JKS Manufacturing JKS 1" Budget Motor Mount Lift - TJ/YJ (JKS8100) Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Motor Mounts Next Product
Rating:
Product Information
MSRP: $100.00
Average Price: $60.09
Manufacturer: JKS Manufacturing
Recommended?
Yes: 91 / No: 2
JKS has been building this motor mount spacer lift since 1999 in small quantities. With the increasing demand for this simple design we have decided to go into production, mass-producing them to make it more affordable. The actual spacer is now made from 6061-T6-alloy aluminum. Simply slip this spacer below your OEM motor mount to achieve a full one-inch motor lift. This system allows you to retain the rubber isolated OEM motor mounts. This is a direct bolt-on item. Red anodizing and zinc-plated fasteners are standard. Great value at a budget price!
None
Page 3 of 5 1 2 3 4 5 > Last »
Donkeyboy28
Donkeyboy28's Reviews
08-13-2009, 12:04 PM
Price: $60.00
Pros: works really well
Cons: took a while to install
Recommended? Yes
Comments: I bought this in a kit with my body lift. I t took a while to put on. I recomend two people. There is a video on youtube that walks you through the entire process. the one thing they don't tell you is that u need to adjust the 4wd shift lever when your done. its as simple as loosening and tightening a 1/2" screw
Snowplow
Snowplow's Reviews
06-05-2009, 05:25 PM
Price: $50.00
Pros: none
Cons: none
Recommended? No
Comments: Simple install but over priced for a 1 inch block of metal.
mrosseker
mrosseker's Reviews
03-29-2009, 05:41 PM
Price: $60.00
Recommended? Yes
Comments: Install went very well, followed according to the instructions. Best to do this with a friend, as it makes for a lot of 'test and fit' if you go it alone. Great product.
Watch the "Rokmen" install video on YouTube for a great walkthrough.
JohnyPro
JohnyPro's Reviews
03-22-2009, 10:57 PM
Price: $58.00
Recommended? Yes
Comments: Quick install, make sure if lifting from transmission bell to tilt the wood towards the passenger side when lifting engine to reinstalled motor mounts.
Alexia
Alexia's Reviews
03-16-2009, 11:56 AM
Price: $60.00
Recommended? Yes
Comments: Easy to install, parts machined to precise dimensions. Directions were perfectly clear with plenty of helpful tips.
05moabTJ
05moabTJ's Reviews
03-07-2009, 04:02 PM
Price: $50.00
Recommended? Yes
Comments: Nice product. Highly recommend getting this MML. Now I can run 37's with no problems.
crawlr
crawlr's Reviews
03-04-2009, 06:28 PM
Price: $50.00
Recommended? Yes
Comments: easy to install. does what i bought it for. nice billet aluminium. its good to install this with a bl.
TJlady
TJlady's Reviews
02-20-2009, 01:46 PM
Price: $75.00
Recommended? Yes
Comments: We had this in our previous Jeep and we bought it again for this one.
Libtekguy
Libtekguy's Reviews
01-08-2009, 05:38 AM
Price: $54.99
Recommended? Yes
Comments: Easy install, an extra set of hands works too. Simple hand tools and a jack is all you need. I hack saw will work when you have to trim the stock motor mount bolts, but an angle grinder works best.
yellertj4rob
yellertj4rob's Reviews
01-04-2009, 08:55 AM
Price: $20.00
Recommended? Yes
Comments: Easy to install and gets the job done corretly. A little trimming or moving of the fan shroud is the only hard(ish) work.
alvinl
alvinl's Reviews
12-13-2008, 09:37 PM
Price: $30.00
Recommended? Yes
Comments: Great product. The install is a little involved, but very straight forward.
erickpl
erickpl's Reviews
11-24-2008, 12:25 PM
Price: $50.00
Recommended? Yes
Comments: Why do I need 75 characters to provide a review? I Just want to list em. Adding characters to shut this thing up.
Justin79
Justin79's Reviews
09-22-2008, 11:08 AM
Price: $60.00
Recommended? Yes
Comments: Installed in conjunction with JKS 1.25" BL. Cheap and easy, and as an added benefit, corrected driveline vibes from my 2" BB.
stu2003
stu2003's Reviews
09-19-2008, 01:27 PM
Price: $50.00
Recommended? Yes
Comments: Worked great with my JKS 1.25" body lift. Factory mounts were in great condition and there was no need to replace them. This spacer is a great budget option.
Guns
Guns's Reviews
09-17-2008, 01:33 PM
Price: $60.00
Recommended? Yes
Comments: Went in nice and easy and I haven't had any problems for the past 8 months. Good product and it was cheap.
shane_huskey
shane_huskey's Reviews
08-23-2008, 04:51 PM
Price: $56.04
Recommended? Yes
Comments: i bought this to keep from having to use the drop brackets for the t-case and cooling system. i guess it does it's job. the instructions say to cut off some of the factory stud, but i didn't bother and it works fine. i wish it was black...
0utback
0utback's Reviews
08-12-2008, 11:01 PM
Price: $58.00
Recommended? Yes
Comments: Simple effective kit, somewhat easy install. If you have air, you will have more work with the install. Easiest way is to detach the driver's side motor mount from the engine block when fitting this one. Passenger side is the easy side.
sherp89
sherp89's Reviews
06-29-2008, 09:42 AM
Recommended? Yes
Comments: Now that I know exactly what I am doing I could do another one in an hour, but figuring it out for the first time was the biggest challenge. Having AC makes removing the cross bolt a pain and when I put it back in we ran the bolt the other way to help us in the future. Helps to have a friend by myself it would have been a lot more work and four letter words
jdarg
jdarg's Reviews
06-27-2008, 05:28 PM
Price: $50.00
Recommended? Yes
Comments: Its a block of aluminum - it better work! The kludge-looking bolt extension actually seems to hold up well though...knock on wood. Always a pain to install but thats the price of being a cheapskate.
sebastian22
sebastian22's Reviews
06-19-2008, 04:35 PM
Price: $60.00
Recommended? Yes
Comments: This kit is great. Very affordable, not hard to install and helped me get rid of my T-case drop. I now run 4" suspension lift with no tcase drop and love it. no vibes or problems.
ThreadForumRepliesLast Post
BROWN DOG OFFROAD 1" TJ Motor Mount Lift - C2572-1 Motor Mounts 68 02-03-2017 09:05 AM
Daystar 1" Motor Mount Lift - KJ01005BK Motor Mounts 8 05-05-2015 07:53 PM
Daystar 1" riser motor mount Motor Mounts 6 11-03-2013 03:53 PM
M.O.R.E. JM600L "Bombproof" Motor Mount Lift Motor Mounts 54 10-08-2013 05:26 AM
Novak SBC Jeep Motor Mounts Motor Mounts 3 02-08-2009 09:07 PM
