Notices
JKS Manufacturing JKS 1" Budget Motor Mount Lift - TJ/YJ (JKS8100) Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Motor Mounts Next Product
Rating:
Product Information
MSRP: $100.00
Average Price: $60.09
Manufacturer: JKS Manufacturing
Recommended?
Yes: 91 / No: 2
JKS has been building this motor mount spacer lift since 1999 in small quantities. With the increasing demand for this simple design we have decided to go into production, mass-producing them to make it more affordable. The actual spacer is now made from 6061-T6-alloy aluminum. Simply slip this spacer below your OEM motor mount to achieve a full one-inch motor lift. This system allows you to retain the rubber isolated OEM motor mounts. This is a direct bolt-on item. Red anodizing and zinc-plated fasteners are standard. Great value at a budget price!
None
Page 4 of 5 1 2 3 4 5 > Last »
JoeySnow70
JoeySnow70's Reviews
06-11-2008, 09:02 AM
Price: $70.00
Recommended? Yes
Comments: Exelent product if you need to raise the engine and dont want the vibrations related with the uretane bushings in the other type of motor lift.
TJ Flexer
TJ Flexer's Reviews
05-27-2008, 11:02 AM
Price: $85.00
Recommended? Yes
Comments: I did not get the budget lift that is comprised of just lifter block, I purchased the better lift with the new mounts that are just taller I feel they are better plus the old bushings are sloppy anyways
BM20
BM20's Reviews
05-18-2008, 08:17 PM
Price: $45.00
Recommended? Yes
Comments: Takes some creative manuvering to get it done but in the end, much better than lowering the T/C.
distortedtj
distortedtj's Reviews
05-17-2008, 10:15 AM
Price: $100.00
Recommended? Yes
Comments: great product easy to install took 20 minutes........................................... .................
XTC Jpr13
XTC Jpr13's Reviews
05-08-2008, 10:14 PM
Price: $50.00
Recommended? Yes
Comments: inexpensive way to raise the motor mounts if you need to do so. Very well built and straight forward install!
RCJEEP2002
RCJEEP2002's Reviews
05-05-2008, 09:22 PM
Price: $59.99
Recommended? Yes
Comments: Installed this lift with my body lift and works like a charm, install was alittle tricky though.
slate210
slate210's Reviews
05-05-2008, 03:01 PM
Price: $50.00
Recommended? Yes
Comments: Got them bundled with the 1.25" Body Lift 9904. They do what they're supposed to.
distantdog
distantdog's Reviews
05-01-2008, 01:55 PM
Price: $100.00
Recommended? Yes
Comments: came with my lift kit. Guess i give it a thumbs up since it probably keeps my drivetrain from vibrating.
98VTRam
98VTRam's Reviews
04-30-2008, 09:18 AM
Price: $100.00
Recommended? Yes
Comments: PITA to install but very well made and nice complement to BL. Suggest loosening motor mount from block when installed driverside
keithkeith
keithkeith's Reviews
04-29-2008, 06:10 PM
Price: $1.00
Recommended? Yes
Comments: no commentsno commentsno commentsno commentsno commentsno commentsno commentsno commentsno commentsno commentsno commentsno comments
bman9089
bman9089's Reviews
04-29-2008, 03:38 AM
Price: $60.00
Recommended? Yes
Comments: Can be a pain to install, but these are the best alternative to an SYE/CV setup. Afterall, anyone who plays in the rocks knows how bad a stock clearance xfercase can be, why make that worse by lowering it?
These are great quality and the bright red makes them easy to identify when looking around the suspension/engine area. You can't see them otherwise.
match this up with a JKS 1.25" BL and you won't have to worry about any other mods. Run one or the other, but not both together, and you will have to modify the engine fan/fan shroud to make sure they line up together.
if your motor mounts are shot now though, look elsewhere into complete MMLs and not just spacers.
ElConq
ElConq's Reviews
04-23-2008, 12:05 PM
Price: $50.00
Recommended? Yes
Comments: Easy Install w/ JKS 1.25 BL
Hrothgar
Hrothgar's Reviews
04-22-2008, 02:31 PM
Price: $60.00
Recommended? Yes
Comments: difficult to install, especailly if you have air conditioning.
jkcopey
jkcopey's Reviews
04-21-2008, 04:52 PM
Price: $100.00
Recommended? Yes
Comments: easy to install. no fan shroud mod required.
undercoverfab
Vendor
undercoverfab's Reviews
04-21-2008, 03:29 PM
Price: $56.00
Recommended? Yes
Comments: Great Product
BlackBellamy
BlackBellamy's Reviews
04-17-2008, 10:46 AM
Recommended? Yes
Comments: .
tractionhunter
tractionhunter's Reviews
04-15-2008, 10:09 PM
Price: $1.00
Recommended? Yes
Comments: 1
WKENDWARIOR69
WKENDWARIOR69's Reviews
04-13-2008, 01:03 AM
Recommended? Yes
Comments: This is hor the non-budget motor lift. If plan on doing thisyou must take the motor mounts off th jeep on the left side. I am talking about the 3 bolts holding the mount that got to the rubber grommet. Or else you can't get the long bolt out of the old motor mount. Outside of that a very clean install.
Mista Toad
Mista Toad's Reviews
04-12-2008, 03:38 PM
Price: $64.00
Recommended? Yes
Comments: Works great. No problems.
Hubi
Junior Member
Hubi's Reviews
03-25-2008, 06:23 PM
Price: $86.00
Recommended? Yes
Comments: just installed...
ThreadForumRepliesLast Post
BROWN DOG OFFROAD 1" TJ Motor Mount Lift - C2572-1 Motor Mounts 68 02-03-2017 09:05 AM
Daystar 1" Motor Mount Lift - KJ01005BK Motor Mounts 8 05-05-2015 07:53 PM
Daystar 1" riser motor mount Motor Mounts 6 11-03-2013 03:53 PM
M.O.R.E. JM600L "Bombproof" Motor Mount Lift Motor Mounts 54 10-08-2013 05:26 AM
Novak SBC Jeep Motor Mounts Motor Mounts 3 02-08-2009 09:07 PM
