Go Back JeepForum.com > Reviews > Engine > Motor Mounts > Rusty's TJ 1" MML
ORS4x4: New Product!Aluminum Quick Release Fire Extinguisher Mounts from ORS4xKinetic Recovery Rope from ORS4x4
Rusty's TJ 1" MML Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Motor Mounts Next Product
Rusty's TJ 1" MML
Rating:
Product Information
MSRP: $90.00
Average Price: $66.67
Manufacturer: Rusty's
Recommended?
Yes: 4 / No: 2
These motor mounts are built just as durable as our proven mounts but will raise the engine 1-inch. Used on the Wrangler vehicles, this will help with driveline angles when using a suspension lift.
(1) Slight modification to fan shroud may be necessary.
(2) Some vehicles require 1-inch body kit.
None
nottusyeroc
nottusyeroc's Reviews
09-12-2011, 06:52 PM
Price: $30.00
Pros: good
Cons: none
Recommended? Yes
Comments: good stuff
alex_c
alex_c's Reviews
09-13-2010, 07:50 PM
Price: $90.00
Pros: Beefy, good price
Cons: requires 9/16" x 5" bolt that is not supplied.
Recommended? No
Comments: They look beefy as hell, but they do not include any instructions (or any indication on their website) that they require the tabs on the engine block to be drilled out to accommodate a 9/16" x 5" bolt that is not included. With the factory motor mount bolt, the inner diameter of the metal sleeves in the motor mount is much bigger, causing a lot of slack. I don't need to explain how having excess play between two metal components in a motor mount is a bad thing.
Good luck finding a 9/16" x 5" bolt on short notice, too!
Mercman50
Mercman50's Reviews
06-30-2010, 05:47 PM
Price: $90.00
Pros: Not nearly as hard to install as everyone said... If you have half a brain and a floor jack, you can do it in 1 hour with a buddy.
Cons: None at all...
Recommended? Yes
Comments: Easy to install and completely took out all vibes on my tj (x) with a 3" teraflex suspension lift and rusty's 1" bl.... Did NOT have to run a t-case drop!!!!
Jebussaves0
Jebussaves0's Reviews
12-25-2008, 10:02 PM
Rusty's TJ 1" MML
Price: $50.00
Recommended? No
Comments: Seem fine after the installation but the spacers on the sides of the mount are seperate unlike the M.O.R.E design that integrates a single elongated tube. I would've bought M.O.R.E. if it hadn't been for the price.
C2U5H
C2U5H's Reviews
04-09-2008, 12:44 PM
Rusty's TJ 1" MML
Price: $90.00
Recommended? Yes
Comments: AWESOME product. Very stout, good welds, quality rubber used in bushings. Installs perfectly.
