Rusty's Offroad - Rusty's 1 inch Drop Crossmember Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Skid Plates Next Product
Rating:
Product Information
MSRP: $119.00
Average Price: $129.33
Manufacturer: Rusty's Offroad
Recommended?
Yes: 3 / No: 0
Company Website: http://www.rustysoffroad.com/
The Rusty's Crossmember is a direct replacement for those that have been beat and banged on rocks and stumps. Made of 3/16 steel, pre-drilled for easier installation of our engine - trans skid and our TC skid. It is also available with a 1 inch drop model for better driveline angles without loosing any ground clearance. If used in conjunction with our engine skid plate, new holes will need to be drilled. There is no change on the catalytic converter attachment and we actually recommend cutting that off. Black powder coated for durability.
None
Snoopi8321
Snoopi8321's Reviews
06-16-2011, 09:03 PM
Price: $119.00
Pros: no loss ground clearance, good budget alternative
Cons: it not a SYE
Recommended? Yes
Comments: little bit more expensive than a spacer drop kit but no lost ground clearance and not relying on spacers is worth the little extra. good alternative for those of us on a budget.
Climbit
Climbit's Reviews
10-13-2010, 05:00 AM
Price: $150.00
Pros: beefy, no loss of ground clearance
Cons: wanting to raise my transfer case back up, debating how to go about doing that.
Recommended? Yes
Comments: beefy, easy install, much better than stock. no loss of ground clearance.
I am now debating how to raise my transfer case back up without having to get a new crossmember. I'm thinking a taller isolator, or somehow modifying it to be higher up.
theducksguts
theducksguts's Reviews
09-27-2010, 03:42 PM
Price: $119.00
Pros: No loss of ground clearance, uses factory hardware, 3/16 steel, easy install, they send you everything you need, including modified transmission mount.
Cons: power coated so you can't do your own finish on it, uses modified transmission mount, stock mount will not work, doesn't hold up to rocks, transfer case sits lower, might not work with your T-case skid.
Recommended? Yes
Comments: SYE would be better but this is a good budget alternative to dropping your cross member using washers or drop blocks. You don't lose any ground clearance over the factory unit. Install is easy, I did it by myself in about 1.5 hours.
Although... It doesn't hold up to rocks very well.
ThreadForumRepliesLast Post
Rusty's Offroad XJ Transfer Case Skid Plate Skid Plates 6 07-07-2017 06:15 AM
Rusty's Offroad - Rusty's XJ Engine/Tranny Skid Plate Part # RA-JS11-XJ Skid Plates 2 07-07-2017 06:03 AM
Rusty's Offroad Transfer Case Skid Plate Skid Plates 6 03-14-2015 01:02 AM
Rusty's Offroad Radiator Skid Plate Skid Plates 7 01-17-2012 11:01 AM
Rusty's Off-Road Products Rusty's Radiator Skid-TJ Skid Plates 10 06-17-2011 12:45 AM
