Go Back JeepForum.com > Reviews > Armor > Skid Plates > skid row engine skid for long arm lift
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
skid row engine skid for long arm lift Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Skid Plates Next Product
Rating:
Product Information
MSRP: $325.00
Average Price: $267.49
Manufacturer: skid row
Recommended?
Yes: 6 / No: 0
These skid plates are made from 1/4" thick steel and reinforced with 1/4" angle to provide beefy protection for your engine's oil pan and your transmission. Installation is quick and easy and only requires drilling of two holes to attach the rear of our skid plate to whatever transfer case skid plate you are using. There is even an oil drain hole so that you can perform your regular maintenance without removing the skid plate. Take a look at the pictures below!
We provide carriage bolts to attach our skid plate to the transfer case skid plate. Why not use counter sunk bolts? Simply because we've had problems removing counter sunk bolts after they've been run over rocks a few times. Metal always seems to get pushed into the recessed hex. Also, once a little rust gets into the threads, getting enough torque to break them loose without stripping out the hex can be VERY difficult to say the least! We've had to drill countersunk bolts out in the past and can't say we were happy about it. By using carriage bolts the bottom is smoother than with a hex head bolt and there is a nut on top that you can get a wrench or socket onto. We've found that we like carriage bolts much better
Which one fits?
To determine which model skid plate you need simply take a measurement from the engine's oil drain plug to the leading edge of the transfer case skid plate. You'll get a measurement of approximately 16" or 20".
Please Note: Fits 6 cylinder models ONLY.
Also, if you have an aftermarket exhaust header that goes under your engine or transmission, our skid plate may not fit properly. An example would be the Borla exhaust header for 1997 model TJ's.
If you're unsure, it's best to contact us and ask.
jetter
jetter's Reviews
03-25-2009, 11:45 AM
Price: $279.95
Recommended? Yes
Comments: Easy install and great protection. Doesn't interfere with front control-arms or drive shaft.
smamas
smamas's Reviews
01-20-2009, 06:11 PM
Price: $250.00
Recommended? Yes
Comments: This skid is an easy install, and is solid as a rock. I have the RE long arm and it bolts right up to the front of the RE trans mount. Definitely worth the money.
UTmike
UTmike's Reviews
10-16-2008, 11:47 PM
Price: $240.00
Recommended? Yes
Comments: Heavy duty produck. 1/4" steel, with reinforced sides. It bolts up to the motor mounts rather than the control arms
ian0341fo
ian0341fo's Reviews
07-11-2008, 03:42 PM
Price: $310.00
Recommended? Yes
Comments: This thing is BEEFY. The install took a little bit of working, just because of the tabs that hold the arms in place. It covers, very effectively, the transmission pan, and engine oil pan. I have banged this up pretty hard, and it is none the worse for wear.
bartlanz
Been There, Done That
bartlanz's Reviews
06-29-2008, 07:13 PM
Price: $200.00
Recommended? Yes
Comments: Nice Product, a bit dificult to install, takes two people, Once installed it is stiff and you can jack you jeep from it
jneal
Nice....Keep Wheelin!
jneal's Reviews
04-29-2008, 09:58 AM
Price: $325.00
Recommended? Yes
Comments: tried rusty's but it didnt fit. if you have a long arm lift and want an engine skid, nothing could be simpler to install and provide better protection than this skid
ThreadForumRepliesLast Post
Skid Row Engine & Transmission skid Skid Plates 46 05-23-2011 11:51 PM
Factory front skid and rear gas tank skid OEM Skid Plates 9 02-07-2010 10:31 AM
Skid Row JP - 0009 Engine & Transmission Skid Plate Skid Plates 2 01-20-2010 11:40 AM
Skid Row Offroad Transfercase Skid plate Skid Plates 5 03-17-2009 11:51 AM
skid row Jeep TJ Wrangler Gas Tank Skid Plate Skid Plates 2 08-16-2007 11:39 PM
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
