Notices
Teraflex oil pan skid plate Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Skid Plates Next Product
Rating:
Product Information
MSRP: $121.00
Average Price: $134.47
Manufacturer: Teraflex
Recommended?
Yes: 20 / No: 2
The Teraflex oil pan skid plate bolts into the transmission bell housing using existing hardware. No drilling is required, and a cutout is provided for access to the drain plug. Only fits 6 cyc engines.
None
Page 1 of 2 1 2 > Last »
five-0
five-0's Reviews
07-26-2013, 02:53 PM
Price: $130.00
Pros: strong. Everything lined up nicely. Fits as described
Cons: -All bolts and screws not provided!! Not a good alternative for a full skid, can still get snagged up on rocks.
Recommended? No
Comments: Pretty good skid, as far as oil pan skids are concerned.
My biggest issue is that not all the parts described in the instructions are actually provided. I ended up having to supplement with my own screws and bolts. Disappointing really, because teraflex is not a new company and should be organized enough.
cplacke
cplacke's Reviews
11-28-2012, 04:04 PM
Price: $125.00
Pros: Fit well, pre-finished
Cons: Exhaust manifold sometimes ratlles on it
Recommended? Yes
Comments: This is an inexpensive skid plate considering it portects one of the most vital systems on the Jeep. Install was easy, and the construction seems quality. Sometimes my exhaust manifold rattles on it, but that's not a huge concern.
codyjames
codyjames's Reviews
10-21-2012, 07:57 PM
Price: $40.00
Pros: Good cheap protection Will fit 4cyl motor with very light modification
Cons: For the price I can't find any Had to drill one additional hole for 4cyl jeep
Recommended? Yes
Comments: Got this 40.00 shipped when they went on sale. I have a 2.5l jeep and it says its only for the 4.0l jeeps. Turns out after adding one additional hole its a perfect fit for the 4cyl motor.
TexasTJ
No Longer DD
TexasTJ's Reviews
08-22-2012, 11:40 PM
Price: $40.00
Pros: Solid piece of equipment easy install protection
Cons: Vibrates on the flywheel box and sounds awful, I cut a 1" piece of rubber tubing down the middle and placed it flat inbetween the skid plate and the oil pan, no more rattle
Recommended? Yes
Comments: Install was very simple, just two bolts. I like it, except that it rattles really bad. But a simple piece of rubber tubing fixed it. Got it on sale for $40. I recommend.
FManansala
FManansala's Reviews
06-29-2012, 02:44 PM
Price: $24.00
Pros: ease of installation and access to oil pan bolt
Cons: bangs against oil pan sometimes
Recommended? Yes
Comments: need to put a piece of radiator hose rubber between skid and pan to eliminate rattling ......
other than that...perfect!!!
Delfire
Delfire's Reviews
06-12-2012, 11:13 PM
Price: $25.00
Pros: Easy Install
Cons: TeraFlex shipping fees
Recommended? No
Comments: TeraFlex offered this skidplate for $25 online. However they had a $16 shipping fee. I found it on EBay at the same price with no shipping fee.
The install was three bolts took me 5 minutes to install. Great so far.
2GPS4ME
2GPS4ME's Reviews
03-12-2012, 10:05 PM
Price: $45.45
Pros: Really inexpensive! 3/16" steel, very simple and practical design
Cons: For the price, none.
Recommended? Yes
Comments: Bought two of these on Ebay, and with combined shipping I paid $65.45 for the pair. This is so ridiculously inexpensive, it's not even funny.
On my 4.0, 5spd TJ, install time was 5 minutes. 2 lower trans bellhousing bolts and 1 dust shield screw, and it's in. Leaves ample room for an oil change. No, it's not going to protect the Jeep from a 2 story free-fall, but it will stop anything that tries to get in my oil pan.
CCWwrangler
CCWwrangler's Reviews
03-05-2012, 10:00 PM
Price: $132.00
Pros: saves your oil pan from being crushed
Cons: none
Recommended? Yes
Comments: its cheaper to buy a skid plate then to have to replace an oil pan
OregonVette
OregonVette's Reviews
06-03-2011, 10:51 AM
Price: $150.00
Pros: Good
Cons: Heavy good
Recommended? Yes
Comments: Decent
rikkards
rikkards's Reviews
05-09-2010, 02:09 PM
Price: $130.00
Pros: Solid built, pretty straightforward install (but caveats exist)
Cons: Lousy customer service.
Recommended? Yes
Comments: They have changed the look of this skid plate compared to what is shown above. It more resembles the nth Degree/AEV model
I have a 98 TJ 4.0L and found that the driver side engine mount hole had no thread, but looked like it should be the larger bolt which they mention may be needed. I emailed the company for some guidance on whether I should have to tap it or not. It has been two weeks and have received no response. I went ahead and tapped the hole and looks like it did the job.
At the same time there is a washer that is supposed to go between the back of the skid plate and the bell housing. This washer is used to stop the skid plate from pushing the inspection plate on the bell housing into the flywheel . Since they only provide one washer that is big enough for the bolts, I had to go out and buy another one to balance it out since there are two bolts involved. I also asked about this and received no response.
Instructions are relatively thorough however it leaves a lot of questions especially if you experience what I did. Like why is there only one washer? Is it enough? Is the washer required if you have larger bolts which I did. (The variances in bolt size between early and late model TJs is uber stupid but I digress)
BTW, this is the 2nd 98 TJ I have heard of that had to have the driver side hole tapped since there was no thread.
98VolsTJ
98VolsTJ's Reviews
04-29-2010, 10:46 PM
Price: $24.00
Pros: very cheap price. well made
Cons: none
Recommended? Yes
Comments: bought for very little. havent installed it yet.
tekach
tekach's Reviews
04-17-2010, 01:39 PM
Price: $113.00
Pros: Does it's job, tough
Cons: none
Recommended? Yes
Comments: A must have. Has lots of deep scratches that would otherwise end on oil pan :-)
burger3026
burger3026's Reviews
01-19-2010, 09:51 AM
Price: $100.00
Pros: easy bolt on
Cons: none
Recommended? Yes
Comments: learned i needed this a little to late
Nicho
Nicho's Reviews
01-06-2010, 05:30 PM
Price: $115.00
Pros: Sturdy
Cons: None
Recommended? Yes
Comments: Good Insurance
limeking
limeking's Reviews
11-19-2009, 10:40 AM
Price: $1,111.00
Pros: heavy duty and easy to install
Cons: not a fan of the mounting points, all wieght is on the motor mounts
Recommended? Yes
Comments: scared up but no damange to it.
ModernJ
ModernJ's Reviews
09-26-2009, 08:11 PM
Price: $113.00
Pros: fits lots of different Jeeps easy install. No drilling uses factory holes
Cons: none
Recommended? Yes
Comments: Easy install just four bolts in existing bell housing and engine.Easy to follow instructions
acrijos
acrijos's Reviews
04-03-2009, 01:46 AM
Price: $1.00
Recommended? Yes
Comments: Well designed and constructed piece of armor. I have used it for the past 10 years with no problems.
elpound
elpound's Reviews
03-26-2009, 02:07 PM
Price: $98.00
Recommended? Yes
Comments: this skid plate bolts right up real easy. I am sure it will save my oil pan from damage
jt97tj
jt97tj's Reviews
03-24-2009, 09:01 PM
Recommended? Yes
Comments: Works well and cheap. What sucks is that I need to leave 75 characters for the review,,,fing stupid waste of time.
Poobah
Poobah's Reviews
07-09-2008, 06:40 PM
Recommended? Yes
Comments: Actually I have the Belly Up Skid plate...it's very nice...gain clearance...good protection...
ThreadForumRepliesLast Post
Skid Row JP - 0009 Engine & Transmission Skid Plate Skid Plates 4 04-01-2013 09:25 PM
Skid Row Lower Control Arm Skid Plate Skid Plates 12 10-29-2012 11:18 AM
Skid Row Radiator Skid Plate-TJ Skid Plates 16 06-02-2012 12:18 AM
skid row Jeep TJ Wrangler Gas Tank Skid Plate Skid Plates 3 05-25-2010 06:49 PM
Skid Row Offroad Transfercase Skid plate Skid Plates 5 03-17-2009 11:51 AM
