JKS Manufacturing JKS 1" Budget Motor Mount Lift - TJ/YJ (JKS8100) Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Motor Mounts Next Product
Rating:
Product Information
MSRP: $100.00
Average Price: $60.09
Manufacturer: JKS Manufacturing
Recommended?
Yes: 91 / No: 2
JKS has been building this motor mount spacer lift since 1999 in small quantities. With the increasing demand for this simple design we have decided to go into production, mass-producing them to make it more affordable. The actual spacer is now made from 6061-T6-alloy aluminum. Simply slip this spacer below your OEM motor mount to achieve a full one-inch motor lift. This system allows you to retain the rubber isolated OEM motor mounts. This is a direct bolt-on item. Red anodizing and zinc-plated fasteners are standard. Great value at a budget price!
None
Page 5 of 5 1 2 3 4 5
RubiCrawler_LJ
RubiCrawler_LJ's Reviews
03-17-2008, 10:55 AM
Price: $59.95
Recommended? Yes
Comments: Well thought off product; clear instructions, no surprises!
PullMeSideways
PullMeSideways's Reviews
03-09-2008, 04:16 PM
Price: $55.00
Recommended? Yes
Comments: easy to install works great with a belly up
jboom
jboom's Reviews
03-04-2008, 09:07 PM
Price: $35.00
Recommended? Yes
Comments: No vibes now.
sasquachYJ
sasquachYJ's Reviews
02-20-2008, 10:04 PM
Pros: got rid of vibrations
Cons: could use better directions
Recommended? Yes
Comments: The mounts went on easy, recentering the motor with the mounts is the hardest part. Overall a great product!
Shag
Shag's Reviews
02-16-2008, 11:15 AM
Price: $54.40
Recommended? Yes
Comments: An inexpensive way to lift the motor. Fairly easy to install.
mike_dippert
mike_dippert's Reviews
02-13-2008, 10:15 PM
Price: $54.40
Recommended? Yes
Comments: .
Kulae
Kulae's Reviews
12-19-2007, 11:42 PM
Price: $50.00
Pros: Easy install
Cons: Need to do a little grinding and cutting
Recommended? Yes
Comments: Easy install. Little tougher if you have A/C. Had to grind down some OE studs to get the adapters to sit flush. Not that hard. No wobbles!
FarFire70
FarFire70's Reviews
09-24-2007, 09:05 PM
Pros: Straight forward install and lets you keep original motor mounts
Cons: None
Recommended? Yes
Comments: Did this with my JKS 1.25" BL. I was able to do this install by myself without any problems. I had no complaints with the instructions but there is always plenty of help on the forum with this mod.
mudmonkey2400
mudmonkey2400's Reviews
04-23-2007, 02:17 PM
Pros: Cheap. You keep OEM rubber bushings. Raises drive line by an inch.
Cons: Poor instructions.
Recommended? Yes
Comments: Didn't have to trim the stud on mine. If you've never done it before, find a good write-up and pretty much just go by it.
c_gilbert
c_gilbert's Reviews
08-22-2006, 04:56 PM
Pros: Fixed the drive line angle like its supposed to.
Cons: Directions lack some detail.
Recommended? Yes
Comments: This product did exactly what I wanted it to do. I didn't need to cut the stock mount bolts either. The new ones threaded all the way down. Give yourself some time for this project because lining everything back up isn't as simple as "just line everything back up."
Ichabod1960
Have Jeep, Will Travel
Ichabod1960's Reviews
08-09-2006, 11:24 PM
Pros: Easily installed.
Cons: Need better instructions.
Recommended? Yes
Comments: This was part of the DPG Off-Road Ultimate OME TJ/LJ Wrangler Kit. The installation went well with the following tips that should be included in the instructions.
Make sure you have a Factory Service manual available.
Support the engine with a floor jack using an old phone book to distribute the weight.
Loosen both mounts before installing the passenger side.
When cutting down the mount bolts thread the nut past the cut off point and use the nut to protect the threads while trimming down the bolt.
There is much less space on the drivers side and on my 05 LJ the Motor Mount Through Bolt could not be removed without loosening the engine mount bracket (the AC compressor interferes).
Trombino
Trombino's Reviews
08-05-2006, 08:49 PM
Price: $55.00
Pros: Easy Installation; No Additional Items Necessary
Cons: None Noted
Recommended? Yes
Comments: I installed the JKS BMML with my body lift and RE budget boost. Installation was straightforward and I didn't encounter any problems. Overall, I have been very pleased with this product.
ThreadForumRepliesLast Post
BROWN DOG OFFROAD 1" TJ Motor Mount Lift - C2572-1 Motor Mounts 68 02-03-2017 10:05 AM
Daystar 1" Motor Mount Lift - KJ01005BK Motor Mounts 8 05-05-2015 08:53 PM
Daystar 1" riser motor mount Motor Mounts 6 11-03-2013 04:53 PM
M.O.R.E. JM600L "Bombproof" Motor Mount Lift Motor Mounts 54 10-08-2013 06:26 AM
Novak SBC Jeep Motor Mounts Motor Mounts 3 02-08-2009 10:07 PM
