Smitty Built rock sliders with step ups
Rating: |
Product Information
| Average Price: |
$212.97 |
| Manufacturer: |
Smitty Built |
| Recommended? |
Black with step ups; they mount onto the frame of the jeep.
mikesloudjeep's Reviews
Price: $350.00 Pros: Superior protection and BIG! Cons: Technique needed to get in! Recommended? Yes
Comments: Super good product. Pro would be (as in the pics) Its big and away from the sides. This protects the sides from taking impact. The only con that I can find to gripe about is it takes some learning to get in. BUT! It's way better than getting those "Sliders". You need to hit the side frame to use those and at that point you damage the vehicle. Great usable product. I've actually used it and found it to work over well! It's high on the sides so you don't bottom out on them like other products.
Uncfan900's Reviews
Price: $220.00 Pros: Heavy Duty Cons: Could be better instructions Recommended? Yes
Comments: Good price and good look to them.
wyliepeacock's Reviews
Price: $299.99 Pros: Tough & Durable, the price was right, but there's a lot to choose from. Cons: Install is tricky, make sure these are what you want, it's as easy to boat the sides while you're at it, so think about the future. Recommended? Yes
Comments: I have used and abused these sliders glad to have them I'm sure they've saved the body more than once.
cont7's Reviews
Price: $249.99 Pros: Awesome finish, great packaging Cons: none Recommended? Yes
Comments: If you install them, just remember, you are about to drill the body of your jeep. In my jeep, when installed, it left a little separation body-rock slider that allowed water in. I strongly suggest to clean all, and spray with WD40, or a sealant, so it won't corrode within a few years. It's inevitable, but they did stand the 200LB test of me standing over them LOL
Alohi Ahi's Reviews
Price: $299.00 Pros: Solid
Looks great Cons: Difficult to install on front body mount Recommended? Yes
Comments: Look great on and relatively easy to install. The front mount did not fit into the front body mounts flange and required some help from the jack to force it in enough to get the nuts back on the mount pins.
Other than the install they look great and I have already received many compliments.
Carkinjim3's Reviews
Price: $189.00 Pros: Easy install and completes the look of my jeep. Cons: Surface rust from the start :( Recommended? Yes
Comments: I have all Smittybilt body armor and bumpers on my YJ. The look is great, but the armor rusts at the seams. I'm currently rustproofing everything as it shows up.
You get what you pay for... but, I love the overall look!
IbeamYJ93's Reviews
Price: $239.00 Pros: powder coated free
well built Cons: none Recommended? Yes
Comments: Great quality fast shipping
Although the box it was shipped in, was broken open
upon delivery and there was no mounting hardware.
s_beckerle's Reviews
Price: $249.99 Pros: Like the added step, and the protection. Cons: Have to drill into your frame, which was scary. Recommended? Yes
Comments: I purchased these from the 4wheel Jamboree in Allen County Ohio, and installed the next weekend. They are nice and do their job.
kennyboobear's Reviews
Price: $179.99 Pros: Good solid economically priced rocker protection Cons: Doesn't run all the way to the frame throughout the whole slider, only the rear half does. Recommended? Yes
Comments: Install was easy, very nice fitting product, lined up perfectly with my smitty full corners, and had to trim a bit for the fitment to match my metalcloak fenders.
oitprichard's Reviews
Price: $200.00 Pros: Easy install, heavy duty. Cons: Step gets your pants dirty. Recommended? Yes
Comments: I've been very happy with my purchase of the XRC rocker guards. The install was easy. I bought them to cover up some rocker damage and prevent new damage. They're pretty heavy duty, 3/16" steel. I got free shipping from Amazon. The only problem is when I get out of the Jeep, especially now with the lift, my pants will get dirty. Not a huge problem, but it's my DD.
chris_ce's Reviews
Price: $187.00 Pros: Good fit. Seem strong. Cons: Would like the option of getting them bare metal instead of the powder coat. Recommended? Yes
Comments: Good fit and finish for the price.
skiandgolf's Reviews
Price: $178.00 Pros: Well built, look good Cons: None so far Recommended? Yes
Comments: Took a little while to install the first, but second went right in with the experience gained from the first. Maybe did not need to cut down the body mount, but did it anyway. Excellent product for the money.
sxysouthtx's Reviews
Price: $300.00 Pros: looks great. Cons: Coating could have been thicker. Recommended? Yes
Comments: Looks great, easy installation, and really gives a good place to put your foot when driving.
BlkJeepTJSahara's Reviews
Price: $158.00 Pros: Read below Cons: none really Recommended? Yes
Comments: This is the review for the Smittybilt rocker guards WITH the step up. I bought the set WITHOUT.
Install wasn't too bad. You have to lift the body off the frame to insert the bottom part of the rocker guards (loosen the opposing bolts and unbolt completely the side your installing the rocker on. They say to trim the body mounts to accommodate the guards but I just pushed them in and torqued everything back down (squashed the two body mounts) and it fits nice. I also found it UNNECESSARY to remove the rocker guards before drilling the holes on the body. Make sure the guards are pushed in snug between the body mounts and then use a floor jack to push the guards firmly up against the body. Then use the rocker guards as a template to drill and bolt them to the body. Much easier.
I chose the model WITHOUT the step for a couple reasons:
WITHOUT the step combined weight of the guards are 33 pounds, WITH the step they're 70 pounds... Double the weight..
Also, getting in and out of the jeep I thought it would be a pain having them get in the way. Plus I hear its not really useful as a step for entry being that its higher than the floor.. (maybe to get to the roof it would useful, which I just step on the body anyway when I open the door).
I dont plan on going anywhere where protruding boulders threaten the body of my jeep so that extra protection of the step I feel didn't need. Just all my opinion.. buy what you feel you need I guess..
They look great, and for the price can't be beat.
tangotag's Reviews
Price: $188.00 Pros: Cheap, solid, powder coated. Cons: One side hole would have fit better if it was drilled 1.5" over. Recommended? Yes
Comments: These are solid built, welds look good. Shipping weight was 72.1 Lbs. I got them from Streetsideauto.com and shipping was free for $188.
The rocker guards are out of 3/16" bent plate they attach underneath by the 2 rear body mounts. The instructions state to remove 3/16" off the body rubber or body lift. Most people never need to do this. The drill hole body hardware is all stainless steel. Washers are small, fender washers would have been a better solution. I plan to cut bar steel for a larger full length backing plate in the cab.
JeepJake24's Reviews
Price: $200.00 Pros: Cheap compared to other manufacturers Cons: Poor powder coating Recommended? Yes
Comments: These sliders work and look good while doing it!! The only problem is smittybilt's poor powdercoating. Nothing too substantial though.
JG04TJ's Reviews
Price: $180.00 Pros: do not take away any ground clearance Cons: installation, compared to factory side steps Recommended? Yes
Comments: My 04 TJ X did not have any factory side steps on it when I got her. I shopped around and came across the Smittybilt XRC Armor Rock Sliders. I really liked the way the looked and found them less expensive than any other side step on line. The instructions were a little overwhelming at first. One website went as far to say that they did not even include instructions because the rock sliders should only be professionally installed. But I looked up a thread on Jeep Forum and found a much easier way to install them. Did it in an open garage, in the middle of February, in Columbus Ohio, high of 30 degrees. I over analyzed every part of the installation and it took me around 4+ hours. But if everything I needed was laid out to use, then I could install them in about an hour. You can do it.
minesbetter's Reviews
Price: $200.00 Pros: looks good, good construction Cons: heavy, hard mounting at first, bad install instructions Recommended? Yes
Comments: good rockers, affordable, will recoment to friend
north50's Reviews
Price: $175.00 Pros: makes the Jeep look taller and should help protect Cons: had small chip in coating from shipping Recommended? Yes
Comments: For the price I couldn't beat them
WheelieTime's Reviews
Price: $239.00 Pros: Heavy duty. Good Style. Great Welds. Cons: Holes did not line up completely. Had to drill out slightly to fit. Recommended? Yes
Comments: Great style, Just wished the slipped on as easy as the should of both sides the front mount was off by about half an inch.
