Go Back JeepForum.com > Reviews > Armor > Skid Plates > Skid Row Lower Control Arm Skid Plate
1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with FullIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Lockers FREE SHIPPING Excellent Prices
Skid Row Lower Control Arm Skid Plate Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Skid Plates Next Product
Rating:
Product Information
MSRP: $129.99
Average Price: $103.11
Manufacturer: Skid Row
Recommended?
Yes: 10 / No: 0
For Jeeps with Dana 30 or 44 Front Axle and Coil Springs
-1997-2006 TJ Wrangler, including Rubicon and Unlimited
-1984-2001 XJ Cherokee,
-1986-1992 MJ Comanche,
-1993-1998 ZJ Grand Cherokee
These skid plates are completely bolt-on and protect the mounting tabs of the lower control arms on the Dana 30 or 44 front axle. Why does this matter? Simply because the mounting tabs are among the first parts to hit the rocks and they are pretty easily damaged. They're made of surprisingly thin material and we've seen and heard of them being literally torn off while wheeling.
A set includes one skid plate for the left side and another for the right, as well as all mounting hardware and easy to follow instructions.
Another benefit to having bolt-on skids is that you can move them from one vehicle to another. For example, if you sell your Jeep or it gets wrecked, the skids can be removed and put on your next Jeep.....if it's one of the models they fit, of course. We've had several customers do this and they LOVED not having to pay someone to weld on another set.
These skid plates are built to take a beating! They are made from 1/4" steel plate and use custom-made, grade 5 U-bolts and carriage bolts to mount them to the axle. They fit tight against the sway bar mounting tab on one side and up against the axle housing on the other side. The are also attached using the control arm mounting bolt so there's no way they'll rotate.
These skids are designed to fit with stock or aftermarket control arms and will work with virtually any aftermarket track bar. We've redesigned the passenger side skid to create more clearance for the larger track bars that several companies are now making.
Milton75
Milton75's Reviews
06-30-2010, 07:42 AM
Price: $25.00
Pros: They will save you on rough terrain
Cons: Bolts have to be cut down after installation
Recommended? Yes
Comments: These skids are very easy to install. They're perfect for no welders. The only down side is you have to cut off the bolt excess after installation. I would definitely recommend these skids.
PackDude
PackDude's Reviews
05-28-2010, 09:16 PM
Price: $125.00
Pros: Thick steel
Cons: Cannot think of any now
Recommended? Yes
Comments: These Skid Row control arm skid plates seem quite cool. I haven't had to test them out yet to see if they really work, but I'm sure they will do a great job.
weasel796
weasel796's Reviews
05-25-2010, 06:51 PM
Price: $138.00
Pros: protects lower control arms
Cons: haven't discovered any yet
Recommended? Yes
Comments: These look like they will hold up very well if they do hit any rocks, They also make the jeep look cleaner underneath
OAS
OAS's Reviews
03-30-2010, 10:22 PM
Price: $115.00
Pros: very thick steel plate. easy to install (hell, if I can do it YOU can do it)
Cons: wish it covered the entire bottom of the control arm. other than that, none.
Recommended? Yes
Comments: Works with stock or aftermarket control arms. a little pricey, but well designed and very heavy duty!
Plus no welding! Can be transferred to your next Jeep.
Zakman
A locked & armored Sport
Zakman's Reviews
02-22-2010, 08:37 AM
Price: $125.00
Pros: 3/16" plate, easy install, great protection for a stock set-up.
Cons: Had to open up control arm bolt due to PC.
Recommended? Yes
Comments: Nice, simple product. Ease of mind protection for those LCA mounts. Esp for those on a stock set-up.
MoCab
MoCab's Reviews
12-05-2009, 02:02 AM
Price: $100.00
Pros: bolt on, very stout
Cons: uses control arm bolt with requires 130 Ft/LB torque to replace
Recommended? Yes
Comments: very stout and provide excellent jack point for front axle.
Thunderstrike
Thunderstrike's Reviews
06-21-2008, 08:03 PM
Price: $120.00
Recommended? Yes
Comments: Skid Row's LCA skid save me several times. I like this design better than the weld on because it's more robust and provides solid protection. Wish they had one for rear LCA.
Pillswoj
Pillswoj's Reviews
05-10-2008, 11:51 AM
Price: $129.99
Recommended? Yes
Comments: Bolts on using the lower control arm bolt and clamps over the axle tube. Looks like it will protect the mounts from rocks but won't know until I hit them a few times
XTC Jpr13
XTC Jpr13's Reviews
05-08-2008, 09:17 PM
Price: $50.00
Recommended? Yes
Comments: Save my control arms from damage many times. one of my most used skids. Takes a beating ans still in great shape!
valeech
valeech's Reviews
08-29-2006, 06:15 AM
Pros: Very easy install / direct bolt on / no welding
Recommended? Yes
Comments: These control arm skids are a must have if you plan on doing any rock crawling. They are a nice bolt on option to protect your control arms from taking a beating. These were installed in under 3 minutes with a simple set of sockets and crescent wrenches.
I have had mine on for just over a year and they have taken a beating. The powder coating hasn't held up for obvious reasons, but its better the paint goes then having to have a new control arm mount welded on and a new control arm installed...
ThreadForumRepliesLast Post
Skid Row Gas Tank Skid Plate (TJ / XJ) Skid Plates 9 08-24-2010 12:26 PM
Skid Row JP - 0009 Engine & Transmission Skid Plate Skid Plates 2 01-20-2010 11:40 AM
Skid Row Front Skid Plate Skid Plates 2 06-27-2009 01:25 PM
Skid Row Offroad Transfercase Skid plate Skid Plates 5 03-17-2009 11:51 AM
skid row Jeep TJ Wrangler Gas Tank Skid Plate Skid Plates 2 08-16-2007 11:39 PM
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
