Notices
Barnes 4wd - Barnes 4wd Stubby Front Bumper Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Bumpers Next Product
Rating:
Product Information
MSRP: $170.00
Average Price: $180.00
Manufacturer: Barnes 4wd
Recommended?
Yes: 3 / No: 0
Company Website: http://www.barnes4wd.com
Description
The Barnes 4WD YJ Front Bumper is laser cut from 3/16" and is formed on a CNC Press Brake. This is a high clearance bumper that offers the protection that you need without getting in the way on the trail. Our bumper uses six factory mounting holes to attach the bumper to the frame. This design keeps the winch close to the grill for improved protection and low to maximize air flow. D-ring mounts are 3/4" thick welded inside and out and accept a 7/8" D-ring
None
The_Goob
Hell on Wheels
The_Goob's Reviews
11-07-2014, 10:07 PM
Price: $200.00
Pros: Shipped same day, very stout. looks great
Cons: Comes with shims for top of frame gap, wish they were just welded on there. made it a paint to install without peeling the fresh paint off
Recommended? Yes
Comments: Pretty much summed it up in the pro/con. I needed to get rid of a huge cow catcher bumper and this fit the bill nicely. Good approach angle and clearances. nice and beefy. The D-ring tabs were only welded on the outside so I welded them on the inside as well where they come thru the bumper.
bgredjeep
bgredjeep's Reviews
04-29-2014, 05:47 PM
Price: $170.00
Pros: .
Cons: .
Recommended? Yes
Comments: Just a follow-up to my original review. The bumper is still working great but I did bend the fairlead mount I bought with the bumper pretty good this weekend. As seen in my original review post it mounts flush with the front of the bumper so the fairlead sticks out a good bit. After I got home I pulled the bumper, straightened the fairlead mount, then drilled new holes in the mount to move it back 3/4". I also added gussets on each side to reinforce the mount, then put it back together. A roller fairlead would still stick out with my mods, but my aluminum fairlead is now flush with the bumper so it is less likely to get hit, and with the gussets it is less likely to bend even if it does get hit.
bgredjeep
bgredjeep's Reviews
12-06-2013, 06:00 PM
Price: $170.00
Pros: Looks great, excellent clearance, integrated winch mount, recovery points.
Cons: none
Recommended? Yes
Comments: I'm just copying my review I posted on the manuf's site. Wanted to share it here as well.
I picked up this bumper a couple months ago for my YJ. I was replacing a bumper that had a receiver hitch which was hurting my approach angle. This bumper has no such issues. I shaved a few pounds as well since I didn't have to run a bumper and a winch plate. Install was simple and all the holes lined up perfectly. I did make a small spacer to sit on top of the frame rail (3/16" thick) to tighten up the fit around the frame. On the trail I hardly even touched the bumper on anything which was a nice change from my old setup. The winch mount worked fine through multiple pulls, and I used the D-ring mounts a few times as well. I've got no complaints at all with this product.
