Solid Axle Industries Differential Cover Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Skid Plates Next Product
Rating:
Product Information
MSRP: $100.00
Average Price: $78.33
Manufacturer: Solid Axle Industries
Recommended?
Yes: 4 / No: 1
Features
• Lifetime warranty
• Thick nodular iron casting with reinforcing ribs.
• Fully machined seal surface.
• Machined bolt bosses for maximum clamping force.
Benefits
• Adds rigidity to weak factory housings
• Replaces weak factory stamped steel covers
• Large diameter fill plug for easy fluid replacement
• Higher fill plug location for increased fluid capacity
• Dense material quiets down noisy lockers.
None
bajabronco
bajabronco's Reviews
06-24-2013, 09:57 PM
Price: $65.00
Pros: Seems to be sturdy and "solid"
Cons: Some diff cover holes do not line up.
Recommended? No
Comments: I have both a front solid diff cover for the D30 and rear for the 8.25 on my Cherokee. The solid cover for the Chrysler 8.25' s bolt holes did not line up. I had to bore out the holes with a drill so they would actually line up. The D30 had no problems, lined up fine. Just be aware that if you get the cover for the 8.25 you will need to mess with the cover to make it fit.
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Reviews
07-27-2010, 12:10 PM
Price: $70.00
Pros: inexpensive, stout
Cons: none
Recommended? Yes
Comments: For $70 and a lifetime warrenty this thing cant be beat. Its a tank that takes tons of abuse. I would highly recommend and own 4 of these right now.
mecompco
www.midcoastjeep.com
mecompco's Reviews
07-30-2008, 03:36 PM
Pros: Heavy duty, relatively inexpensive.
Cons: Finish on the sealing surface could be improved.
Recommended? Yes
Comments: I've got the SOLID cover on my 8.8 and it works great. I've dragged it over numerous rocks with no damage or peeling up. The finish is nice, but they could have machined the mating surface of the cover a bit more cleanly. We cleaned up the surface a bit with a fine file prior to installing. Used a LubeLocker gasket and it has been leak free for over a year now.
AZTJ02
AZTJ02's Reviews
06-21-2008, 12:05 PM
Pros: good fit, heavy duty, reasonably priced, looks good
Cons: none that I can see
Recommended? Yes
Comments: I have drug these over rocks several times and set the jeep down on these a few times. The fins are about rubbed off on the bottom side, but I am very impressed with these. And they are reasonable priced compaired to others out there!
tgrt
tgrt's Reviews
05-01-2008, 09:44 AM
Price: $100.00
Recommended? Yes
Comments: They're strong and do the job great; in fact I hit the front one on a rock really good and there was no damage. My only issue was the difficulty in getting at the bolts for installing and uninstalling.
ThreadForumRepliesLast Post
Solid Dana 44 cover Differential Guards 3 11-24-2016 08:25 AM
Solid Dana 30 Cover Differential Guards 26 02-16-2016 08:03 PM
Riddler Differential cover Differential Guards 72 06-21-2015 09:57 PM
Solid Dana 35 Cover Differential Guards 9 05-13-2013 02:28 PM
TKH Fab Dana 30 Differential Cover Differential Guards 3 09-18-2007 09:04 AM
