Notices
M.O.R.E. JM600L "Bombproof" Motor Mount Lift Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Motor Mounts Next Product
Rating:
Product Information
MSRP: $230.00
Average Price: $120.40
Manufacturer: M.O.R.E.
Recommended?
Yes: 54 / No: 1
JM600L....1987-2005 Jeep® Wrangler YJ* & TJ Wrangler, 4.0L or 4.2L engines
With a One Inch Body Lift Kit installed. These mounts are the same as our new "Torsion" rubber BombProof"mounts, except that they are designed to "Lift" the engine one inch. These mounts work great for the TJ owner who wants to help correct the rear drive shaft angle, by leaving the stock crossmember in the stock location.
None
Page 2 of 3 1 2 3 > Last »
ScottHarr_TJ
ScottHarr_TJ's Reviews
01-07-2009, 04:33 PM
Price: $138.00
Recommended? Yes
Comments: Just placed my order the other day, i've heard great things about these motor mounts so i expect they will be pretty good.
mud-dog27
mud-dog27's Reviews
11-24-2008, 10:00 PM
Price: $200.00
Recommended? Yes
Comments: unreal...my engine rattled and creaked and just made stupid amounts of noise and vibration after installing these my jeep is about as quiet as a jeep can be,and the crisper more responsive throttle was a plus aswell
kman8
kman8's Reviews
11-08-2008, 06:37 PM
Price: $79.00
Recommended? Yes
Comments: When in easier than i had expected. Took less that a hour. Didn't stop all of my driveline vibes but did reduce them.
TJRubicon06
TJRubicon06's Reviews
10-17-2008, 08:08 PM
Price: $126.00
Recommended? Yes
Comments: Torsion Rubber Bombproof mounts. The mounts are stout, gold zinc plated for corrosion resistance and have no more vibes then the stock mounts on my rubi did. Im very happy with them.
Draper
Draper's Reviews
10-07-2008, 02:48 PM
Price: $130.00
Recommended? Yes
Comments: This motor mounts build quality is great! Easy too install...only took 1 hour. Only Con would be more vibration from the motor.
ballanjl
ballanjl's Reviews
09-02-2008, 11:09 PM
Price: $230.00
Recommended? Yes
Comments: They are the best mounts I have ever installed. They are trail tested. Destroyed the factory mounts in one trip to Moab.
tjtone
tjtone's Reviews
06-11-2008, 07:32 PM
Price: $1.00
Recommended? Yes
Comments: Also a very straight forward install excellent instructions.
Added about 2.5 hrs to the job.
I still have no right hand.
-sean-
-sean-'s Reviews
06-04-2008, 01:58 AM
Price: $50.00
Recommended? Yes
Comments: .................................................. .................................................. ................................................
VZEHLER
VZEHLER's Reviews
06-03-2008, 05:49 PM
Price: $125.00
Recommended? Yes
Comments: A little more expensive than the alternative options, but, they are VERY high quality and are not cause for engine vibes into the cabin. A common problem for other poly style lifts
SuperWade2
More Money than Brains
SuperWade2's Reviews
06-03-2008, 05:22 PM
Price: $125.00
Recommended? Yes
Comments:
Erik719
Erik719's Reviews
05-20-2008, 09:27 PM
Price: $1.00
Recommended? Yes
Comments: Great ---------------------------------------------------------------------------------------------------------------------------------
Panici
(O|||||||O)
Panici's Reviews
05-19-2008, 10:12 PM
Pros: Raises engine an inch higer from the rocks. Helps slightly with rear shaft angle. Solid, strong mounts.
Cons: Instructions need some work. I used tha guide at 4x4xplor.com in addition to the supplied instructions.
Recommended? Yes
Comments: -Beefy mounts, i'd say almost twice the weight of the OEM mounts.
-I noticed slightly more engine noise and more body roll when the engine is revved. Both are good things to me
-Install was a pain with A/C, but thats the case for any MML.
Cody
Junior Member
Cody's Reviews
05-19-2008, 11:42 AM
Price: $3.00
Recommended? Yes
Comments: test test test test test test
ekoms
ekoms's Reviews
05-02-2008, 10:00 PM
Price: $80.00
Recommended? Yes
Comments: Well I didn't really have vib problems before I installed this 1" MML & I haven't had any problem after installing it so. all is good & ya got to paint it yourself.
rescueTJ
rescueTJ's Reviews
04-28-2008, 06:25 PM
Price: $100.00
Recommended? Yes
Comments: I would highly recommend doing this with a Body Lift. Install is easy. Stay away from the poly mounts. They send lots of vibrations back into the truck. Use the torsion rubber type.
Booner_007
Booner_007's Reviews
04-09-2008, 03:45 PM
Price: $120.00
Recommended? Yes
Comments: Good Mounts
Islidur
Islidur's Reviews
04-07-2008, 01:50 AM
Price: $150.00
Recommended? Yes
Comments: A little more vibes, but ok
ThUmPeRcOn
ThUmPeRcOn's Reviews
03-17-2008, 10:26 PM
Pros: certainly Bomb proof like 3# per mount Beefy!
Cons: $$$
Recommended? Yes
Comments: Had daystar 1"mml for about a week then ordered these Like Night & Day. If installing and have AC drop the mm bracket on drivers side and it pops right in!
firecap4
firecap4's Reviews
03-17-2008, 01:36 AM
Recommended? Yes
Comments: great product holds up very well to everyday abuse
GringoLoco
GringoLoco's Reviews
03-16-2008, 11:40 AM
Price: $125.00
Recommended? Yes
Comments: Truly appear to be bombproof. When I first installed them I got more engine feel through the steering and chassis, and could hear the vibrations a bit more, but over time they either broke in and loosened up or I got used to it.
ThreadForumRepliesLast Post
BROWN DOG OFFROAD 1" TJ Motor Mount Lift - C2572-1 Motor Mounts 68 02-03-2017 09:05 AM
Daystar 1" Motor Mount Lift - KJ01005BK Motor Mounts 8 05-05-2015 07:53 PM
JKS Manufacturing JKS 1" Budget Motor Mount Lift - TJ/YJ (JKS8100) Motor Mounts 92 03-07-2014 09:39 PM
Daystar 1" riser motor mount Motor Mounts 6 11-03-2013 03:53 PM
Novak SBC Jeep Motor Mounts Motor Mounts 3 02-08-2009 09:07 PM
