Go Back JeepForum.com > Reviews > Armor > Skid Plates > 33 Engineering High Clearance Transfer Case Skid Plate
RuffStuff Memorial Day Sale!CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
33 Engineering High Clearance Transfer Case Skid Plate Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Skid Plates Next Product
Rating:
Product Information
MSRP: $450.00
Average Price: $393.33
Manufacturer: 33 Engineering
Recommended?
Yes: 9 / No: 0
Whether your rig is a daily driver or a hard core rock crawler, skid plates are often the most tested parts. You want to make sure that your skid plates are up to the task, or you might end up spending some down time on the trail side.
EASY - Simple bolt on installation minimizes vehicle down time
SMART - 3/16" steel skid plate is reinforced by a steel double U-channel for impenetrable protection
STRONG - The design supports the entire vehicle's weight without deflection or damage
ACCESSIBLE - The 2-Piece design lets you remove the skid plate and the transmission stays supported for easy access
SLIDABLE - The design ramps up in the front and the back to maximize clearance, hanging only 1.25" at it's lowest
HIGH - Saves over 2.5" of ground clearance from the stock skids
SMOOTH - Countersunk fasteners mean no bolts sticking out to grab rocks
LIGHT - only 65 lbs - Optional Aluminum version saves an additional 22lbs
http://www.33engineering.com/skids.html
None
mike_dippert
hodophobic
mike_dippert's Reviews
10-26-2011, 11:02 AM
Price: $524.98
Pros: Very strong. 2 pc design.
Cons: Very heavy.
Recommended? Yes
Comments: These are no longer available, but it's a very nice product. It has a 3/16" plate that mounts to a cross member. The cross member supports the Tcase. The plate is heavy and difficult to handle so I tend to leave it mounted if I can help it. I've balanced my LJ on it and no dents, just surface scratches. I have the low-profile mount so I can tuck it up real close to the body. The 6 flush mount bolts are difficult to get in and lined up, but they get easier with practice.
IOUnlimited
IOUnlimited's Reviews
10-19-2009, 09:05 AM
Price: $400.00
Pros: Very easy to install Two piece design makes servicing transmission easy
Cons: None
Recommended? Yes
Comments: It took forever for all the right parts to be received. I've been very disappointed with the service I received from 33E. The products however have been very good...when I finally got them.
05jeeper
05jeeper's Reviews
12-25-2008, 02:26 PM
Price: $350.00
Recommended? Yes
Comments: AWSOME PRODUCT. HUGH GROUND CLEARANCE GAINS. LOOKS BETTER THAN FACTORY. RECOMMEND TRANNY MOUNT FOR TRANNY TO BODY VIBES
daveshan
Feeding the money pits
daveshan's Reviews
11-22-2008, 12:45 PM
Price: $380.00
Recommended? Yes
Comments: A good solid tummy tuck that has taken some good hits and done its job. It works well with the Skid Row short arm engine skid.
yrojnoid
yrojnoid's Reviews
06-20-2008, 02:00 AM
Price: $300.00
Recommended? Yes
Comments: Nice product, Rubicon tranny was a hair too big and was touching body an it gave a horrible cab noise. A single washer in between the cross member fixed it. Everything feels tighter then before.
XTC Jpr13
XTC Jpr13's Reviews
05-08-2008, 10:16 PM
Price: $380.00
Recommended? Yes
Comments: Does not bolt up to skid row engine skid, but with a little adaptation it makes a very nice way to raise up everything under the belly. Two piece design is great for working on your Jeep!
rescueTJ
rescueTJ's Reviews
04-28-2008, 06:04 PM
Price: $450.00
Recommended? Yes
Comments: Straightforward install, the only problem I had was b/c of my B&M short throw shifter contacting the tub. I do not think this would have been a problem with the stock shifter.
Islidur
Islidur's Reviews
04-07-2008, 01:41 AM
Price: $375.00
Recommended? Yes
Comments: Great build quality, great looks.
ozlowole
ozlowole's Reviews
01-02-2008, 03:59 PM
Price: $379.99
Pros: Two piece design allows for easy maintenance under the Jeep
Cons: None
Recommended? Yes
Comments: The installation was easy, its lighter and I got more clearance. I like it cause its not that hard to change oil or check everything out. The skid plate comes off with 6 bolts and the cross member still holds the transmission in place. It also moved my transmission closer to the body. I installed an inch body and motor mount lift and the transmission shifter was about an inch further away. When I installed the high clearance skid plate, it brought the transmission back to where it shoud have been, closer to my hand!
ThreadForumRepliesLast Post
Mopar WJ Transfer Case Skid Plate Skid Plates 24 04-24-2013 11:41 AM
UCF Transfer Case Skid Plate Skid Plates 34 04-15-2013 09:47 AM
warn Transfer Case Skid Plate for XJ Skid Plates 10 05-27-2012 03:36 PM
Skyjacker High Clearance Skid Plate model # SP28 Skid Plates 4 03-18-2012 08:11 PM
Rusty's Offroad XJ Transfer Case Skid Plate Skid Plates 5 06-02-2010 09:56 PM
Jeep Parts at Andy's
