Notices
Rokmen Steering Box Skid Plate Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Skid Plates Next Product
Rating:
Product Information
MSRP: $55.00
Average Price: $46.14
Manufacturer: Rokmen
Recommended?
Yes: 42 / No: 0
http://www.rokmen.com/products/tj_lj_bumpers/steering_box_skid/steering_box_skid.html
ROKMEN TJ/LJ Steering Skid Plate
The steering box on TJ and LJ model Jeeps® hangs below the front bumper and is a magnet for rocks and other debris encountered on the trail. The ROKMEN Steering Skid plate protects the vulnerable steering box, giving you more confidence to tackle the tough trails.
Unique mounting allows the skid to mount closer to the outside of the frame rail; therefore not causing interference with torsion style swaybars. The ROKMEN skid is a full 1 1/2" wider than the competition's steering skids to give your steering box more protection. Constructed of 3/16" steel that is fully TIG welded for superior toughness and great fit and finish.
* Protects the vulnerable steering box on TJ/LJ Jeeps®
* Unique mounting will not cause interference with torsion style swaybars
* Constructed of 3/16" steel for superior toughness
* 1 1/2' Wider than the competition's steering skids for more steering box protection
* Includes mounting hardware and comes in either bare steel or black powdercoat
NOTES:
- ROKMEN steering skid is for use with 97-06' TJ/LJ model Jeeps® only
- Will not cause interference with torsion style swaybars
None
Page 2 of 3 1 2 3 > Last »
bobthetj03
bobthetj03's Reviews
11-06-2009, 04:29 PM
Price: $50.00
Pros: beefy Installation easy
Cons: None
Recommended? Yes
Comments: Great guys to talk to on the phone. Answered all my questions. Shipped quickly. Quality of product very good. Extra beefy skid. Installation was easy and everything lined up the way it should.
jmcgonig
jmcgonig's Reviews
10-29-2009, 06:36 PM
Price: $40.00
Pros: Pretty strong
Cons: None
Recommended? Yes
Comments: Why do I have to fill this in to add stuff to my profile..................
wyodar
wyodar's Reviews
10-25-2009, 11:28 AM
Price: $50.00
Pros: Easy to install
Cons: None
Recommended? Yes
Comments: Goes on quickly. Remove two bolts, put the skid in place and reinstall the bolts. Drill one hole in the cross tube between frame rails and install a self tapping bolt and that is it.
Pmort
Pmort's Reviews
09-21-2009, 12:14 AM
Price: $49.00
Pros: Tough, Thick, Looks Good
Cons: none
Recommended? Yes
Comments: I got this as a gift. It looks good and seems really well built. Easy to install, had to drill a hole.
Atar
Atar's Reviews
09-12-2009, 04:02 AM
Price: $49.99
Pros: Good
Cons: No
Recommended? Yes
Comments: I am satisfied
FarFire70
FarFire70's Reviews
09-07-2009, 07:56 AM
Price: $40.00
Pros: Thick. Wider that most. Went on without any problems.
Cons: None
Recommended? Yes
Comments: I picked this since it is wider than most. I had no problems with the install but expect to have to drill a hole in the frame cross member and use a self-tapping screw there. It's a great skid. It's not in a place I've hit often but gives me piece of mind that I won't have to worry about my box.
2000jeeper
2000jeeper's Reviews
07-23-2009, 03:20 PM
Price: $50.00
Pros: Excellant construction. Welds are awesome. Very Very Very heavy duty.
Cons: Instructions aren't the best. By that i mean they should tell you, you may need to grind some of the steering box frame mount a little bit. Second fit was not great out of the box. I had to slightly enlarge 2 of the 4 bolt holes to get it to fit properly and this is after i had to do som grinding.
Recommended? Yes
Comments: Other then the fact that it took 3 weeks to get here i am very impressed with the skid. A little miffed at the initial fit but a little grinding here and there and fits great now. Cant wait to smack it on a rock!!
Kinless
Kinless's Reviews
07-18-2009, 05:20 PM
Price: $39.99
Pros: Well built and easy install
Cons: None
Recommended? Yes
Comments:
E. Humphries
E. Humphries's Reviews
06-14-2009, 11:33 PM
Price: $39.99
Pros: High quality construction; beefy!
Cons: None that I can think of...
Recommended? Yes
Comments: The Rokmen steering box skid plate is a high quality skid. Made of 3/16 steel with easy to read directions with color pictures.
JohnyPro
JohnyPro's Reviews
05-14-2009, 10:30 PM
Price: $35.00
Pros: thick, stainless steel, can paint or not, easy install
Cons: None
Recommended? Yes
Comments: I painted about 3 coats of rustoleum primer and two coats of flat black paint after roughing the stainless up with a piece of steel wool and pouring 91% rubbing alcohol to clean the surface off first. Install went really well took about 20 minutes including the drilling. I think Rokmen dismantled a safe to make this product! Thick and sturdy i don't think I'm ever going to have a problem with my steering box from an outside assault!
DougB
DougB's Reviews
03-27-2009, 03:33 PM
Price: $55.00
Recommended? Yes
Comments: Fits very well even with an aftermarket bumper. Handles anything I can throw at it.
Hesher420
Hesher420's Reviews
01-04-2009, 05:15 PM
Price: $45.00
Recommended? Yes
Comments: A very sturdy skid for a very vulnerable area. One of the easiest and cheapest upgrades you can make to make sure you get home at the end of a day wheeling. Excellent instructions w/ pics from Rokmen.
BYuen
BYuen's Reviews
01-03-2009, 12:48 PM
Price: $44.99
Recommended? Yes
Comments: There's not much to say about a steering box skid, but this is a great skid. I really like having the option of having the four mounting points on the skid. One on the steering box bracket, two on the bumper, and one on the frame cross member.
rkwfxd
rkwfxd's Reviews
12-17-2008, 08:19 PM
Price: $50.00
Recommended? Yes
Comments: Well made. Fit right. Looks Strong. Fun and Easy to Install. Priced Right.
BlackBellamy
BlackBellamy's Reviews
09-30-2008, 10:45 AM
Price: $45.00
Recommended? Yes
Comments: A steering skid is a steering skid. They're all pretty much the same. This one was the cheapest, and it has the Rokmen name behind it.
silverjeep
silverjeep's Reviews
08-03-2008, 12:34 AM
Price: $40.00
Recommended? Yes
Comments: BEEFY! Wish I didn't have to drill any holes. The skid is very well made and the welds are perfect.
alvinl
alvinl's Reviews
07-10-2008, 11:38 AM
Price: $50.00
Recommended? Yes
Comments: I would recommend ANYTHING that Rokmen makes. This is a very sturdy product and the install was simple.
onlyn8v
onlyn8v's Reviews
06-15-2008, 10:38 AM
Price: $45.00
Recommended? Yes
Comments: Well thought out design, clear instructions, excellent welds. Comes with everything needed to install (except a 5/16 drill bit and drill)
thedirt
thedirt's Reviews
05-23-2008, 03:32 AM
Price: $44.99
Recommended? Yes
Comments: Nice, very easy to install steering box skid plate. Glad my steering box isn't exposed any more.
3rivers
3rivers's Reviews
04-21-2008, 12:03 AM
Price: $39.00
Recommended? Yes
Comments: This skid is wider than some, great price and made by craftsmen in a small shop, not in large Chinese factory.
ThreadForumRepliesLast Post
FabTech Steering Box Skid Plate Skid Plates 9 01-09-2013 01:29 PM
Gen-Right TJ Steering Box Skid Plate - SBS-2001 Skid Plates 5 04-07-2012 12:36 AM
Skyjacker SJ-SSP10 -- Steering Box Skid Plate Skid Plates 7 01-07-2012 03:21 PM
Gen-Right TJ / LJ Steering Box Skid Plate SKUSBS-2001 Skid Plates 6 10-12-2011 01:22 PM
GEN-RITE STEERING SKID PLATE YJ Skid Plates 1 06-13-2009 12:00 PM
