ARB Bullbar Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Bumpers Next Product
ARB Bullbar
Rating:
Product Information
MSRP: $1,200.00
Average Price: $660.14
Manufacturer: ARB
Recommended?
Yes: 80 / No: 1
The ARB bullbar is an excellent product. It is well constructed and affords a very high degree of protection. (See pictures in my gallery of an ARB on my XJ that got totaled) The product is very easy to install, can be done by one person but two would be better, and comes with all hardware required. Install time is about 2-3 hours.
I originally purchased the one on my XJ to protect me from Deer, but after seeing how good it stood up in the accident, I ordered the one for my WJ even before I picked up the Jeep.
None
Page 3 of 5 1 2 3 4 5 > Last
NickJr44
NickJr44's Reviews
09-15-2009, 08:08 PM
Price: $800.00
Pros: It's big, strong, takes abuse, conceals my 10,000 lb. winch, has two offroad 100 watt lights on it, and has my CB antenna on it
Cons: A little tricky to install. But with the right tools, know how, and will, anything is possible.
Recommended? Yes
Comments: This bull bar comes in black. Looks just fine, but if you want it sprayed you can also have it done to match your vehicle. This is frame mounted; not just some tow hook mounted POS brush gaurd. I have had a few friends sit and stand on it... doesn't budge. It is meant to be used with a Warn winch rated at 9,000 lbs. or so. But I custom rigged it to work with a (cheaper) Gorilla 10,000 lb. winch. This combo works excellently. Has an access bay on top of bumper to get inside bumper (where winch would go). It has two recovery points on the bottom, underneath the bumper. Very strong, looks great, gets traffic to move out of your way! One last thing... it's easier to spot a fellow Jeeper from a distance.
soulfinger
soulfinger's Reviews
09-12-2009, 09:55 PM
Price: $800.00
Pros: strong, ability to mount lights, winch, tow points and antenna
Cons: none
Recommended? Yes
Comments: It's great. Buy one.
PackDude
PackDude's Reviews
08-13-2009, 08:52 PM
Price: $1,000.00
Pros: Very well made Easy to install
Cons: Cross bar blocks stock turn signals somewhat
Recommended? Yes
Comments: This bumper is outstanding, that's all I can say.
The installation kit it comes with made it very easy to install on my 1998 XJ. I only had to drill two 1/2" holes in the "frame" bars, otherwise it uses existing holes perfectly.
I even was able to use the ARB as an anchor for the tow strap when pulling my brother out of a jam when his Ford Exploder got stuck out in the boonies.
Because the stock turn signal lights are mostly blocked by the tubular cross bars, the bumper comes with two amber lights that you can patch into your turn signal wires.
I am not worried about running into deer anymore.
Strebs
Strebs's Reviews
06-13-2009, 12:02 AM
Price: $200.00
Pros: Perfect fit on the TJ, well made, and looks great.
Cons: The turn signals included fill with water & muck easily. I'll find some replacements.
Recommended? Yes
Comments: I got this used for a great price. It had quite a bit of surface rust when I got it. I'm not sure if this is due to cheap original paint, a result of salty roads and not enough washing, or just plain neglect. Anyway, it cleaned up nicely and is a perfect fit. Looks fantastic and no winch plate is needed with this bumper.
xjpeople
xjpeople's Reviews
05-31-2009, 07:40 PM
Price: $800.00
Pros: vary strong
Cons: price
Recommended? Yes
Comments: vary nice but a little expensive
Firedog13
Firedog13's Reviews
04-05-2009, 04:12 PM
ARB Bullbar
Recommended? Yes
Comments: Good bumper. Houses the winch and looks great too. Also have 4 auxiliary lights on mine. Quality product. Only thing I don't like is that the mounts for the D-shackles are too thin. I had to put washers as spacers between the shackles and mounting point to keep them from flopping around.
jazzman31
jazzman31's Reviews
04-01-2009, 10:39 AM
ARB Bullbar
Price: $600.00
Recommended? Yes
Comments: Where can one get a bumper, guard, and a kangaroo/deer protection in one place. Awesome
meek61480
meek61480's Reviews
03-18-2009, 11:19 PM
ARB Bullbar
Price: $400.00
Recommended? Yes
Comments: one brute of a bumper. nice agressive look. downside is it is very heavy. does not mount up kc lights very well. had to drill new hole to fit them.
Heartless
Heartless's Reviews
03-16-2009, 12:22 PM
ARB Bullbar
Price: $850.00
Recommended? Yes
Comments: Finally got the Bull Bar. I Used the 84-96 Bull Bar on my 99' Cherokee. Aparently the 84-96 has more clearance and works better in conjunction with Bushwacker Cut-outs.
BLKRUBICON
BLKRUBICON's Reviews
03-01-2009, 12:04 AM
ARB Bullbar
Price: $989.00
Recommended? Yes
Comments: WENT W/ THIS BUMPER CAUSE IT LOOKED LIKE THE AEV BUT WAS ABLE TO SAVE ALMOST $500.00 GLAD I DID BRCAUSE W/ BEING ABLE TO THROW THE STOCK FOGS IN IT A MOUNT MY PLATE OVER THE WINCH MOUNT THE BUMPER MAKES MY JK LOOK BAD ***!!!
ToughWJ
ToughWJ's Reviews
02-05-2009, 11:24 AM
ARB Bullbar
Price: $1,000.00
Recommended? Yes
Comments: I would never get anything different! its perfect in every way. I have never had any problems with it.
jjmiller81
jjmiller81's Reviews
01-21-2009, 04:39 PM
ARB Bullbar
Price: $700.00
Recommended? Yes
Comments: TOP NOTCH. haven't found a complaint yet. Looks great, performs great. I pressed it to a tree to pull someone out, didn't even budge vehicle, distributed weight evenly. very tough
Travis873o
Travis873o's Reviews
01-16-2009, 04:21 PM
ARB Bullbar
Price: $550.00
Recommended? Yes
Comments: great. flat black w/ hella fog lights. Gives me more room for larger tires. Bolt on.
davidmech21
davidmech21's Reviews
12-16-2008, 04:07 PM
ARB Bullbar
Price: $900.00
Recommended? Yes
Comments: Took the deluxe bullbar and removed the turn signals and had it line-x'd. Looks awesome now!
RingRingRing
RingRingRing's Reviews
12-11-2008, 01:44 AM
ARB Bullbar
Price: $400.00
Recommended? Yes
Comments: Love this bull bar, waited 6 months to find it used for cheap on Craigslist... It came PC Black, but I sprayed it White.
warlizard
warlizard's Reviews
12-05-2008, 08:36 AM
ARB Bullbar
Price: $740.00
Recommended? Yes
Comments: Great design! It has saved me from having to do alot body repair while off roading.
b1pig
b1pig's Reviews
11-27-2008, 04:44 PM
ARB Bullbar
Price: $500.00
Recommended? Yes
Comments: one of the best aftermarket bumpers around. i have hit rocks and old junk cars with this thing and it holds straight. mounting for a Warn M8000 is excellent.
91Woody
91Woody's Reviews
11-26-2008, 12:23 AM
ARB Bullbar
Price: $250.00
Recommended? Yes
Comments: I have no complaints- although I haven't needed a pull yet though. I picked it up used so I couldn't go wrong.
Kegan
Kegan's Reviews
11-07-2008, 09:56 PM
ARB Bullbar
Price: $800.00
Recommended? Yes
Comments: This bumper is awesome! It's solid, looks great, and it's well designed. All I need now is a winch to complete it.
Red_
Red_'s Reviews
09-14-2008, 04:56 PM
ARB Bullbar
Price: $100.00
Recommended? No
Comments: Thing is a freaking tank front end and moderately heavy. Totally overkill, but if you can find it cheap well worth it. Only has two light tabs
