with the roller fairlead even though havent used that looks awesome really beefy
Bill C
Bill C's Reviews
01-18-2009, 06:19 PM
Recommended? Yes
Comments: looks great. practical design. great recovery points. easy fit and install.
Viperus
Viperus's Reviews
01-06-2009, 02:45 AM
Price: $468.00
Recommended? Yes
Comments: Loogs great, very easy to install and its great for pulling cars out of trenches
01TJCRAWLER
01TJCRAWLER's Reviews
11-08-2008, 09:20 AM
Price: $600.00
Recommended? Yes
Comments: high rock front and rear bumpers with approach rollers.
i really like this setup. approach your rock face and let the roller guide you up without the ill metal to rock grinding, it also protects the steering box b/c the drovers roller point comes down just below it.
the rear roller will keep you off the gas tank skid.
the only down side is that if you were looking for the outmost approach and departure angles the rollers kinda hender this. but then again that's what they are for.
RubiRebel
RubiRebel's Reviews
09-03-2008, 08:18 PM
Price: $420.00
Recommended? Yes
Comments: Roller sticks if you don't lube it, but you could drive through a brick wall with this bumper. Steering box skid won't fit with this, but the roller mount protects the steering box.
Existence
Existence's Reviews
07-03-2008, 03:47 PM
Recommended? Yes
Comments: Great bumper, extremely strong. The only thing missing place for the oe fog lights.
KingOfStLouis
KingOfStLouis's Reviews
06-04-2008, 02:04 PM
Recommended? Yes
Comments: Very heavy duty, looks awesome on my '02 wrangler X, the optional light bar raises the aux lights which REALLY improves visibility. It is a bit expensive, but gven the quality it's still a great buy. No regrets whatsoever.
washone
washone's Reviews
05-21-2008, 08:03 PM
Price: $650.00
Recommended? Yes
Comments: .................................................. .................................................. ...........................
Stik
Stik's Reviews
05-12-2008, 09:07 AM
Price: $500.00
Recommended? Yes
Comments: The light bar may interfere with some winches, but it looks really nice. Its a solid bumper.
banks741938
banks741938's Reviews
05-12-2008, 08:51 AM
Price: $200.00
Recommended? Yes
Comments: great bumper with a great look. has the square look which is awesome. with the add on bar it makes for one killer looking bumper. really heavy duty. fit was a little off though. needed to grind a tad off the mounts 7 just becasue of the fit would be a nine otherwise
Page 2 of 2 1 2
ThreadForumRepliesLast Post
Currie Enterprises RockJock 45 Wide V-Front Bumper for 97-06 Jeep Wrangler TJ & Wrangler T Bumpers 4 07-02-2016 10:14 PM
Bestop HighRock 4x4 Rear Bumper 1986-2006 Bumpers 30 09-18-2014 06:58 PM
Xtreme Xtreme Front Bumper End Caps for 97-06 Wrangler TJ & Unlimited Bumpers 5 05-07-2014 08:51 PM
A to Z Fabrication Jeep TJ/YJ Wrangler Bumper and Tire Carrier Combo Bumpers 7 08-01-2013 09:17 AM
LoD Offroad LoD Jeep TJ/YJ Wrangler Xpedition Rear Bumper Tire Carrier Bumpers 1 04-24-2009 06:46 PM
