Ironman Fabrication and 4x4 - Motor Mounts - 1" lift Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Motor Mounts Next Product
Rating:
Product Information
MSRP: $70.50
Average Price: $102.58
Manufacturer: Ironman Fabrication and 4x4
Recommended?
Yes: 6 / No: 0
Company Website: http://www.ironman4x4fab.com/
1" LIFT. Drop-in replacement, allows for radiator clearances with body lifts.
Bolt-in replacement motor mounts for Jeep 4.0L I-6 engines.
All solid 1/4" steel construction.
5/8 hole instead of slot to allow for easier installation.
Narrower bushing than competitors allows for better fit the first time!
Designed for high-torque and -horsepower applications.
Durable Powder-Coat finish.
85 Durometer Poly for firm hold without the harshness of other poly setups.
None
antcg
antcg's Reviews
04-21-2015, 10:48 AM
Price: $110.00
Pros: Solid, Well Built, Quality Product
Cons: None
Recommended? Yes
Comments: Bought these for my 98 XJ with the 4.0, and I'm never looking back. While the price may be up there, this is one of the BEST things I have done to my Jeep. My driver side OE mount was basically trashed, so i feel like this well worth the extra coin. Regardless of whether or not you need them, this is a great mod if you want to feel the vibes of your engine more and have the peace of mind that your stock mounts aren't going to give way and cause all kinds of carnage in your engine bay.
With that said, the only fitment issue I had was with the poly busing on the drivers side. That was remedied by just shaving less than a quarter of a millimeter of the busing off to make it flat on that end. Never had a problem since! Can't recommend this product enough, especially for anyone with an XJ/MJ.
BoostinChick
BoostinChick's Reviews
03-19-2014, 06:46 PM
Price: $142.50
Pros: Solid product
Cons: Not many.
Recommended? Yes
Comments: This only lifts the 4.0L motor 1/4". The fit wasn't perfect, had to shave the mount plate where it bolts to the frame. Other than that very solid product.
capcyclone
capcyclone's Reviews
08-10-2013, 01:34 AM
Price: $132.00
Pros: Absolutely solid, poly bushings - excellent build quality
Cons: Pricey, but they are built to last!
Recommended? Yes
Comments: These mounts, being poly, do transfer some vibes to the cabin, but it just helps you feel the power of the ZJ's motor. Awesome!
Meighty8
Meighty8's Reviews
07-24-2013, 02:16 PM
Price: $90.00
Pros: POLY BUSHINGS, AND DRIVETRAIN ANGLE.
Cons: ENGINE VIBES MORE NOTICABLE WITH POLY BUSHINGS.
Recommended? Yes
Comments: GREAT PRODUCT TO REPLACE YOUR FAILING OE MOUNTS WITH. THESE THINGS ARE HEAVY DUTY, EASY TO INSTALL AND SHINY!!!!! THEY ARE BLUE. IT ALSO LIFTS THE FRONT END OF YOUR ENGINE UP AN INCH WICH IS GOOD FOR DRIVELINE ANGLES. THE ONLY BAD THING WITCH ISNT EVEN BAD IS THE ENGINE VIBES ARE MORE NOTICABLE BUT THAT IS TO BE EXPECTED GOING FROM RUBBER TO POLY.
WillysEdition04
WillysEdition04's Reviews
07-13-2010, 07:23 AM
Price: $70.50
Pros: Lifetime Warranty. 85A Durometer poly, stiffer than rubber to help get torque to the ground, but softer than other poly compounds so no harsh ride qualities.
Cons: None.
Recommended? Yes
Comments: I asked Andy at Ironman Fab if he could fab up a 1" lift mount similar to the standard size heavy-duty mount they already produce. He was more than willing to do so and is now offering them on the company website. These mounts are pure beef and the 85 durometer poly is much more forgiving than the compounds used by other manufacturers.
I paired these mounts with a poly Transmission mount. There is noticable difference of firmer shifts and no vibrations at all.
ThreadForumRepliesLast Post
Brown Dog Offroad Standard Motor Mounts, not the 1 Motor Mounts 33 02-25-2017 10:07 PM
Currie Enterprises 1" raised heavy duty motor mounts Motor Mounts 6 12-26-2015 11:59 PM
M.O.R.E. JM600L "Bombproof" Motor Mount Lift Motor Mounts 54 10-08-2013 06:26 AM
Currie Enterprises heavy duty stock height motor mounts Motor Mounts 3 03-24-2010 12:51 PM
Novak SBC Jeep Motor Mounts Motor Mounts 3 02-08-2009 10:07 PM
