Go Back JeepForum.com > Reviews > Armor > Skid Plates > Rokmen Gas Tank Skid
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Rokmen Gas Tank Skid Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Skid Plates Next Product
Rating:
Product Information
MSRP: $264.99
Average Price: $228.33
Manufacturer: Rokmen
Recommended?
Yes: 29 / No: 0
The ROKMEN gas tank skid plate protects your stock gas tank and gives you the piece of mind needed to attack the toughest of obstacles. At the same time it increases your ground clearance by 1 1/2" inches overall and 1" at the dimple over stock.
ROKMEN is the first to offer a formed dimple in the bottom of the skid to protect and maintain proper function of the factory pickup and sending unit; just like the stock skid plate was designed to do. It is the right way to protect your investment and keep you moving down the trail.
Constructed from high grade 3/16" steel that is Laser cut, CNC formed, and then fully TIG welded for the highest quality gas tank skid available.
Protects the stock gas tank on 97-06' TJ/LJ Jeeps®
3/4" of additional clearance behind the diff cover
Constructed of 3/16" steel for superior toughness
Available bare steel only
Full replacement skid, does NOT install over factory skid
Page 1 of 2 1 2 > Last »
julietkilo
FLY DIVE JEEP SKI
julietkilo's Reviews
11-14-2011, 08:13 PM
Price: $210.00
Pros: ROKMEN Heavy
Cons: Heavy
Recommended? Yes
Comments: As was said before, done right, by a robot, search out the videos. Unreal for the price.
mike_dippert
hodophobic
mike_dippert's Reviews
10-26-2011, 10:09 AM
Price: $0.01
Pros: Extreme duty.
Cons: HEAVY
Recommended? Yes
Comments: Another top notch product of Rokmen. I'd buy this again in a heartbeat if I didn't mind the weight of the steel. I used it as a jack point several times. Wacked it on ledges more than I can count. Lots of scratches but no dents.
Shiguy
Shiguy's Reviews
06-21-2011, 08:13 AM
Price: $210.00
Pros: HEAVY DUTY!, fits perfectly
Cons: HEAVY! difficult to get back in?
Recommended? Yes
Comments: Got this skid cause the LJ has more hangover in the rear than the normal TJ's My stock gas skid was getting to the point that I risked puncturing the tank. Skid fits perfectly to existing mounts and tank. And very heavy dute! I could take the rear wheels off and drag the a$$-end of my jeep across rocks and come out fine. With BL tucks tank very nicely for an added lift. Only downside is installation. I snapped the tube coming out of the fuel pump trying to remove the old tank and installing everything back up while raising the tank leaves VERY little room to reconnect the lines. A lot of "feel" for where the lines and mounts were was required. That being said would do this again in a heart beat. I now don't have to worry about anything while going over a big drop and a tank hit is inevitable.
blizzboy15
Dual Jeeps!!!
blizzboy15's Reviews
04-04-2011, 03:11 PM
Price: $800.00
Pros: Excellent Quality! awesome craftsmanship!
Cons: $$
Recommended? Yes
Comments: Amazing quality! I purchased the whole ARMOR UP package from ROKMEN and i couldnt be happier! Thanks fellas! I gained a good 2 inches of clearance and also made my undercarrige unstoppable!!
blizzboy15
Dual Jeeps!!!
03-24-2011, 05:01 PM
Price: $219.00
Pros: Great product! craftmanship is unmatched! great service!
Cons: no cons!
Recommended? Yes
Comments: ROKMEN is one of the best if not the best company i have ever come across! they are dedicated to building the best product all the time! i have not found a product that can compete yet! thier quality and customer service is the best! great skid! heavy duty! i would recommend the BL/MM before installing the skid. Great product, I will buy Rokmen time and time again! I would suggest getting it powder coated through Rokmen, great quality and good price as well.
patricknash1
Junior Member
patricknash1's Reviews
03-16-2011, 09:55 AM
Price: $219.99
Pros: Heavy Duty, amazing product.
Cons: None, I am sold on Rokmen products.
Recommended? Yes
Comments: After removing the stock skid, I couldn't belive how strong this skid is. I was able to do the install by myself in the driveway with just a floor jack. I havent had the chance to hit it on anything yet, but if I can dent this thing, it would have destroyed my old skid. I also like the extra clearance I got for my rear diff, which was the main reason for buying it in the 1st place.
1unknown
1unknown's Reviews
08-22-2010, 05:33 PM
Price: $245.00
Pros: well engineered, quality material and workmanship
Cons: dont have a bodylift so had to use the half inch spacer which did not come with hardware.e mail rockman but no reply.
Recommended? Yes
Comments: went on the tahoe hi-lo poker run near markleyville ca. it was 6 miles of rocks and with the winter weather it was worse than it usually is. came down hard on granet rocks and boulders. it came thru undamaged except for paint. highly recoment this product
TJagain
Junior Member
TJagain's Reviews
04-27-2010, 01:30 PM
Price: $200.00
Pros: very well built and designed
Cons: ?
Recommended? Yes
Comments: very well built and designed. higher ground clearance and extra protection is a good feeling. tank droped right in and all bolt holes lined up perfectly! It is a bit of work for the gain you get. I recomend doing this upgrade with at lift install. dame my install much easier when working on the rear.
tjsean0308
tjsean0308's Reviews
04-25-2010, 10:06 PM
Price: $1.00
Pros: super HD. added significant clearance.
Cons: weighs a lot. comes un-painted
Recommended? Yes
Comments: love it so far. got it as a gift. has the factory style "bump" on the bottom to further protect the fuel pump and screen. I am torn as to whither or not it being un finished was good or bad. some other products I have came powder coated and it hasn't held up. I hit this with por and its doing good so far.
Filthy-Beast
Filthy-Beast's Reviews
03-03-2010, 02:25 PM
Price: $200.00
Pros: Very heavy duty and a perfect fit. Install video.
Cons: none
Recommended? Yes
Comments: My stock skid was taking some heavy abuse since I have an LJ, that extra 5" past the rear wheels causes me to drop the gas tank on more objects than a regular TJ. This new skid has taken a ton of abuse without issue.
FarFire70
FarFire70's Reviews
09-07-2009, 06:52 AM
Price: $220.00
Pros: Thick, gained clearance, fuel pump bulge for proper fitment
Cons: None yet
Recommended? Yes
Comments: I got this to replace my stock skid after I put a nice big dent right at the fuel pump. It's held up nicely when I landed on it last time I was out.
razorback84
razorback84's Reviews
09-01-2009, 11:33 PM
Price: $220.00
Pros: Tough
Cons: None
Recommended? Yes
Comments: Great Product!!! Have done several trail runs with this gas tank skid and it has taken a beating. Still holding up strong.
white305
white305's Reviews
08-19-2009, 08:59 PM
Price: $195.00
Pros: Perfect fit made for a easy install. Solid and well built. Consistant with everything I have got from Rokmen. You couldn't ask for better service.
Cons: None
Recommended? Yes
Comments: This is as nice a skid plate as I have found. I researched a lot prior to spending my hard earned money and I am impressed with what I got.
Kinless
Kinless's Reviews
07-02-2009, 06:55 PM
Price: $219.99
Pros:
Cons:
Recommended? Yes
Comments: Very well put together product and customer service is fantastic. These guys sat and listened to me as I explained what I want to do now, what I want to work towards, and my end goal at this time and helped me come up with a plan. Dave and Jeff are good guys and I will deal with them again.
apexjeepinjoe
apexjeepinjoe's Reviews
05-26-2009, 08:08 PM
Price: $259.00
Pros: Best made
Cons: None
Recommended? Yes
Comments: Great skid. Easy to install and they have a video on you tube to help you out.
DougB
DougB's Reviews
03-27-2009, 02:26 PM
Price: $257.00
Recommended? Yes
Comments: GREAT PRODUCT! Fits like a glove. Added clearance is excellent. Price includes $37 in shipping.
BYuen
Wahoowa
BYuen's Reviews
01-03-2009, 11:22 AM
Price: $219.99
Pros: more clearance everywhere, extreme protection from rocks and tailgating Hondas, great looks
Cons: No powder coat available?
Recommended? Yes
Comments: This skid is an awesome skid. So far, IMHO it is the best full replacement gas tank skid on the market. I just installed it and haven't gotten the chance to whack it on the rocks yet, but there is no doubt in my mind this skid will take whatever I throw at it. I will send an update when I do. Now I will say I did have to add 3/4" coil spacers to the rear of my Jeep due to the added weight along with my Hi-Lift and rear bumper setup, but not to worry the protection and peace of mind is definitely worth it. I also feel the Jeep handles much better on and off road with this skid installed.
Since I already had some rubbing issues with the stock setup, I thought I would run into clearance issues with the rear track bar, driver's side shock, or with my aftermarket exhaust piping. Well I was wrong! Turns out this skid fits perfectly and actually gave more clearance the whole way around. I was just flabbergasted. This skid is the epitome of gas tank skids.
As for the install, it was easy and straightforward. If you follow the tips and instructions off the Rokmen YouTube install, you should have no issues. To me the hardest part was just lifting the tank back up under the Jeep since I did do the install solo. It would definitely help to have someone else to help line up and balance the tank as you lift it back up.
05jeeper
Jeep Enthusiast
05jeeper's Reviews
12-25-2008, 01:17 PM
Price: $250.00
Recommended? Yes
Comments: EASY TO INSTALL, WELL BUILT AND BEEFY. GAINED GROUND CLEARANCE AND LOOKS BETTER THAN FACTORY
TJTRUBL2006
TJTRUBL2006's Reviews
11-06-2008, 10:22 AM
Recommended? Yes
Comments: Great Fuel skid. Alot of detail went into building this skid and the quaility of the construction is second to none...
BlackBellamy
BlackBellamy's Reviews
10-09-2008, 07:33 AM
Price: $220.00
Recommended? Yes
Comments: Great value for the price, solid construction, raises the tank and provides much better coverage than the stock skid.
ThreadForumRepliesLast Post
Skid Row Gas Tank Skid Plate (TJ / XJ) Skid Plates 9 08-24-2010 12:26 PM
Rokmen Steering Box Skid Plate Skid Plates 25 04-27-2010 08:12 PM
EMP Gas Tank Skid Plate Skid Plates 3 02-10-2010 08:54 AM
Factory front skid and rear gas tank skid OEM Skid Plates 9 02-07-2010 10:31 AM
skid row Jeep TJ Wrangler Gas Tank Skid Plate Skid Plates 2 08-16-2007 11:39 PM
Glock Forum
