Go Back JeepForum.com > Reviews > Armor > Rocker Guards > Raingler Jeeperman Rocker Skidz
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Raingler Jeeperman Rocker Skidz Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Rocker Guards Next Product
Rating:
Product Information
MSRP: $300.00
Average Price: $250.00
Manufacturer: Raingler
Recommended?
Yes: 5 / No: 0
These are designed to save your Wrangler's rockers from showing all the fun they've seen and provide easier access in and out. Include a welded on 2"dia. DOM tube for pivoting and sliding over the rocks without getting hung up. Our unique mounting plate actually "sandwiches" the frame with dual 3/8" thickness; hence no drilling is required to induce rust or possibly weaken the frame, and our 3/8" thick bracket plates distribute the load of impacts or jacking vertically across the frame (and not through a drilled in frame bolt) for serious extreme strength and less chance of damage. 2x2" 3/16" thick steel tapered front and rear to slide over and not hang up on the rough stuff. Outer tube is approx. 4.5" from the sheetmetal on the Wrangler.
FmrVette
FmrVette's Reviews
03-09-2008, 08:38 PM
Price: $200.00
Recommended? Yes
Comments: One person install. Very cool. After 2 Detroit winters the powder coat has worn off and surface rust has appeared on the top of the skid.
ryan3098
ryan3098's Reviews
04-08-2007, 10:59 AM
Pros: Easy mounting. Well built. Doubles as step with plate
Cons: Bolts directly over lines on frame. Needed relocation
Recommended? Yes
Comments: Product came very well packed with no scratches in the paint. No directions though that was not a problem, only a handful of bolts and 4 pressure plates. Diamond plate also significantly reduces the amount of rock and other debris that strikes body and paint while driving. Easy install with a helper. I needed to ground down frame welds in order to properly mount the front mounts. You also must relocate lines that run down the left frame rail to accommodate the frame mounts. 20 min to 30 for entire job with grinding.
tomcathy
tomcathy's Reviews
12-24-2006, 08:58 AM
Pros: strong, the way they are attached to body.
Cons: Very heavy
Recommended? Yes
Comments: Very happy with them.
CNY
CNY's Reviews
09-26-2006, 03:14 PM
Pros: Easy install, no drilling. Seems strong.
Recommended? Yes
Comments: One of the nice things about these rocker guards is that they cover wheelwell-to-wheelwell.
Most (all?) of the tub mounted ones only protect flair-to-flair (like that plastic fender flair is going to protect anything ).
The step is slippery when wet.
If you're looking for frame-mounted rocker protection, these are the way to go. They cam highly rated, and I was not disappointed.
Since this picture was taken, I have scraped them up a bit at Paragon. They didn't dent, just scratched. Quick touch-up with spray-paint keeps the rust away.
mudmonkey2400
mudmonkey2400's Reviews
09-04-2006, 10:18 PM
Price: $300.00
Pros: Protects outer edge of tub. Solid construction. Easy installation. Works as a step.
Cons: Does not give quite the protection a body mounted rocker guard would.
Recommended? Yes
Comments: Love the product. Installation is like child play. 4 bolts on each side, and you're done, although it's nice to have an extra set of hands or some other way to support them as you bolt the clamps on. All the rocks I've encounted have only scuff the powder coating, no bends or dings. Raingler's customer service has been one of the best I've ever encountered, and would strongly reccommend them to anyone.
*edit* Will not work with Rock Krawler's new bent long arms. If you're looking for a set and thinking you might go LA, make sure these will work with the arm's mounts and/or bends.
ThreadForumRepliesLast Post
Jeeperman JS Jeeperman TJ/YJ/CJ Swingaway Bumpers 12 01-14-2011 07:36 PM
Jeeperman 54H Jeeperman Receiver Winch Bumper Bumpers 7 12-15-2009 11:53 PM
Rock-It Man Fabrication / Jeeperman Ultimate Rocker Guards Rocker Guards 9 09-05-2009 09:04 PM
Jeeperman Jeeperman Bumper (not swingaway) Bumpers 2 04-29-2008 07:30 PM
Jeeperman JBST TJ/LJ Jeeperman Rockers Skid Plates 1 11-07-2006 10:28 PM
Glock Forum
