Notices
Skid Row Engine & Transmission skid Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Skid Plates Next Product
Rating:
Product Information
MSRP: $325.00
Average Price: $231.48
Manufacturer: Skid Row
Recommended?
Yes: 54 / No: 0
These skid plates are made from 1/4" thick steel and reinforced with 1/4" angle to provide beefy protection for your engine's oil pan and your transmission. Installation is quick and easy and only requires drilling of two holes to attach the rear of our skid plate to whatever transfer case skid plate you are using. There is even an oil drain hole so that you can perform your regular maintenance without removing the skid plate. Take a look at the pictures below!
We provide carriage bolts to attach our skid plate to the transfer case skid plate. Why not use counter sunk bolts? Simply because we've had problems removing counter sunk bolts after they've been run over rocks a few times. Metal always seems to get pushed into the recessed hex. Also, once a little rust gets into the threads, getting enough torque to break them loose without stripping out the hex can be VERY difficult to say the least! We've had to drill countersunk bolts out in the past and can't say we were happy about it. By using carriage bolts the bottom is smoother than with a hex head bolt and there is a nut on top that you can get a wrench or socket onto. We've found that we like carriage bolts much better.
1997-2006 Jeep TJ Wranglers
including Rubicon and Unlimited
with Long Arm Suspensions
None
Page 3 of 3 1 2 3
asa
asa's Reviews
04-23-2008, 08:26 PM
Recommended? Yes
Comments: great for free.
MaddieXJ
MaddieXJ's Reviews
04-20-2008, 01:11 PM
Price: $50.00
Recommended? Yes
Comments: Tough Skid, No Problems!
WillyB
110K miles and counting!
WillyB's Reviews
04-18-2008, 05:36 PM
Price: $250.00
Recommended? Yes
Comments: This thing's a lifesaver when you're running 33s. I abuse this thing and all it requires is a little touch up paint. Easy install, but it makes changing your tranny fluid a pain.
BlackBellamy
BlackBellamy's Reviews
04-16-2008, 03:47 PM
Recommended? Yes
Comments: .
rmagers
rmagers's Reviews
04-15-2008, 09:29 PM
Recommended? Yes
Comments: Works well, easy install.
Asored2000
Asored2000's Reviews
04-15-2008, 07:30 PM
Price: $245.00
Recommended? Yes
Comments: Love it
FarFire70
FarFire70's Reviews
04-12-2008, 11:56 AM
Price: $230.00
Recommended? Yes
Comments: Great product. I've already hit it a few times with no damage. I specifically went with Skid Row because of the quality and that it will bolt up to the 33 Eng. Tummy Tuck.
bluerubicon06
bluerubicon06's Reviews
04-09-2008, 08:01 PM
Price: $240.00
Recommended? Yes
Comments: no brainer to install, solid performer
FunkyCold
FunkyCold's Reviews
04-03-2008, 03:11 AM
Price: $245.00
Recommended? Yes
Comments: easy bolt on
TJ 4 the Boxers
TJ 4 the Boxers's Reviews
03-23-2008, 10:13 AM
Price: $175.00
Recommended? Yes
Comments: Bounced off a few rocks with no problems.
rastadog
rastadog's Reviews
03-10-2008, 04:54 PM
Price: $245.00
Recommended? Yes
Comments: Full coverage, tough as nails and easy to install. What's not to love?!?
Manateu
Manateu's Reviews
11-30-2007, 08:39 PM
Pros: Quality Contruction and Ease of install
Cons: None so far
Recommended? Yes
Comments: I just installed this product recently. On a trip to Badlands it took some hard hits and walked away with only small scratches. Although this is not a sexy upgrade, it does provide exceptional protection of the oil pan, headers, and transfer case. I would recommend checking out http://www.4x4xplor.comfor a great write up with pictures.
barry1me
barry1me's Reviews
07-05-2007, 11:18 AM
Pros: ROBUST!!! gives you more protection then any other skid
Cons: heavy!
Recommended? Yes
Comments: To say this skid protects the undercarriage is an understatement. This thing is incredible. Installation is not that bad, as long as you can read instructions (pun intended towards myself) I included a few tricks to help with installation if your a one man show. Install with pics. If your looking for the ultimate protection this skid is the one to buy. It protects the front of the oil pan all the way back to the transfer case. Very tough
Page 3 of 3 1 2 3
ThreadForumRepliesLast Post
Factory front skid and rear gas tank skid OEM Skid Plates 26 01-24-2016 10:41 AM
Skid Row JP - 0009 Engine & Transmission Skid Plate Skid Plates 5 12-23-2015 06:59 PM
Skid Row Lower Control Arm Skid Plate Skid Plates 12 10-29-2012 10:18 AM
skid row Jeep TJ Wrangler Gas Tank Skid Plate Skid Plates 3 05-25-2010 05:49 PM
skid row engine skid for long arm lift Skid Plates 6 03-25-2009 10:45 AM
