Notices
Mike Green LCA Skids Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Skid Plates Next Product
Rating:
Product Information
MSRP: $30.00
Average Price: $26.00
Manufacturer: Mike Green
Recommended?
Yes: 3 / No: 0
TJ Weld-on lower control arm skids are made from 3/16" steel.
None
BlackBellamy
BlackBellamy's Reviews
10-23-2008, 10:34 AM
Price: $30.00
Recommended? Yes
Comments: Weld on - can use with stock or beefier LCA mounts. Can be used with stock control arms but you will need to grind away a bit of the control arm so it doesn't rub against the skid at full stuff.
Chris_
Chris_'s Reviews
11-09-2007, 11:48 AM
Pros: Cheap, solid
Recommended? Yes
Comments: I have these. I use my control arm mount as a jacking point now. I've beat these things pretty hard, and for the money it's one of the better modifications I've made. Before I had these I bent up a control arm mount. They weld along both sides, and to the axle tube, so they are as solid as a rock. On top of that, Mike Green is a great guy and wholeheartedly supports, and is very active in, off roading.
VinoTJ
VinoTJ's Reviews
08-23-2007, 04:18 PM
Price: $22.00
Pros: Fit is perfect with stock control arms
Cons: The only thing that could be better would be to have them in 1/4"
Recommended? Yes
Comments: I just swapped in a HP30 front axle and wanted to make sure that my LCA mounts stayed nice and straight. I found Mike Green's LCA Skids work with stock control arms (which I still have). The skids are 3/16" thick and machined perfectly to be attached on three sides. I was even surprised to find there was a left & right skid - meaning that the tube side was cut on an angle for a better fit.
Bravo Mike Green!
ThreadForumRepliesLast Post
Clayton engine and tranny skids Skid Plates 4 02-07-2016 04:38 PM
Tomken Machine Rocker Skids Rocker Guards 4 10-20-2011 06:29 AM
Currie Enterprises lower control arm bracket "mini-skids" Skid Plates 3 10-14-2011 12:51 PM
