Go Back JeepForum.com > Reviews > Armor > Skid Plates > Clayton engine and tranny skids
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Clayton engine and tranny skids Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Skid Plates Next Product
Rating:
Product Information
MSRP: $775.00
Average Price: $524.67
Manufacturer: Clayton Off Road Manufacturing
Recommended?
Yes: 3 / No: 0
Company Website: http://claytonoffroad.com/index.php?cPath=17_47
Clayton Off Road skid plates are the ultimate in off road skid plate protection. The main skid plate is a 2 piece design. The cradle is laser cut from 3/16 metal and bolts into the OEM frame rail locations. This holds up the transmission reusing the stock mount and bolts. Once this cradle is bolted up, the 1/4 flat skid bolts to the cradle using counter sunk allen head bolts. This gives you a completely smooth surface to easily slide over any obstacle in your way. Servicing your drivetrain is now also easier, by simply removing the skid plate while the cradle will keep the drivetrain in its proper location. The oil pan and engine skid plate are also laser cut from 1/4 steel for maximum rock dragging protection. The oil pan skid plate comes with a front bolt in bracket which holds the front of the skid plate using counter sunk allen head bolts. While the back attaches to our main skid plate with another bolt on bracket. No oil drain holes is cut because it will slightly weaken the skid plate, plus add a hole you may get hung up on. Some customers have chosen to drill a 3-4 inch hole to make oil changes easier. Many customers simply drop the oil pan skid plate section by removing the 7 bolts. This skid plate combo will fit on stock Jeep Wrangler TJs and works perfectly with our long arm setup. Any Rubicon model does REQUIRE a 1 inch body lift. On 2003-2006 models you will gain approximately 1.5 inches, and on 1997-2002 models approximately .5 inches. All skid plates are shipped bare metal out of the box.
yellowrubicon
yellowrubicon's Reviews
11-05-2009, 06:21 PM
Price: $475.00
Pros: Extreme in every way. Tight precise fit.
Cons: Had to get it powder coated myself. Would be nice if Clayton would do it for an additional $$ from the factory.
Recommended? Yes
Comments: Very nice two piece design. I have a Rubicon with a NV241 transfer case so I had to install a 1" body lift and a 1" engine mount lift to get this "tummy tucker" skid installed due to the t-case size. Nothing hits and the fit is very precise. One piece of the skid stays in place after you remove the lower skid plate so that you can get to the t-case to change fluids, etc. I got it powder coated gloss black for an additional $80 locally. I wish Clayton would offer that option from the factory.
onlyn8v
onlyn8v's Reviews
09-12-2009, 09:24 PM
Price: $749.00
Pros: Built like a tank. Clayton didnt even need to ship in a box lol.
Cons: Extremely heavy!
Recommended? Yes
Comments: Eat your wheaties before planning to mount these babies! Strong as anythign but heavy as sin. Smart 2 part design allows you to get to the important stuff without worrying about the transfer case falling
uvalax236
uvalax236's Reviews
06-26-2009, 01:04 PM
Price: $350.00
Pros: Awsome Skid!
Cons: None
Recommended? Yes
Comments: This skid has an integrated crossmember so cleaning the skid is a breeze! The actual skid itself is 1/4" thick steel so bashing it on rocks is a no-brainer. Highly recommended when going with the Clayton Long Arm kit.
ThreadForumRepliesLast Post
Rusty's Offroad JS-TJ10 TJ Engine/Tranny Skid Plate Skid Plates 8 09-02-2009 11:39 AM
Tomken Machine Rocker Skids Rocker Guards 3 07-19-2009 10:11 PM
Currie Enterprises lower control arm bracket "mini-skids" Skid Plates 1 03-20-2009 08:31 AM
Mike Green LCA Skids Skid Plates 3 10-23-2008 09:34 AM
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
