Go Back JeepForum.com > Reviews > Armor > Skid Plates > Skid Row Gas Tank Skid Plate (TJ / XJ)
TJ 5.25" Speaker Adapters - NalinMFGTruck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Skid Row Gas Tank Skid Plate (TJ / XJ) Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Skid Plates Next Product
Rating:
Product Information
MSRP: $289.99
Average Price: $210.00
Manufacturer: Skid Row
Recommended?
Yes: 9 / No: 0
1997-2006 Jeep TJ Wrangler including Rubicon and Unlimited
Our new gas tank skid plate is a cover-up style skid plate that bolts over the factory skid plate. This skid plate simply bolts on right over the original so you don't have to drain your gas tank and remove it. That makes the installation a snap! Normal installation time is less than an hour. They are made from 3/16" thick steel on the bottom and sides, and come powder coated in semi-gloss black. We have one installed on our project TJ Rubicon with a D44 rear axle and it works great!
Please note that 1997-1998 TJ's will require two holes to be drilled while 2004and newer models require drilling one hole. Unlimited models require drilling of two holes.
1984-2001 Jeep XJ Cherokees
These skids are made from 3/16" thick steel on the bottom and sides, are powder coated, and are completely bolt-on. They are designed to work with hitches as you can see in the picture above left. If you don't already have a hitch you will need to provide the nut plates that fit inside the chassis. You can get them from your friendly Jeep dealer. On 1997-2001 models you'll only need the driver's side nut plate. We just got a set from our local dealer.
Please note: We've recently learned that our gas tank skid plate is not compatible with the Rusty's Offroad Hitch due to its width.
Please note that there is a difference between the 1984-1996 model and the 1997-2001 model.
The 1984-1996 models have a steel gas tank, while the 1997-2001 models have a plastic gas tank that hangs closer to the ground.
greedyg76
greedyg76's Reviews
08-24-2010, 12:26 PM
Price: $100.00
Pros: Heavy Duty Easy install
Cons: Exhaust interference
Recommended? Yes
Comments: I have this skid on my 2000 XJ and this thing is burley. The install was fairly straight forward and took 40 minutes with two guy, this includes removal of the tow hitch. The only issue I encountered was interference with the stock tail pipe. With the skid in place, the tail pipe rests right against it and rattles like a freight train. Cut the pipe off right behind the muffler and added a turn down, problem solved
UCTJ
UCTJ's Reviews
11-29-2009, 03:34 PM
Price: $325.00
Pros: Easy to install.
Cons: None.
Recommended? Yes
Comments: Good fitment, easy install.
barflyfisherman
barflyfisherman's Reviews
09-03-2009, 05:58 AM
Price: $175.00
Pros: Made of US fabricated steel, no China OEM sheet metal.
Cons: Doesn't come in colors other than black
Recommended? Yes
Comments: All of the holes aligned perfectly. Still had to use power tools. Instructions had pictures for those of us who don't read so well. Large crayon sized check boxes kept track where we were in the process.
dagen
dagen's Reviews
11-16-2008, 11:11 AM
Price: $289.99
Recommended? Yes
Comments: fairly easy to install. good thick steel plates. only had to buy the "reinforcement nut plate" for the driver side from the dealer.
had to pull bumper to fit nut plate in.
badsparky
Newbie
badsparky's Reviews
07-08-2008, 02:51 PM
Price: $250.00
Recommended? Yes
Comments: Very nice - product takes a beating, doesn't show any signs of weakness. Its a must have on any Jeep!
bartlanz
Been There, Done That
bartlanz's Reviews
06-29-2008, 07:14 PM
Price: $200.00
Recommended? Yes
Comments: Very nice, requires drilling, more than adiquit protection, nice feature that it will slip over the factory skid
Pillswoj
Pillswoj's Reviews
05-10-2008, 11:46 AM
Price: $239.99
Recommended? Yes
Comments: Skid went on easily without haveing to drop the tank, still need to put a jack under it to get the front mounts to their highest position.
av8tr
av8tr's Reviews
04-29-2008, 02:31 PM
Price: $260.00
Recommended? Yes
Comments: This was an interesting install especially with a hitch. I had a little problem getting the heat shield to fit right, had to do some modification. Definately a one man job, easier with two.
MaddieXJ
MaddieXJ's Reviews
04-20-2008, 12:12 PM
Price: $50.00
Recommended? Yes
Comments: Tough Skid, No Problems
ThreadForumRepliesLast Post
EMP Gas Tank Skid Plate Skid Plates 3 02-10-2010 08:54 AM
Mopar Fuel Tank Skid Plate Skid Plates 10 02-08-2010 01:07 AM
Warn Gas Tank Skid Plate Skid Plates 7 12-14-2009 10:48 PM
Gen-Right Crawler Gas Tank Skid Plate TJ Skid Plates 4 07-04-2008 12:31 AM
skid row Jeep TJ Wrangler Gas Tank Skid Plate Skid Plates 2 08-16-2007 11:39 PM
Glock Forum
