Notices
Rokmen Gas Tank Skid Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Skid Plates Next Product
Rating:
Product Information
MSRP: $264.99
Average Price: $232.08
Manufacturer: Rokmen
Recommended?
Yes: 38 / No: 0
The ROKMEN gas tank skid plate protects your stock gas tank and gives you the piece of mind needed to attack the toughest of obstacles. At the same time it increases your ground clearance by 1 1/2" inches overall and 1" at the dimple over stock.
ROKMEN is the first to offer a formed dimple in the bottom of the skid to protect and maintain proper function of the factory pickup and sending unit; just like the stock skid plate was designed to do. It is the right way to protect your investment and keep you moving down the trail.
Constructed from high grade 3/16" steel that is Laser cut, CNC formed, and then fully TIG welded for the highest quality gas tank skid available.
Protects the stock gas tank on 97-06' TJ/LJ JeepsŪ
3/4" of additional clearance behind the diff cover
Constructed of 3/16" steel for superior toughness
Available bare steel only
Full replacement skid, does NOT install over factory skid
None
Page 2 of 2 1 2
razorback84
razorback84's Reviews
09-02-2009, 12:33 AM
Price: $220.00
Pros: Tough
Cons: None
Recommended? Yes
Comments: Great Product!!! Have done several trail runs with this gas tank skid and it has taken a beating. Still holding up strong.
white305
white305's Reviews
08-19-2009, 09:59 PM
Price: $195.00
Pros: Perfect fit made for a easy install. Solid and well built. Consistant with everything I have got from Rokmen. You couldn't ask for better service.
Cons: None
Recommended? Yes
Comments: This is as nice a skid plate as I have found. I researched a lot prior to spending my hard earned money and I am impressed with what I got.
Kinless
Kinless's Reviews
07-02-2009, 07:55 PM
Price: $219.99
Pros:
Cons:
Recommended? Yes
Comments: Very well put together product and customer service is fantastic. These guys sat and listened to me as I explained what I want to do now, what I want to work towards, and my end goal at this time and helped me come up with a plan. Dave and Jeff are good guys and I will deal with them again.
apexjeepinjoe
apexjeepinjoe's Reviews
05-26-2009, 09:08 PM
Price: $259.00
Pros: Best made
Cons: None
Recommended? Yes
Comments: Great skid. Easy to install and they have a video on you tube to help you out.
DougB
DougB's Reviews
03-27-2009, 03:26 PM
Price: $257.00
Recommended? Yes
Comments: GREAT PRODUCT! Fits like a glove. Added clearance is excellent. Price includes $37 in shipping.
BYuen
BYuen's Reviews
01-03-2009, 12:22 PM
Price: $219.99
Pros: more clearance everywhere, extreme protection from rocks and tailgating Hondas, great looks
Cons: No powder coat available?
Recommended? Yes
Comments: This skid is an awesome skid. So far, IMHO it is the best full replacement gas tank skid on the market. I just installed it and haven't gotten the chance to whack it on the rocks yet, but there is no doubt in my mind this skid will take whatever I throw at it. I will send an update when I do. Now I will say I did have to add 3/4" coil spacers to the rear of my Jeep due to the added weight along with my Hi-Lift and rear bumper setup, but not to worry the protection and peace of mind is definitely worth it. I also feel the Jeep handles much better on and off road with this skid installed.
Since I already had some rubbing issues with the stock setup, I thought I would run into clearance issues with the rear track bar, driver's side shock, or with my aftermarket exhaust piping. Well I was wrong! Turns out this skid fits perfectly and actually gave more clearance the whole way around. I was just flabbergasted. This skid is the epitome of gas tank skids.
As for the install, it was easy and straightforward. If you follow the tips and instructions off the Rokmen YouTube install, you should have no issues. To me the hardest part was just lifting the tank back up under the Jeep since I did do the install solo. It would definitely help to have someone else to help line up and balance the tank as you lift it back up.
05jeeper
05jeeper's Reviews
12-25-2008, 02:17 PM
Price: $250.00
Recommended? Yes
Comments: EASY TO INSTALL, WELL BUILT AND BEEFY. GAINED GROUND CLEARANCE AND LOOKS BETTER THAN FACTORY
TJTRUBL2006
TJTRUBL2006's Reviews
11-06-2008, 11:22 AM
Recommended? Yes
Comments: Great Fuel skid. Alot of detail went into building this skid and the quaility of the construction is second to none...
BlackBellamy
BlackBellamy's Reviews
10-09-2008, 08:33 AM
Price: $220.00
Recommended? Yes
Comments: Great value for the price, solid construction, raises the tank and provides much better coverage than the stock skid.
stu2003
stu2003's Reviews
09-19-2008, 01:17 PM
Price: $200.00
Recommended? Yes
Comments: Have JKS 1.25 body lift. High clearance gas tank skid bolted up with no problem.
Significant upgrade over factory skid plate.
Kiwi Jeeper
Kiwi Jeeper's Reviews
06-07-2008, 03:41 AM
Recommended? Yes
Comments: Heavy!! Great quality and easy install. It took three people to lift the tank + skid + 10 litres of petrol to put it back up while the Jeep was on a hoist.
breckboarder55
breckboarder55's Reviews
06-01-2008, 11:44 PM
Price: $220.00
Recommended? Yes
Comments: Great quality, great design!
Excellent gain in clearance!
I wish it came powder coated, but it did not. Shipped bare metal, no box. Received in less than three days prior to ordering. Excellent product, will buy from again.
thedirt
thedirt's Reviews
05-23-2008, 03:35 AM
Price: $264.99
Recommended? Yes
Comments: Awesome skid plate. I picked it up locally and they had one that was powdercoated, which saved me a lot of time. I'm glad to get rid of the flimsy, bent up stock gas tank skid plate.
TJ Flexer
TJ Flexer's Reviews
05-12-2008, 07:22 PM
Price: $220.00
Recommended? Yes
Comments: I feel this is the best on the market, and the price is better than most other skids of less quality. Rokmen knows what they are doing.
slate210
slate210's Reviews
05-05-2008, 03:00 PM
Price: $219.00
Recommended? Yes
Comments: The extra clearance is much appreciated. My stock skid was just crumbling from rust and this works great. No complaints at all on the install. I sprayed it with bedliner prior to install.
FireMedicZ
FireMedicZ's Reviews
04-25-2008, 11:11 AM
Price: $230.00
Recommended? Yes
Comments: Heavy duty skid plate, nice welds, very well made. Be careful of the sharp edges when handling the skid.
bluerubicon06
bluerubicon06's Reviews
04-09-2008, 08:12 PM
Price: $195.00
Recommended? Yes
Comments: Nice addition and provides good protection
Page 2 of 2 1 2
ThreadForumRepliesLast Post
Factory front skid and rear gas tank skid OEM Skid Plates 21 08-19-2013 03:30 PM
Rokmen Steering Box Skid Plate Skid Plates 40 03-23-2013 11:23 PM
EMP Gas Tank Skid Plate Skid Plates 5 01-16-2012 01:55 AM
Skid Row Gas Tank Skid Plate (TJ / XJ) Skid Plates 9 08-24-2010 12:26 PM
skid row Jeep TJ Wrangler Gas Tank Skid Plate Skid Plates 3 05-25-2010 06:49 PM
