Go Back JeepForum.com > Reviews > Armor > Skid Plates > Warn TJ Gas Tank Skid
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Warn TJ Gas Tank Skid Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Skid Plates Next Product
Rating:
Product Information
MSRP: $325.00
Average Price: $229.75
Manufacturer: Warn
Recommended?
Yes: 11 / No: 0
3/16" steel skid. Factory tank mounts to skid. No lift required. New model also has 1/4" thick allowance for the fuel pump area for earlier model TJs.
robob280
Junior Member
robob280's Reviews
06-30-2011, 09:34 AM
Price: $307.00
Pros: 1 inch gas tank lift, heavy duty steel
Cons: heavy duty steel
Recommended? Yes
Comments: Heavy but well worth its weight in steel, also boosts the height of the gas tank too. We'll see how it fares offroad
jeep2008
jeep2008's Reviews
12-27-2009, 04:43 AM
Price: $260.00
Pros: black powder coted,HD construction,better clearences than stock.
Cons: Heavy,go for savvy's if you can.
Recommended? Yes
Comments: Good quality,great painting but savvy's newone is lighter and with great price as well.I installed WARN's cause i found it really cheap in greece and it was allready black whereas savvy's i had to ship it fron US and also paint it black.
elpound
Junior Member
elpound's Reviews
03-26-2009, 01:11 PM
Price: $320.00
Pros: Fits like a golve.
Cons: None that I know of
Recommended? Yes
Comments: I installed this tank skid on my own. was simple and is a great improvment over stock plate.
AlexGeorgakis
AlexGeorgakis's Reviews
02-26-2009, 08:20 AM
Price: $211.00
Recommended? Yes
Comments: Heavy duty, direct bolt on. No problems even in the roughest conditions. Just make sure you have help when installing it cause it's quite heavy!
bartlanz
Been There, Done That
bartlanz's Reviews
06-29-2008, 07:15 PM
Price: $40.00
Recommended? Yes
Comments: Nice product, easy install not like any of these skids would be hard, has three points of mounting and they provide you with all of the needed hardware to do it.
dakuda
Admin, Jeep in Pieces
dakuda's Reviews
03-28-2008, 08:49 PM
Pros: Works
Cons: BS bickering between Kilby and Warn camps
Recommended? Yes
Comments: It does what it is supposed to do. Installation is not difficult. Simply works.
PullMeSideways
PullMeSideways's Reviews
03-09-2008, 03:21 PM
Price: $250.00
Recommended? Yes
Comments: Awesome piece and very strong
rgingerelli99tj
rgingerelli99tj's Reviews
02-27-2008, 01:11 PM
Price: $325.00
Recommended? Yes
Comments: Works great. I have set the whole weight of my Tj on it on some rocks and it didnt budge.
JLRUBICON
JLRUBICON's Reviews
10-21-2006, 10:36 PM
Pros: Tuff
Recommended? Yes
Comments: gotta have skids
sahara tj
sahara tj's Reviews
09-02-2006, 10:51 PM
Pros: Very Strong. Easy to install.
Cons: Same clearance as the stock skid.
Recommended? Yes
Comments: Have an 02 TJ with RE 3.5" Superflex lift and 33" tires. Bought the Warn due to price. It does have the fuel pump drop which is a plus. After looking at the damage on the stock skid after a couple trips thru the Rubicon and other trails as hard or harder the clearance should not be an issue IMO, and the drop for the fuel pump has not been hit due to its location.
SirGCal
SirGCal's Reviews
08-03-2006, 02:54 PM
Price: $125.00
Pros: Very strong! Stronger fuel pump drop clearence in bottom.
Cons: hangs slightly lower than older design.
Recommended? Yes
Comments: I had the older flat one (like the Kilby) and it was very nice (just cheaper). Then they came out and reinforced a clearence in the bottom for the fuel pump with 1/4" plate (even stronger). Downside is that means a slight clearence loss obviously since it hangs lower but... Ehh.. no biggie..
I've dropped the rig over 2' onto pointed rocks and logs using this skid, both on the old one and the new one. Neither one ever flinched.
ThreadForumRepliesLast Post
Skid Row Gas Tank Skid Plate (TJ / XJ) Skid Plates 9 08-24-2010 12:26 PM
Factory front skid and rear gas tank skid OEM Skid Plates 9 02-07-2010 10:31 AM
Warn Gas Tank Skid Plate Skid Plates 7 12-14-2009 10:48 PM
Warn Steering box skid Skid Plates 28 12-14-2009 06:32 PM
skid row Jeep TJ Wrangler Gas Tank Skid Plate Skid Plates 2 08-16-2007 11:39 PM
Glock Forum
