Go Back JeepForum.com > Reviews > Armor > Skid Plates > Nth Degree Mobillity Oil Pan Skid (4.0L)
1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with FullIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Lockers FREE SHIPPING Excellent Prices
Nth Degree Mobillity Oil Pan Skid (4.0L) Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Skid Plates Next Product
Rating:
Product Information
MSRP: $250.00
Average Price: $147.62
Manufacturer: Nth Degree Mobillity
Recommended?
Yes: 28 / No: 1
Extreme Clearance. Skid bolts on to engine block and transmission bell housing, giving you protection only where you need it- no excess and uncessary steel. Because the skid will now move with the exhaust and engine, there are no rattles- just solid protection.
Bolt-on Installation uses existing unused holes in engine block and transmission too create simple and easy installation
Easy Oil Changes . No need to drop the skid, convenient holes allow you to quickly drain your oil with no mess .
* Oil Pan Skid to fit 1987-2006 4.0L Jeep engine oil pan
* Engine-Mounted, pan-hugging design for maximum ground clearance (inches higher than frame-mounted designs can acheive).
* Boxed Construction using 3/16” steel prevents not just punctures but also prevents crushing the pan.
* Tidy Fit clears TJ-style exhausts and XJ/ZJ/WJ front driveshafts with no body, motor, or suspension lift limitations.
Page 1 of 2 1 2 > Last »
Flyboy161
Flyboy161's Reviews
11-22-2011, 09:03 PM
Price: $135.00
Pros: Heavy! Should protect my oil pan
Cons: None
Recommended? Yes
Comments: Awesome! After putting a baseball sized dent in my XJ oil pan on the Rubicon trail, I thought this might be a good idea for my TJ.
jamcat77
jamcat77's Reviews
04-24-2011, 06:20 PM
Price: $140.00
Pros: Extra protection
Cons: None, price?
Recommended? Yes
Comments: Easy install!
Rafikie
Rafikie's Reviews
03-22-2011, 12:29 PM
Price: $110.00
Pros: Great protection without covering up oil drain plug.
Cons: If you have an old motor the threads in the block that are used to mount this skid are most likely in rough shape. It's difficult to get in there and clean them out good for the install, but that the only real problem IMO and once it's on your good to go.
Recommended? Yes
Comments: Great protection without covering up oil drain plug. I'm not a fan of the full skids that do this. If you have an old motor the threads in the block that are used to mount this skid are most likely in rough shape. It's difficult to get in there and clean them out good for the install, but that the only real problem IMO and once it's on your good to go.
A+ IMO
yukonblu
yukonblu's Reviews
03-19-2011, 07:57 PM
Price: $139.00
Pros: Great fit, very solid, could not ask for a better product.
Cons: none
Recommended? Yes
Comments: Mine came in black not grey like u see in the pics. I like black better anyway.
USMCEOD
Junior Member
USMCEOD's Reviews
01-24-2010, 09:18 PM
Price: $139.00
Pros: Indestructible
Cons: heavy
Recommended? Yes
Comments: All of my underarmour is Nth Degree. It has taken a beating and has yet to show any signs. I highly recommend AEV/Nth Degree products.
warlizard
warlizard's Reviews
12-08-2009, 06:38 PM
Price: $155.00
Pros: great design that is out of the way of all moving parts
Cons: needed washer to space the skid plate
Recommended? Yes
Comments: I dented my oil pan one of the frist time out. now I don't worry about it anymore.
06_Rubi_LJ
06_Rubi_LJ's Reviews
07-30-2009, 01:12 PM
Price: $135.00
Pros: Works
Cons: Not free
Recommended? Yes
Comments: Very solid and better than the Warn!
Not hard to install.....ever for me.
jaredwade81
jaredwade81's Reviews
07-03-2009, 10:54 AM
Price: $150.00
Pros: provides protection for your oil pan and drain plug
Cons: requires a little time and elbow grease.
Recommended? Yes
Comments: If your like me, and i beat the crap out of my jeep. Your gonna need one of these. its gonna require you to clean out the already tapped holes on your engine block and they are already hard to get to, so it will take some patience. i sprayed some brake cleaner in there to get the chunks out the tapped in a few times until it was clean. then it bolts right up.. and tucks it away quite nice. over all great product.
05moabTJ
05moabTJ's Reviews
03-02-2009, 05:46 PM
Price: $150.00
Recommended? Yes
Comments: Best on the market and strongest. Highly recommend it. Must have for anyone big enough to play outside the sand box.
AlexGeorgakis
AlexGeorgakis's Reviews
02-26-2009, 08:26 AM
Price: $160.00
Recommended? Yes
Comments: Tough skid plate even for the roughest conditions. But after installing it I was scratching my head wondering how it would be useful since the axle will fall on a rock before the oil pan gets even close... It's a good product but I think it's usefull only if you're going to be driving over a mine field...
pigpen8304
pigpen8304's Reviews
12-12-2008, 11:21 PM
Price: $140.00
Recommended? Yes
Comments: Good product, easy to install. Bought at Northridge4X4, which is where I try to get most a my jeep mods. If they have them available.
Loctup
Loctup's Reviews
11-02-2008, 11:22 AM
Price: $125.00
Recommended? Yes
Comments: Best there ever was. Nuff said.
Mounts perfectly, drain cutout is ideal. Stronger then needed.
rickw450
rickw450's Reviews
09-08-2008, 04:50 AM
Price: $100.00
Recommended? Yes
Comments: Protects you oil pan, easy to mount and is solid. Easy access to the drain plug for easy oil changes.
1968olds98
1968olds98's Reviews
08-21-2008, 12:05 PM
Price: $145.00
Recommended? Yes
Comments: Took like 20mins to install after I figured out wtf.. just read in the instructions.
Fit a 93 YJ like a glove, same level as the transfer-case skid so its not any lower.
rlk_99
rlk_99's Reviews
07-06-2008, 09:01 AM
Price: $130.00
Recommended? Yes
Comments: Easy install. Takes maybe 15 min if you have all the tools that you need in your box. Requires an allen wrench a socket and ratchet and a wrench.
jdarg
jdarg's Reviews
06-27-2008, 04:29 PM
Price: $175.00
Recommended? Yes
Comments: Great skid but a royal pain to install unless the block is new and the front mounting holes aren't rusty and full of crud.
dolphin88
dolphin88's Reviews
06-17-2008, 06:14 PM
Price: $150.00
Recommended? Yes
Comments: Had many dings in the stock skid plate, was pushing my luck, this was one of my first upgrades, to bad they went out of business.
TJ Flexer
TJ Flexer's Reviews
05-12-2008, 06:27 PM
Price: $150.00
Recommended? Yes
Comments: well built, and affordably priced... Once again Nth degree puts out a quality product to those offroad enthusiasts
flatlander757
Now in the 937
flatlander757's Reviews
05-10-2008, 10:30 PM
Price: $160.00
Recommended? Yes
Comments: Very nice skidplate, it wraps tightly against the oil pan to stay out of the way but is nice and durable and will support the whole weight of the Jeep should a rock come in the way.
98VTRam
98VTRam's Reviews
04-30-2008, 08:23 AM
Price: $125.00
Recommended? Yes
Comments: solid design but awkward install. Also had to tweak as it was vibrating against my oil pan causing some nasty noises. very srong though and serves intended purpose without robbing clearance
ThreadForumRepliesLast Post
Factory front skid and rear gas tank skid OEM Skid Plates 9 02-07-2010 10:31 AM
Nth Degree Mobillity Tummy Tucker Skid Plates 10 01-24-2010 09:25 PM
Skid Row JP - 0009 Engine & Transmission Skid Plate Skid Plates 2 01-20-2010 11:40 AM
Skid Row Lower Control Arm Skid Plate Skid Plates 5 12-05-2009 02:02 AM
skid row Jeep TJ Wrangler Gas Tank Skid Plate Skid Plates 2 08-16-2007 11:39 PM
Glock Forum
