M.O.R.E. JM600L "Bombproof" Motor Mount Lift Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Motor Mounts Next Product
Rating:
Product Information
MSRP: $230.00
Average Price: $120.40
Manufacturer: M.O.R.E.
Recommended?
Yes: 54 / No: 1
JM600L....1987-2005 Jeep® Wrangler YJ* & TJ Wrangler, 4.0L or 4.2L engines
With a One Inch Body Lift Kit installed. These mounts are the same as our new "Torsion" rubber BombProof"mounts, except that they are designed to "Lift" the engine one inch. These mounts work great for the TJ owner who wants to help correct the rear drive shaft angle, by leaving the stock crossmember in the stock location.
None
Page 3 of 3 1 2 3
ChicagoYJ
Yes, I Understand!
ChicagoYJ's Reviews
02-18-2008, 09:42 PM
Pros: Very well constructed.
Cons: Can't think of any.
Recommended? Yes
Comments: Worth every penny.
ozlowole
ozlowole's Reviews
01-17-2008, 01:48 AM
Pros: Holds the motor
Cons: none
Recommended? Yes
Comments: Good product, did it with a BL and high clearance skid plate so everything is still lined up correctly.
02tjsport
02tjsport's Reviews
10-21-2007, 09:16 PM
Pros: Easy to install
Cons: No hardware supplied.
Recommended? Yes
Comments: Extremely easy to install. Installed with my JKS BL. I ended up losing the one nut for the bottom of the mount and had to buy new from lowes. I wish it would have came with new nuts. But the new ones were only 2.10 for 4.
NOTE: If you install with a BL. You dont have to move the fan shroud down. I didnt think about the combo of hte two and unhooked the shroud, then ended up just installing back into the stock location again.
tdrouill
tdrouill's Reviews
04-19-2007, 03:00 PM
Pros: Excellent product quality
Cons: Slight vibes after install, Instructions are bad for 1st-time DIY'er
Recommended? Yes
Comments: Just to repeat what a lot have said already. These are a very well-built product. The welds are excellent, they chose heavy-gauge for the steel components, all metal is zinc-plated for corrosion resistance, and the rubber part minimized vibes compared to an equivalent poly design.
I thought the price was reasonable.
If this is your first MML install and you are going at it solo, do a web search for an installation procedure. The instructions from M.O.R.E. were pretty useless.
MachineMan
MachineMan's Reviews
02-10-2007, 10:25 AM
Pros: Very strong and uses rubber.
Cons: Cost is to high, $115 a pair.
Recommended? Yes
Comments: Great mount, easy to install. One of the few that come with rubber and not hard urathane. Vibes are low. I gave it a 9 instead of 10 becuase I think they should be cheaper for what they are...
cherokee5up
cherokee5up's Reviews
01-28-2007, 07:29 PM
Pros: Really is bombproof
Cons: NONE
Recommended? Yes
Comments: Best mounts I've had. I just put them in my 91 XJ. Minimal vibrations thanks to the rubber material. Wont crack off like OEM, but doesnt vibrate like polyurethane. Perfect.
2fastlx
2fastlx's Reviews
12-24-2006, 11:26 AM
Pros: very well built, possible cure for minor vibrations
Recommended? Yes
Comments: very well built and do what they're supposed to.
drottie
drottie's Reviews
09-18-2006, 06:45 AM
Pros: These live up to there name, easy install
Cons: none
Recommended? Yes
Comments: I put these on to get rid of a transmission skid spacer kit. They've held up great.
JeepRocks86
Some Call me RockDog
JeepRocks86's Reviews
08-30-2006, 12:10 PM
Pros: Great motor mounts
Cons: some notice more vibration, I did not.
Recommended? Yes
Comments: Great product. They have held up to a lot of abuse.
wahoojeep
wahoojeep's Reviews
08-05-2006, 08:07 PM
Pros: Moves oil pan higher for clearance
Cons: None
Recommended? Yes
Comments: I installed these to get my oil pan and oil pan skid a little higher. You do not have to install a body lift to install this. I just relocated my fan shroud and have had no problems. My Nth oil skid scrapes much less often with the mml.
MLJeeper
MLJeeper's Reviews
08-04-2006, 12:14 AM
Pros: helped reduce vibes while getting rid of the TC drop. Very strong.
Cons: Vibes with the 2.5L are bad at first but after break in for several months all is well.
Recommended? Yes
Comments: Great product. They warned me of the vibes before i bought so i was informed before the purchase. Vibes dissapated after driving for several months. Great fit and great product.
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Reviews
08-03-2006, 09:03 PM
Pros: Beef
Recommended? Yes
Comments: They do the job, and they sure are beefy compared to the stock mounts
BlueJ
BlueJ's Reviews
08-03-2006, 06:54 PM
Pros: Very very strong product. Zinc plated for corrosion, Look great.
Cons: A little more vibes from the engine but that is cool with me. More body roll when the engine is reved up. Again, cool with me.
Recommended? Yes
Comments: Great product when compared to BMML's and other MML's. Best on the market.
ChristopherJ
Resident Physician
ChristopherJ's Reviews
08-03-2006, 04:14 PM
Price: $119.95
Pros: It lifted the oil pan away from the ground and helped with some driveline vibrations.
Cons: I noticed a slight increase in engine vibrations felt in the cab. You must also have a body lift to accomodate the motor mount lift (unless you do some handy stuff with the fan shroud.
Recommended? Yes
Comments: I bought the one inch motor mount lifts from M.O.R.E. because I wanted to cure some driveline vibrations following a lift install. I settled on the "bombproof" mounts from M.O.R.E. after reading very positive things about the product. After seeing these mounts next to the OEM mounts, I can believe that they are in fact "bombproof".
Page 3 of 3 1 2 3
ThreadForumRepliesLast Post
BROWN DOG OFFROAD 1" TJ Motor Mount Lift - C2572-1 Motor Mounts 68 02-03-2017 09:05 AM
Daystar 1" Motor Mount Lift - KJ01005BK Motor Mounts 8 05-05-2015 07:53 PM
JKS Manufacturing JKS 1" Budget Motor Mount Lift - TJ/YJ (JKS8100) Motor Mounts 92 03-07-2014 09:39 PM
Daystar 1" riser motor mount Motor Mounts 6 11-03-2013 03:53 PM
Novak SBC Jeep Motor Mounts Motor Mounts 3 02-08-2009 09:07 PM
