Rear Differential Slider Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Skid Plates Next Product
Rating:
Product Information
MSRP: $249.00
Average Price: $251.60
Manufacturer: AEV
Recommended?
Yes: 5 / No: 0
Company Website: http://www.aev-conversions.com
These smooth differential skid plates not only keep you from getting hung up on your differential, but also protect the vulnerable U-joint and Yoke on TJs and the lower CV Joint on JKs. Each unit is specially designed to fit specific axles and take up virtually zero ground clearance. Slider is built primarily from 1/4″ steel and comes with a black power coat finish with all hardware. Simple hand tools required. Applications currently include all TJ and JK Dana 44 rear axles and TJ Dana 44 and 30 Front Axles. All models are suitable for mounting our Stinger for the ultimate in traction.
None
BlackWidowJK
BlackWidowJK's Reviews
02-03-2014, 06:40 PM
Price: $250.00
Pros: AEV rear slider completely protects the low-riding driveshaft CV joints and collar.
Cons: Heavy when installing and kinda pricey.
Recommended? Yes
Comments: AEV rear slider completely protects the low-riding driveshaft CV joints and collar. I have hit, drug and smacked it pretty good but really keeps me rolling. A little weight back there seems to help with traction as well.
bbusch
bbusch's Reviews
12-08-2012, 07:35 PM
Price: $250.00
Pros: Works great
Cons: none
Recommended? Yes
Comments: Nth Degree rear slider with Stinger boom. Works well and has proven to assist while rock climbing.
4LCKDRUBIUNLTD
4LCKDRUBIUNLTD's Reviews
06-23-2011, 08:29 PM
Price: $259.99
Pros: Quality product
Cons: None
Recommended? Yes
Comments: Pinion Protection Each Slider extends under the pinion yoke to protect the vulnerable U-joint from rock damage.
Maximum Ground Clearance Each Slider is specifically designed to fit so tightly that it conserves 100% of your axle’s original ground clearance by butting up to the casting flange rather than being under it.
Tough Construction using ¼” steel to create an unbreakable ‘ski’ for your differential.
Smooth Design uses minimal bends/edges to hide the rough, snag-prone contours of the factory casting – especially the casting flange around the cover.
Easy Installation in minutes using three special U-bolts (most applications) with no cutting, grinding, etc.
RockyClymer
RedRock4Wheeler
RockyClymer's Reviews
06-17-2009, 11:41 AM
Price: $249.00
Pros: Built tough and easy to install
Cons: pricey
Recommended? Yes
Comments: Original review already listed.
RockyClymer
RedRock4Wheeler
06-13-2009, 04:45 PM
AEV Rear Differential Slider
Price: $249.00
Pros: Very easy to install, great coverage of rear drive shaft joint and very heavily built/fabricated - what you would expect from AEV
Cons: Pricey -
Recommended? Yes
Comments: I had "dinged" my rear Rzeppa joint in Moab and realized this joint hangs down a bit and is exposed to rock damage - this slider is an excellent way to protect the joint especially if you have some real expensive after market U joints on a custom shaft.
ThreadForumRepliesLast Post
Warn Front/Rear Differential Guards Differential Guards 22 07-02-2016 11:15 PM
Olympic Slider rear bumper w/ hitch (textured finish) Bumpers 8 01-25-2016 11:35 AM
Nth Degree/AEV DANA 35 Rear Differential Slider Differential Guards 1 03-18-2009 11:47 PM
Nth Degree/AEV DANA 30 Front Differential Slider Differential Guards 1 11-30-2008 02:26 PM
Nth Degree/AEV DANA 30 Rear Differential Slider Differential Guards 1 11-30-2008 02:25 PM
