OEM - WJ Overland Rock Rails Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Rocker Guards Next Product
Rating:
Product Information
MSRP: $200.00
Average Price: $193.75
Manufacturer: OEM
Recommended?
Yes: 4 / No: 0
Company Website: http://www.jeep.com
The Overland rails can be purchased and easily installed on other WJ models, as shown in the above photo of a 2002 Limited. The Overland rails are functional, made of steel and weigh about 30 Lbs each. Only the adjustable end caps are plastic. The bolt holes for mounting the rails are already designed into the frame area on 2002 and later models. For 1999-2001 WJ's mounting holes must be drilled into the frame. For Laredo models, the side cladding must be removed in order to install the Overland rails. If you purchase a used set make sure the 12 J-nuts are included as well as the other parts listed in the chart below. The front brackets are built onto the rail and are not available separately. Butchen Engineering and Prince Metal Products designed and manufactured the rails for Chrysler.
factory , grand cherokee , oem , overland , rock rails
Highschool_WJ
Highschool_WJ's Reviews
05-30-2015, 10:34 AM
Price: $200.00
Pros: Plenty heavy to protect the rockers
Cons: Doesn't have much protection from the side, and rust easily if not protected from the elements getting in the ends
Recommended? Yes
Comments: Work great if you can get them at decent price and they aren't all rusted out
JimmydaGreek
JimmydaGreek's Reviews
04-19-2013, 02:45 PM
Price: $175.00
Pros: OEM
Cons: None
Recommended? Yes
Comments: Love the OEM look.
peytonimor7
peytonimor7's Reviews
12-03-2012, 09:23 AM
Price: $200.00
Pros: Great OEM fit; contour well to the body; Great protection for OEM armor
Cons: Heavier duty rock rails can be purchased for the same price from aftermarket companies; No lateral protection
Recommended? Yes
Comments: If you find a good deal on these, I say jump on them. They're definitely better than no rocker protection at all. If you don't plan on doing hardcore wheeling, I feel as if these will be plenty. I've scraped mine a couple times with no problems. Just don't go putting all the weight of the Jeep on them.
For the right price, these are great. I wouldn't pay over 150-200 for a pair in moderately good condition.
