Warn Rocker Guards
Rating: |
Product Information
| MSRP: |
$550.00 |
| Average Price: |
$233.88 |
| Manufacturer: |
Warn |
| Recommended? |
Full length rocker guards that protect body from bashing on rocks between front and rear wheels.
jeepndon's Reviews
Price: $300.00 Pros: Look good Very Durable, Easy install Cons: none so far. Recommended? Yes
Comments: Great product and it was easy to install.
ItsMrHall's Reviews
Price: $330.00 Pros: Love the look, smooth and clean. Cons: Body Mod on last two bolts Recommended? Yes
Comments: Last two bolts bottom and sides required some body mods
phillies4752's Reviews
Price: $30.00 Pros: Awesome protection! Very heavy duty Cons: Installation was a bit hard. The body was in the way of the last bolt on both sides Recommended? Yes
Comments: Got the product used. I grinned the rust/paint down and rattle canned it with primer and flat black. Looks brand new. Awesome product and will save me a lot of damage in the future. Would defiantly suggest this product.
Kinless's Reviews
Price: $100.00 Pros: Easy Install Cons: Dont cover as much as I would like Recommended? Yes
Comments: I bought these from a local person just to have something till I could get the ones I want. Decent for 100 bucks.
hybridmoments's Reviews
Price: $200.00 Pros: protection Cons: none Recommended? Yes
Comments: I actually have corner armor, but it's painted so you cannot tell. I like it though
provinT13's Reviews
04-28-2010, 04:57 PM |
Price: $299.99 Pros: Easy to install, clean, tuff, provides nice rocker protection. Cons: Mine seem to have faded a little bit in the sun after a few years. Recommended? Yes
Comments: My warn rocker guards are great. They're easy to mount, look nice and clean. They don't have a big tube step to get in the way, which I didn't want when looking for my rockers, but they do have a small tube-like round edge on the bottom, giving them a clean look and making them easy to slide on.
kelso1337's Reviews
Price: $800.00 Pros: Very solid product, no tube (good or bad), Little circular lip around the tip of jeep for added protection. Cons: Cannot use stepguards as well - not enough room. Recommended? Yes
Comments: These rocker guards are very strong, stiff, and formed well to the body.
I especially like the "lip" that goes around the bottom panel for added protection. The rocker guards came with it black powder coated finish. Which holds up pretty strong. But soon will need to be painted. Personally the "powdercoat" is too glossy.
The install was pretty straight forward, I strayed off a little to make some modifications. However, the instructions I found were lacking. The bolts didn't match up with the bolts on the picture/description. No sure what that is about but if you just use common sense you should not have a problem.
dahlski6's Reviews
Price: $250.00 Pros: Easy Install, Awesome Looks, Tough Cons: None Recommended? Yes
Comments: Worth the money. Strong and they look sweet.
plumber1's Reviews
Price: $1.00 Pros: Very heavy Cons: None Recommended? Yes
Comments: I have beat the hell out them and have saved my sides many time. Would buy them again
jeepinmichguy_'s Reviews
Price: $250.00 Pros: sturdy, 3/16th thick, easy mounting Cons: none Recommended? Yes
Comments: I got a good deal on these and picked them up for the YJ. The are easy to install in use a few body mounts for extra protection so get the PB Blaster ready! All in all there a great buy for the money. I would highly reccomend.
scdiver's Reviews
Price: $150.00 Pros: durable and does the job Cons: have to drill in tight places Recommended? Yes
Comments: it is good and looks good on the rig had to drill in tight places for the rear bolt
peddlerofpunk's Reviews
Price: $1.00 Pros: good coverage Cons: no side steps Recommended? Yes
Comments: over all good beefy construction, they came already installed on the jeep...
ModernJ's Reviews
Price: $265.00 Pros: Fairly easy install. Heavy duty enough for most Jeeps. Cons: Drilling holes in body. Not much underneath protection. No frame attachment. Recommended? Yes
Comments: It was easier to install by first check fitment. Then hold rail in place and drill the center top hole. Loosely attach that screw. Then drill and attach the remaining upper screws working out from the center. This made the screw holes exactly where I needed them. Following the instructions and drilling all the screws then mounting the rail caused some issues as the holes were not in the exact spot I needed them. Also when drilling into the side of the Jeep be careful as the drill bit really takes off through and can easily hit wires.
rstolz's Reviews
03-24-2009, 03:10 PM |
Warn Rocker Guards
Price: $75.00 Recommended? Yes
Comments: Got these of Craigslist. Just had them sprayed with Line-X. They look great, and offer great protection.
alexr40's Reviews
02-09-2009, 12:13 PM |
Warn Rocker Guards
Price: $250.00 Recommended? Yes
Comments: Excellent look and easy install.
They feel hard. Havent landed on a rock yet, but i am certain that they will perform a good job.
TJCole's Reviews
01-19-2009, 01:20 AM |
Warn Rocker Guards
Price: $105.00 Recommended? Yes
Comments: Good. I got it new off of ebay. Some guy just didn't want it anymore.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ajeepcreep's Reviews
12-25-2008, 03:39 AM |
Warn Rocker Guards
Price: $260.00 Recommended? Yes
Comments:
Jgrand03's Reviews
12-24-2008, 12:20 AM |
Warn Rocker Guards
Price: $200.00 Recommended? Yes
Comments: Great product offer great protection powder coatings isnt up to par but nothing a little spray paint cant fix
jokre's Reviews
11-08-2008, 08:32 AM |
Warn Rocker Guards
Price: $150.00 Recommended? Yes
Comments: These rocker are really well built and easy to install, they look good and they will take a hit without thinking twice
