Go Back JeepForum.com > Reviews > Armor > Rocker Guards > JKS JKS Supernerfs
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
JKS JKS Supernerfs Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Rocker Guards Next Product
JKS JKS Supernerfs
Rating:
Product Information
MSRP: $650.00
Average Price: $323.57
Manufacturer: JKS
Recommended?
Yes: 5 / No: 2
If you want "Real Rocker Protection" then look no further! Absolutely hands down, the nicest and most effective protection you can find for your Jeep. They will support the full weight of your vehicle without damage and you can even use your "HiLift" jack on them without worry. They work great for keeping the body off of rocks and trees. After having them on your Jeep you will find them great for pivoting around obstacles and you will come to rely on them frequently.
The backbone of the SuperNerf is the 2 x 2 x 3/16" square tube. It attaches to the pinch weld and supports the underside of the rocker panel from wheel to wheel. That allows any impacts to be distributed over a very large area eliminating damage to the rocker panels. They bolt into the pinch weld in several locations and also tie into the uni-body in two locations giving incredible strength.
The outer tube is made from 1 1/4" x .140 wall pipe (which has a 1 5/8" OD) and is situated outside the body contour so it can be used as a true "nerf" bar. You can slide both tubes over or against any kind of obstacle all day long without damage to the rocker panels. The last feature, which sets our "SuperNerfs" apart from all the copies, is the two small supports which tie the inner and outer tubes together giving an incredible amount of side load strength.
Our "SuperNerf" bars come powder coated in satin black. Yes, you will scratch them up when off-roading but semi-flat spray paint matches quite well. SuperNerfs are designed for bashing on rocks ultimately saving expensive body damage to your vehicle. They will pay for themselves the first time out!
seanmearse
seanmearse's Reviews
06-29-2011, 08:35 PM
Price: $100.00
Pros: not too heavy, fit clean and tight to the body, solid
Cons: none right now
Recommended? Yes
Comments: I have smashed, dragged, kicked, hit with my head, not one problem with these bad boys. The price I paid was from a friend, not retail.
frankenjeep
frankenjeep's Reviews
02-19-2011, 05:32 PM
Price: $345.00
Pros: great protection excelent price.... no more door dings from soccer moms and thier spawn.... these stick out to protect your handels and doors.
Cons: difficult install. one side did not fit right... but with some fabing i got er dune
Recommended? No
Comments: one side the insert tubes didnt fit so.... had to fab and grind and take off burrs....
NorCOWJ
NorCOWJ's Reviews
06-18-2010, 12:27 PM
Price: $200.00
Pros: strong beefy outer tube
Cons: powder coating on edges and corners
Recommended? Yes
Comments: bought these used off of craigslist. first thing i noticed was that some how rust built up underneath the powder coating especially on the edges and corners. other than that they are really beefy and can take a lot of damage. recommend welding them in, it stiffens up the slider from moving up and down
Kramer H
Built and Supercharged 47
Kramer H's Reviews
11-27-2009, 04:22 AM
Price: $185.00
Pros: Awesome protection
Cons: not enough pinch weld mounting holes
Recommended? Yes
Comments: freaking sweet stuff!
CTJeepWJ
CTJeepWJ's Reviews
07-29-2009, 10:00 AM
Price: $325.00
Pros: Solid protection and a good look.
Cons: Real difficult to install.
Recommended? No
Comments: Solid protection and a good look, Real difficult to install even with the right tools, jacks etc.
froggo27
froggo27's Reviews
01-01-2009, 11:31 PM
JKS JKS Supernerfs
Price: $460.00
Recommended? Yes
Comments: Effing awsome, saved my Jeep a lot of times. Strong and sturdy product. I'd recommend to everyone.
ThrillSeeker
ThrillSeeker's Reviews
09-17-2008, 01:42 PM
JKS JKS Supernerfs
Price: $650.00
Recommended? Yes
Comments: These rock sliders are of great quality. They look good too and did not interfere with clearence. So far no rocker problems...
Glock Forum
