Go Back JeepForum.com > Reviews > Armor > Skid Plates > Savvy Offroad - Gas Tank Skid
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Savvy Offroad - Gas Tank Skid Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Skid Plates Next Product
Rating:
Product Information
MSRP: $319.00
Average Price: $271.67
Manufacturer: Savvy Offroad
Recommended?
Yes: 18 / No: 0
Company Website: http://www.savvyoffroad.com
- 3/16" 6061 T-6 - Dual height mounts - Installs with or without a body lift - Corrosion resistant materials - Weighs 32 pounds complete - Form fit to the tank Our skid is designed for the Jeep Wrangler 1997-2006 in both the Unlimited and TJ models. To ensure a painless installation, we have supplied all needed fasteners including new crossmember hardware, tie wraps, and push in panel fasteners to re-install the plastic wheel well liners.
This innovative skid is constructed of 3/16's thick 6061 T6 aircraft grade aluminum alloy to provide high strength with light weight. Weighing in at 32 pounds, you only suffer a 4 pound weight penalty when compared to the 03 and up factory skid. The dual height mounting flanges are made from high quality HRPO steel that has been laser cut and clear zinc plated for corrosion resistance. Whether installed at the lower height with no body lift or the raised position when used with a min. 1" body lift, the skid provides the maximum clearance possible. Our unique stainless steel tank straps keep the tank secured in the skid to protect your delicate emissions and fuel lines from contact with the bottom of the tub. We combined rolled front and back corners with a formed dimple with gradual transitions for the fuel sump to reduce hang-ups on the trails. As with all Savvy Off Road products these are designed for extreme off road use only.
RaggedOleMan
Student of Jeep stuff...
RaggedOleMan's Reviews
11-21-2011, 01:46 PM
Price: $50.00
Pros: Easy to install, just remember to do it when your gas tank is nearly empty! And be very careful unhooking the fuel pump leads... Light weight, and it gave me 1-3/4" additional ground clearance as opposed to the stock skid.
Cons: Can't think of any "con's".
Recommended? Yes
Comments: I got this directly from Blaine Johnson in trade for my "helper" labors on a few projects he was working on. This particular skid was an early prototype of Savvy's. Easy to install, it's lightweight and gave me an additional 1-3/4" of ground clearance. No maintenance...it does what it's supposed to do and doesn't give me any grief. I like that...
greenglazier
greenglazier's Reviews
11-12-2011, 11:09 PM
Price: $329.00
Pros: great pruduct,really easy to install,great design.
Cons: none
Recommended? Yes
Comments: i waited so long to get this skid but it was worth the waiting installation was really easy and straight foward great product dont even think buying somewhere else.
mike_dippert
hodophobic
mike_dippert's Reviews
10-26-2011, 10:15 AM
Price: $319.00
Pros: Aluminum = light, adjustable height, very strong.
Cons: tons of bolts
Recommended? Yes
Comments: I want to keep my LJ light. When I heard mrblaine designed this, I didn't doubt it wouldn't be just as strong as the Rokmen I had on my old Jeep, but at the same weight as the factory skid. It comes with new tie straps for the tank. It has 2 install levels, depending if you have a 1.25" BL or not. The only problem is the tolerances are so tight that it's difficult to get all the bolts started. Get a powered ratchet if you're changing the levels, it'll save you a lot of time.
Richierich1105
Richierich1105's Reviews
06-03-2011, 05:26 AM
Price: $330.00
Pros: Lightweight compared to steel more clearance especially with a body lift and there's two sets of mounting holes if you don't have a body lift but decide to do one later
Cons:  None
Recommended? Yes
Comments: Awesome craftmanship all the holes lined up perfect. getting the tank in was the only hard part but with a lill grease it went right in
mpoo1083
mpoo1083's Reviews
04-21-2011, 09:27 PM
Price: $1.00
Pros: everything about it
Cons: nothing at all
Recommended? Yes
Comments: installed this along with UCF aluminum skids and body lift/motor mount lift. installed it at its highest adjustment and love it. it looks great and can take a beating. first time out with it installed, the rear of the jeep dropped about 3-4 feet onto a pointed rock and you have to look extremely hard to see where it hit. this will never be removed from the jeep and if i ever had to get another one, this would be it
UncleWilson
Because I can...
UncleWilson's Reviews
04-18-2011, 09:20 AM
Price: $330.00
Pros: Easy Assembly, Good Looking Product, Light Weight, Easy Instilation. Also, Customer Service from these guys is great. Phone calls and PM's answered very quick.
Cons: Can't think on any
Recommended? Yes
Comments: Wish I had gotten it earlier!
robbijer
robbijer's Reviews
03-28-2011, 12:06 PM
Price: $350.00
Pros: Aluminium and great fit
Cons: None yet
Recommended? Yes
Comments: I did not receive instructions but was able to get them from Savvy's web site. Install went pretty well, only difficult part is disconnecting all of the fuel, and smog lines. I have not (tested) the skid yet but I expect it will hold up. I also have a body lift so I gained 1" of ground clearance under the new skid.
dwish
Intrinsically Inimical
dwish's Reviews
03-16-2011, 06:34 PM
Price: $300.00
Pros: Very strong, heavier than stock skid (which is weird, because it's made out of aluminum...but it is MUCH thicker than the stock skid, and MUCH stronger). All hardware is included. Perfect fit. Packaged well.
Cons: No smokescreen option to harass tailgaters.
Recommended? Yes
Comments: You can tell right away that this is a quality skid plate. I have heard that Savvy would not put out anything they didn't have complete confidence in. As soon as I opened the box, I believed it. My 2004 gas tank fit right in. "You may have to push it down with some authority ensure the tank is fully seated in the skid." I thought that line was pretty funny. The directions are very thorough and helpful. Plenty of color pictures to guide you through the removal of the old tank and skid, and even more to guide you through putting your new Savvy skid on. I only have one complaint -- I didn't get a sticker with my skid to proudly display Savvy. :-(
jcook793
Hi Mom
jcook793's Reviews
02-05-2011, 10:52 PM
Price: $269.00
Pros: It's the best skid plate ever made
Cons: It will outlast my Jeep
Recommended? Yes
Comments: This is probably my favorite addition to the Jeep. That is a weird thing to say about a gas tank skid.
robert_hollis
The Silver Squirrel
robert_hollis's Reviews
01-03-2011, 05:31 PM
Price: $300.00
Pros: Slick design. Sturdy. Adjustable height.
Cons: One size fits all design. No directions.
Recommended? Yes
Comments: I think I paid less than list price, as I was ordering a lot of Savvy stuff at the time.
I like this skid a lot. It's a good design, and not too hard to install. I would highly recommend it.
My only complaint about it is the fact that it's a one size-fits-all skid. That's both a pro and a con in my mind. I would have rather had a one piece skid, but I see why Savvy made this one the way they did.
I gained a huge amount of clearance with this skid, and feel like my gas tank is much better protected than it was before.
glockster
glockster's Reviews
11-21-2010, 11:08 PM
Price: $300.00
Pros: more clearance, stronger, easy install
Cons: none
Recommended? Yes
Comments: Very well designed product. It allows more clearance with a body lift than any other GTS I am aware of. Installation was straight forward and everyything fit with no surprises. All new hardware is included for those that live in the rust belt. No worries if some fasteners are broken or stripped during removal.
jeepwrangler97
Wheel Weber
jeepwrangler97's Reviews
07-26-2010, 10:47 PM
Price: $280.00
Pros: Lightweight, no rust worries, strong, tight fit, much more clearance.
Cons: None that I can think of
Recommended? Yes
Comments: I needed more clearance for my 8.8 and I have more room between the diff and gas tank now. I also installed a 1"BL with mine and gained more clearance, great skid, great fit. I haven't had it wheeling yet, but doubt I will have any troubles.
SuperWade2
More Money than Brains
SuperWade2's Reviews
04-16-2010, 01:28 PM
Price: $320.00
Pros: Light Weight, Better Clearance
Cons: NONE, it's nearly Perfect
Recommended? Yes
Comments: Love It!
ElConq
ElConq's Reviews
03-29-2010, 11:31 AM
Price: $319.00
Pros: Low profile, Lightweight when compared with steel skids
Cons: none at the moment
Recommended? Yes
Comments: This is an easy install. Plenty of hardware. Clear and well written instructions.
Of course it helps that on the 1999s all of the fuel & electrical connections are in the drivers rear wheel well. No need to drop the tank part way to remove the connections on top of the tank as in later year models.
'Rust Belt' jeeps will need plenty of PB on the front 3 bolts. I sprayed every other day for the week prior and still had 1 of the 3 seized frum rust. I ended up lowering the tank a bit to open a gap to access the bolt and used a mini hacksaw to remove the bolt. The rear 4 were a easy to access.
dendrophobe
Eat. Sleep. Jeep.
dendrophobe's Reviews
12-29-2009, 07:00 PM
Price: $279.00
Pros: Lightweight, well built, tough, looks awesome
Cons: None
Recommended? Yes
Comments: I've never bought a product for my Jeep that was better made, fit better, or gave such piece of mind as this skid. If you manage to make it fail (which you won't) they'll replace it. The tolerances are very tight, it's very tough, and it saves around 2" of clearance over stock. And with the aluminum weight, it's no heavier than the stock skid!
theducksguts
no whiners!
theducksguts's Reviews
11-26-2009, 10:00 AM
Price: $265.00
Pros: Really Light Weight, Stout, takes a serious beating. Rust resistant. Easy install, cleans up well. Two settings for jeeps with or without body lifts. Allows extra clearance. Looks great.
Cons: I honestly can't think of any. Maybe that it's not free?
Recommended? Yes
Comments: I bought the Savvy Skid because I live in WI/MN and rust resistant makes sense for me. I liked the fact that it was light weight and that also had me interested.
I waited a while until other early adopters had tested theirs out. It takes the rocks really well, and the aluminum kind of deadens the impact sound and rattle which is nice too. It has held up to some serious punishment.
Boodyrider
Boodyrider's Reviews
11-01-2009, 01:00 AM
Price: $270.00
Pros: Light weight, decent price, good protection
Cons: not coated
Recommended? Yes
Comments: Full replacement gas tank skid. I got 4 gallons capacity back in my tank when I lost the deformed stock tank 'skid'. Weighs FAR less than steel options, only about 5 pounds over stock. Easy install. Wish it were available coated, but it's not like aluminum is gonna rust. Nice not to have to repaint scrapes after every trip. Seems at least as strong as any steel skid.
Russ Chung
Russ Chung's Reviews
10-27-2009, 11:55 PM
Price: $279.00
Pros: Lightweight and very durable. Also looks great.
Cons: None noted.
Recommended? Yes
Comments: The main selling point of this gas tank skid is that it is made of T6061 Aluminum, so it weighs only four pounds more than the factory gas tank skid, yet it is much stronger than the factory skid. Other steel gas tank skids often weigh 30 pounds more. I've had it on several black diamond trails (John Bull, Nightmare Gulch, Last Chance Canyon) and although there are some scratches, there are no dents.
ThreadForumRepliesLast Post
JCR Offroad TC Belly Skid Skid Plates 2 07-31-2011 09:46 PM
Skid Row Gas Tank Skid Plate (TJ / XJ) Skid Plates 9 08-24-2010 12:26 PM
Factory front skid and rear gas tank skid OEM Skid Plates 9 02-07-2010 10:31 AM
Skid Row Offroad Transfercase Skid plate Skid Plates 5 03-17-2009 11:51 AM
skid row Jeep TJ Wrangler Gas Tank Skid Plate Skid Plates 2 08-16-2007 11:39 PM
Glock Forum
