Notices
UCF Transfer Case Skid Plate Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Skid Plates Next Product
Rating:
Product Information
MSRP: $170.00
Average Price: $339.04
Manufacturer: UCF
Recommended?
Yes: 46 / No: 1
Company Website: http://undercoverfab.com
HD Transfer Case Skid Plate for '97-'06 Jeep Wrangler TJ
Some people call these "belly-pans" and others call them "tummy-tuckers". Fit Jeeps with standard or automatic transmissions.
It is made from 3/16" thick carbon steel plate. The parts were designed in 3D CAD software and laser cut then bent on a CNC press brake for a perfect fit every time.
The transfer case skid is reinforced in the middle of the skid from one side to the other with a stiffening channel/transmission mount. The front and rear edges are ramped to aid in sliding over obstacles. It will increase ground clearance by about 2" over the factory skid plate. The total height of this system is about 2".
We recommend that you have at least a 1" body lift to install this skid plate with no body/transfer case vibration issues.
This product listing does not include the transmission pan skid plate.
Mounting hardware not included. Shipped UPS in bare steel.
None
Page 2 of 3 1 2 3 > Last
Fuzzcheek1
Fuzzcheek1's Reviews
01-26-2012, 12:37 AM
Price: $700.00
Pros: Great quality, fast shipping, easy install.
Cons: I wish it came powder coated.
Recommended? Yes
Comments: Awesome build quality and fitment was perfect. I really like the extra clearance this skid plate system offers over my stock shovel. I would buy it again in a heartbeat.
Zakman
A locked & armored LJ
Zakman's Reviews
12-07-2011, 03:54 PM
Price: $230.00
Pros: No BL required for a slight TT
Cons: None
Recommended? Yes
Comments: UCF no BL required flat skid.
Gained 2" over stock x-fer case skid.
No BL required for installation.
Works with Skid Row engine skid.
USA made!
julietkilo
julietkilo's Reviews
11-14-2011, 09:23 PM
Price: $265.00
Pros: UCF, awesome quality
Cons: Heavy Exhaust, Mount, Body, transfer case linkage modifications.
Recommended? Yes
Comments: If you are ready to get rid of the shovel have the following ready before you install this.
Prep work, Paint 20
1 inch body lift, 1 inch Motor mount lift 200
UCF skid 260
upper/lower adjustable control arms (Rokmen) 600
JKS Track Bar and CV bracket 250
Novak shifter cable 160
1350 Double Cardan Driveshaft 400
Shock mount cut/reweld Free, I have a welder (50-100 for a shop)
Welder, Air Tools, Misc Tools, Angle Finder, etc. Time to get it just right.
Flip Rotate Rubicon Motors under Jeep, custom mount.
Figure 2000 bucks to get it done with Good parts, you can do it less but dont cheap out on parts, you will just have to do it again when they fail or dont line up right.
Weelz
Weelz's Reviews
11-11-2011, 04:46 PM
Price: $800.00
Pros: Pretty easy install. Lightweight.
Cons: Not cheap.
Recommended? Yes
Comments: This if for both the engine skid, the ultra-high clearance transfer case skid and the lowpro transmission mount. Great products. Install instructions were a little vague/inaccurate in some ways. For example, I didn't need to cut my exhaust hanger, though that step was in the instructions.
JOXJ87
JOXJ87's Reviews
05-19-2011, 01:46 PM
Price: $300.00
Pros: Very small. Give you the highest ground clearance of all i researched and found for a damn good price
Cons: Makes it tricky to get the linkage on the t-case right with it shoved so far up in there.
Recommended? Yes
Comments: Real simple to install. I went with the one inch deep that calls for one and a half inch ++ body lift with only doing a tiny bit less than one inch BL and no clearancing. I wish i had the money for the cable T-Case linkage and there was no links to adjust for that piece cause it is hard with it crammed way up. exaughst rattles a tad but i dont care. awesome skid and great price.
mpoo1083
mpoo1083's Reviews
04-21-2011, 10:23 PM
Price: $1.00
Pros: i honestly forget the price. i ordered the body lift, motor mount lift, lopro mount, ultra high clearance t-case skid and engine skid, all in the 3/8" aluminum..this is absolutely amazing, can take a beating, and looks great
Cons: nothing
Recommended? Yes
Comments: everything about it is great including customer service. i honestly forget the price. i ordered the body lift, motor mount lift, lopro mount, ultra high clearance t-case skid and engine skid, all in the 3/8" aluminum..this is absolutely amazing, can take a beating, and looks great. UCF is great to deal with.
NBFarmboy
NBFarmboy's Reviews
03-19-2011, 09:35 PM
Price: $134.00
Pros: Light Weight, Heavy Duty, High Clearance AMERICAN MADE!!!
Cons: interior will get hotter due to the exhaust and tranny being closer to the body but it is not unbearable none in my opinion at least 1" body lift required but the amount of clearance gained is worth it 10fold
Recommended? Yes
Comments: For the amount of worked needed to put this skid plate on, the amount of satisfaction is unbelievable, i already had all the prerequisites so it was a simple skid swap for me, wow awesome product
at least a 1" bodylift and slip yoke eliminator with cv driveshaft needed
1" motor mount recommended
UncleWilson
UncleWilson's Reviews
03-19-2011, 05:30 PM
Price: $280.00
Pros: Heavy Strong
Cons: Umm....
Recommended? Yes
Comments: If it got destroyed... (not sure HOW it could be...Nuke...) I would buy again!
MakeyourlucK
MakeyourlucK's Reviews
03-06-2011, 04:55 PM
Price: $600.00
Pros: light weight
Cons: NO directions
Recommended? Yes
Comments: I got the Aluminum transfer case and engine skids and they are great quality and the price was good
jrfII
jrfII's Reviews
01-23-2011, 05:41 PM
Price: $350.00
Pros: Very lightweight and heavy duty. Awesome construction and welding. Bolted right in by myself in a couple of hours. Matt was very helpful with shifter issue. Incredible product for the price!
Cons: Had to mod fan shroud and drop with 1/8" spacers to get into 4LO.
Recommended? Yes
Comments: While searching for a TT for the TJ without lift I found UCF. The price was excellent considering the competition. It was a very easy bolt in even though I had to mod the shroud and drop for 4LO to engage.
It added over 1" of break-center height on our stock TJ! This is the easiest and best built tuck on the market!
Call Matt, he will treat you well! Love my UCF tuck!!
ghndrcks
ghndrcks's Reviews
12-03-2010, 08:40 AM
Price: $400.00
Pros: good strong skid
Cons: heavy
Recommended? Yes
Comments: Good product. No warnings on anything your about to do though. t-case shift linkage will bind when installing this item.
AstroZombie
AstroZombie's Reviews
11-18-2010, 12:56 PM
Price: $200.00
Pros: Very solid construction, have beat the heck out of this skid and it takes everything I can give it.
Cons: The only minor con I have is the mounting surface of the skid should be countersunk to allow it to sit flush against the frame rails. The factory rivnuts stick out a bit leaving about a 16th" gap between the frame and skid. Once again, this is only a minor con, and would not sway my mind if I were to buy another UCF skid.
Recommended? Yes
Comments: I absolutely love this skid. I wanted to try the aluminum version, but I scored the steel version used for a great price. I have had the full weight of the Jeep on this skid many times and it always takes the beating. Has not deformed like the factory skid. Much stronger, not a shovel, and slides over everything I can imagine driving over. Highly recommended.
greenglazier
greenglazier's Reviews
11-05-2010, 09:38 PM
Price: $230.00
Pros: great product i bought the 3/16 steel and it's strong, installation a bolt on mod easy
Cons: none
Recommended? Yes
Comments: great product
Fropleyqk
Fropleyqk's Reviews
06-12-2010, 05:27 AM
Price: $750.00
Pros: Aluminum
Cons: Dont know yet
Recommended? Yes
Comments: The $750 was for the tranny skid, engine skid, lopro mount and rubicon pumps bracket. Its sitting in the garage with a pile of other stuff. Havent installed it yet.
pirateat53
pirateat53's Reviews
05-20-2010, 02:35 PM
Price: $209.00
Pros: excellent
Cons: none..
Recommended? Yes
Comments: Very heavy duty and gave me that extra clearance that is needed especially when you have a shovel for a factory skid.
servozn
servozn's Reviews
05-03-2010, 12:44 PM
Price: $450.00
Pros: tucked everything up nicely
Cons: none
Recommended? Yes
Comments: Very easy to install. I used the lo-pro mount as well since I do not have a body lift.
gregdean13
gregdean13's Reviews
03-30-2010, 04:22 PM
Price: $300.00
Pros: light
Cons: none
Recommended? Yes
Comments: awesome
Mayfair_Jeeper
Mayfair_Jeeper's Reviews
02-10-2010, 09:52 AM
Price: $210.00
Pros: Nice price. Matt added some drain holes for me for nominal charge. Welds look solid
Cons: Lots of Weld splatter. This was an early production model and was prior to UFC being around.
Recommended? Yes
Comments: Product is solid. Matt is an awsome guy willing to assist in any way. Loves fabing, and will modify the product to make you happy. Made in the USA ain't bad either.
bgmadmxr
bgmadmxr's Reviews
01-19-2010, 01:44 PM
Price: $189.00
Pros: Price, design
Cons: none
Recommended? Yes
Comments: With all the other belly up skids being in the $350 to $400 range, the UCF skid is a screaming deal. Skid is very well made, welds are good. You need a BL, and a transfer case shifter bracket to make the install go smooth. Overall great product and great customer service.
Boodyrider
Boodyrider's Reviews
11-01-2009, 01:46 AM
Price: $1.00
Pros: integrated with the transmissions skid
Cons: none
Recommended? Yes
Comments: Single bellyup plate for both trans and Tcase protection, trans mount has it's own support
ThreadForumRepliesLast Post
Mopar WJ Transfer Case Skid Plate Skid Plates 28 04-26-2016 09:52 PM
Rusty's Offroad Transfer Case Skid Plate Skid Plates 6 03-14-2015 12:02 AM
warn Transfer Case Skid Plate for XJ Skid Plates 10 05-27-2012 03:36 PM
33 Engineering High Clearance Transfer Case Skid Plate Skid Plates 9 10-26-2011 09:02 AM
Rusty's Offroad XJ Transfer Case Skid Plate Skid Plates 5 06-02-2010 09:56 PM
