Smittybilt - Smittybilt SRC Side Armor
Rating: |
Product Information
tcanzonieri's Reviews
Price: $300.00 Pros: Rocker protection with integrated step Cons: NA Recommended? Yes
Comments: Easy install, great protection, acts as a step as well. Have been installed nearly 6 months and off road every weekend, finish and quality are still as new.
silverbullet556's Reviews
10-13-2011, 11:25 AM |
Price: $189.99 Pros: Provides protection for rockers and they look sweet. Cons: none Recommended? Yes
Comments: Installed them myself in about an hour. It took a little patience and the socket I used kept getting stuck. They provide adequate protection and look good.
Powrjunkey's Reviews
09-06-2011, 12:56 AM |
Price: $189.00 Pros: strong solid steel bars, attractive powder coating, great step, awesome protection. Cons: reduced ground clearance by about 1-2", but it doesnt go below the transfer case, its not the lowest point. they are heavy, but they are steel(duh) Recommended? Yes
Comments: I got this so cheap because my rear bumper didnt fit right as it came in the box and smittybilt reduced the price. I would pay 300 for this set. was recently sandwiched on the freeway between a dodge nitro and a mercedes. it prevented any body damage. the powder coat was worn off, and my fender flares were damaged, but nothing on the metal or mirror. they are solid, and if you spend the time to install them correctly, you cannot go wrong. highly recommend, they are a great step too.
Alohi Ahi's Reviews
Price: $299.00 Pros: Looks great
Solid Cons: Difficult to install Recommended? Yes
Comments: What should have been a very easy install ended up being an exercise in frustration because the front mount was just a hair too narrow. Some jack work fixed that and now install they look great..
robs9873k's Reviews
Price: $260.00 Pros: goog low step for kids and wife Cons: none Recommended? Yes
Comments: heavy duty construction, nice looking finish. pretty east to install alone once i figured out how to prop guards up to mark frame mounts
IWaveAtNight's Reviews
06-27-2011, 11:25 AM |
Price: $299.00 Pros: Sturdy, heavy duty, looks great Cons: bright yellow smittybilt logo in the middle Recommended? Yes
Comments: Got these on amazon, and they shipped for free and no tax (Im in CA.)
Went on pretty easy, just make sure you use a fairly new drill bit and the holes come easy. Followed others' advice of using floor jacks to hold them while drilling, made it really easy.
They look great and are a solid guard for my rocker panels. THey double as a step so now girls dont complain about getting in
AcidRaiN's Reviews
Price: $299.00 Pros: Durable and Beefy! Cons: Drivers side didn't fit very well. I had to grind down the front bracket to fit around the body mount Recommended? Yes
Comments: The rocker rails seem very sturdy and durable. I had a fitment issue on the drivers side. I had to grind the forward bracket to fit around the front body mount. The passenger side went on smoothly. Also, the directions from smittybilt did not mention taking off the factory rocker rails. I had to figure that out on my own.
Krazy302's Reviews
Price: $100.00 Pros: Covers Rocker panels Cons: none yet Recommended? Yes
Comments: Item was fair priced.. Just needed something to help from getting rockers all scratched up and dented.
mcgoo26's Reviews
Price: $256.00 Pros: None yet Cons: You have to drill into the frame. Recommended? Yes
Comments: Have yet to test them out.
sxysouthtx's Reviews
Price: $275.00 Pros: Looks great. Cons: A pain to install. Recommended? Yes
Comments: These tub guards really bring my Jeep's appearance to a new level.
xmedicmanx's Reviews
Price: $249.99 Pros: Very tough metal ... Great powder coat finish ... easy to install Cons: none Recommended? Yes
Comments: This is probably one of the best items that I have put on my jeep ... Very strong great tough powder coat finish.
Jesses97sahara's Reviews
Price: $219.00 Pros: good price
hasnt rusted
good protection
look great Cons: none Recommended? Yes
Comments: This is a great product i have had no problems with it. Install is a little interesting, i am very inexperienced and i figured it out within two hours. This product is well worth the price i would recommend it.
Leoboy297's Reviews
Price: $220.00 Pros: Great look, Awesome armor Cons: need at least 2 people to install Recommended? Yes
Comments: Contrary to popular findings, smittybilt has finally put out some great armor. This stuff is tough, heavy, and looks good. They supply all beefy hardware, and said and done it looks good. would deficiently use again for full corner guards.
cthompson8846's Reviews
Price: $200.00 Pros: Great protection, great price, look good, easy to install. Cons: none yet Recommended? Yes
Comments: recommended
Fireman0402's Reviews
Price: $135.00 Pros: I got them second hand for a great price. They look great, they double as steps, but I have yet to test them out off road. Cons: Install is a pain in the butt. Smittybilt had no online install directions nor did they return e-mails or phone calls. Recommended? Yes
Comments: I bought these roack rails for $135 and was happy about the price and the look. Install was a pain in the butt. I did read some reviews that said they have a tendency to cave in the middle without an extra support bar welded in there when you land square in the middle. Hence why Smittybilt no longer makes the SRC, their new generation roackrails are called XRC.
95YJohn's Reviews
Price: $250.00 Pros: sturdy, looked great at first Cons: cheap coating, cheap install Recommended? Yes
Comments: hardware coating faded and is now starting to chip. I recommend changing the mounting hardware to grade 8.
larubie's Reviews
Price: $225.00 Pros: Thick steel Cons: Poor finish (already rusting around welds), Poor fit, Poor packaging (arrived with lost parts, which took 6 weeks to arrive) DO NOT BUY ANYTHING SMITTYBILT!!! Recommended? No
Comments: Poor quality, poor finish, and very poor customer service if you need to talk to Smittybilt. The last email I sent took 2 weeks to be answered. Pro Comp is a sister company of them and is also trash (Chinese) quality.
hcw3's Reviews
Price: $270.00 Pros: look great Cons: they don't fit right, the forst set didn't the second set didn't either, bolt holes are as much as 1/4" off Recommended? No
Comments: I received my second set of side steps today after returning the first set for poor fit. The mounting holes are almost 1/4" off on front body mount holes and about 1/8" off on the most rearward holes. You can grind out the holes to fit (actually recommended by smittybilt support)but the flange on the bolt will no longer support the step on all sides if you do that. it'll hold, but a $270 part should work AND fit.
When I called smittybilt support with the second set, I was advised that "they were having some fitment issues with the product" and either i could return them and wait a few months for a revised product or I could "make them fit".
I'm sorry, I shouldn't have been sold a product that had "fitment issues". DO NOT BUY THIS PRODUCT IF YOU EXPECT IT TO FIT.
gmaheu's Reviews
Price: $240.00 Pros: look great, easy to install Cons: need some grinding to fit properly Recommended? Yes
Comments: I installed these bars myself in about an hour. Very easy install and they look great.
