Go Back JeepForum.com > Reviews > Engine > Motor Mounts > Daystar 1" Motor Mount Lift - KJ01005BK
Truck-Lite's New LED Headlamp SeriesCURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee!Poison Spyder DeFenders™ - "Tubeless" Jeep Fende
Daystar 1" Motor Mount Lift - KJ01005BK Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Motor Mounts Next Product
Rating:
Product Information
MSRP: $100.00
Average Price: $84.00
Manufacturer: Daystar
Recommended?
Yes: 5 / No: 1
Motor Mount - 4 Liter Engine - 1" Taller for Body Lift Applications
Item Number: KJ01005BK
All of Daystar's™ mounts are constructed of heavy duty steel that is fully welded and interlocked for Extreme Duty strength. Daystar™ uses its special blend of polyurethane to isolate the mount from the engine and reduce the amount of power loss a traditional mount allows. An additional feature of the Daystar mount is that it resists oil and grease much better than stock rubber, thereby increasing the longevity of the mount.
Fits:
1997-2006 TJ Wrangler with 4.0 Liter Engine
1987-1996 YJ Wrangler with 4.0 Liter Engine
Your Price: $84.16 EA
Gobbles347
Gobbles347's Reviews
07-20-2011, 10:56 PM
Price: $85.00
Pros: Nice to have whole new mounts instead of block spacers
Cons: none so far
Recommended? Yes
Comments: a little hard to install but nothing that you cant get done in an afternoon, overall very happy with them
05jeeper
Jeep Enthusiast
05jeeper's Reviews
12-18-2008, 10:46 PM
Price: $75.00
Recommended? Yes
Comments: Correct misalignment from body lift. Easy to install. Increases motor vibration but not bad.
jeepxguy_02
jeepxguy_02's Reviews
11-27-2008, 11:17 PM
Recommended? Yes
Comments: THEY WORK. PUT THESE ON WITH 1" BODY LIFT DUE TO CLEAREANCE ISSUES WITH SOME STUFF AND IT HELPS REDUCE SOME FRONT DRIVELINE VIBES.
RVA_TJ06
RVA_TJ06's Reviews
04-02-2008, 06:31 PM
Price: $100.00
Recommended? Yes
Comments: Complimented BL
Benderff
intentionally left blank
Benderff's Reviews
05-15-2007, 04:03 PM
Pros: ummmm
Cons: Bad Vibrations!!
Recommended? No
Comments: I installed this with my body lift. I had to grind one of the through the center bolt holders because it was way to long. The engine vibs are worse then I thought they ould be. I plan on going to MORE bombproof mounts soon.
LoneJeeper
i wear foil underwear too
LoneJeeper's Reviews
08-06-2006, 07:36 PM
Price: $76.00
Pros: a MML helps with driveline vibes, and pairs nicely with the BL,
Cons: um, didn't come with a sticker? price, i guess.
Recommended? Yes
Comments: When paired with the BL, this is a nice mod, there's no trimming of the fan shroud, transfer case linkage is ok, and it helps with driveline vibes after a lift.
it's a pretty straightforward install, a hydraulic lift makes it super easy.
lj
ThreadForumRepliesLast Post
JKS Manufacturing JKS 1" Budget Motor Mount Lift - TJ/YJ (JKS8100) Motor Mounts 80 12-29-2011 05:27 PM
BROWN DOG OFFROAD 1" TJ Motor Mount Lift - C2572-1 Motor Mounts 36 02-20-2011 05:08 AM
Daystar 1" riser motor mount Motor Mounts 4 07-30-2010 01:51 PM
M.O.R.E. JM600L "Bombproof" Motor Mount Lift Motor Mounts 43 01-06-2010 10:16 PM
Novak SBC Jeep Motor Mounts Motor Mounts 3 02-08-2009 10:07 PM
Glock Forum
