BROWN DOG OFFROAD 1" TJ Motor Mount Lift - C2572-1 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Motor Mounts Next Product
Rating:
Product Information
MSRP: $100.00
Average Price: $121.06
Manufacturer: BROWN DOG OFFROAD
Recommended?
Yes: 64 / No: 5
1" Motor Mount Lifts
Want motor mount lifts (MML) to help compensate for your body lift (BL)? Brown Dog designed these motor mount lifts to reposition your engine one inch higher than stock (at the cooling fan) while providing a serious upgrade from most aftermarket mounts. This pair of motor mount lifts were engineered for extreme strength. And, just to make sure, why we periodically pull one off the shelf and put it through our 20-Ton Press Test. These will be the last set of mounts you'll need. The Brown Dog gives you his promise. Replaceable bushings provide some high-frequency vibration dampening. If the bushings wear out, just replace them. Lift not available individually. Installation Notes: Lifts bolt directly to the pylon or cradle in the identical position of the stock mounts. Engine will be raised 1" at the stock cooling fan.
The Brown Dog Promise.
Brown Dog products are designed for high performance applications and off highway use. No one can predict the forces a vehicle will encounter in extreme conditions that are beyond the vehicle's original design parameters. We feel that our products will continue to perform as designed when other products would break. We will replace any product that fails due to a defect in assembly (broken weld). We cannot be responsible for forces so extreme that the integrity of plate or tubular steel becomes compromised. But if you manage to do that, we certainly want to see a picture of it.
Hey, we go out and do the same stuff you do, and we try to break it, but we don't hold others responsible for the results of our strange behavior. Have fun, be safe.
None
Page 3 of 4 1 2 3 4 > Last »
SoonerE39
SoonerE39's Reviews
03-20-2010, 06:28 PM
Price: $100.00
Pros: Can't remember specific price now - but like the appearance and they unbreakable.
Cons: I have the urethane mounts which are cheaper but transmit just a little more engine vibes. The rubber ones are more expensive but isolate more vibration
Recommended? Yes
Comments: Purchased directly from Brown Dog. At time of install I realized a problem with the motor mount brackets so I replaced the brackets with the MORE Bombproof Brackets
MaulCrawler
MaulCrawler's Reviews
03-10-2010, 10:18 PM
Price: $80.00
Pros: very heavy duty
Cons: none
Recommended? Yes
Comments: Lifted the one inch it said it would resulting in a better driveline angle
NOBLACKTOP
NOBLACKTOP's Reviews
01-21-2010, 11:11 PM
Price: $97.00
Pros: Customer service
Cons: None
Recommended? Yes
Comments: Installing the driver side was challenging. If you do not have AC it will be much easier.
zanash2
zanash2's Reviews
12-19-2009, 09:10 AM
Price: $109.00
Pros: strong product
Cons: none
Recommended? Yes
Comments: This is a sturdy mount.
1RuffRider
1RuffRider's Reviews
11-04-2009, 07:49 PM
Price: $75.00
Pros: Great lift, no flex at the mounts, poly bushings don't radiate vibrations. Nice tight feel!
Cons: None!
Recommended? Yes
Comments: Only $75 shipped for 1" MML's with poly bushings. Great feel not too much vibration and no motor flex... Great product and very well made!
Kiwi Jeeper
Kiwi Jeeper's Reviews
08-11-2009, 03:33 AM
Price: $100.00
Pros: Solid.
Cons: None noted.
Recommended? Yes
Comments: I had poly bushings from a competitor, it drove me nuts because of the vibrations. I finally gave in and changed over to these. What a difference. No more annoying vibrations. I did end up painting them black though (I like everything painted black).
99TJSahara
99TJSahara's Reviews
07-23-2009, 01:55 PM
Price: $71.96
Pros: Easy to install, I was able to take off my T-case drop
Cons: Can't think of any
Recommended? Yes
Comments: Excellent product, I installed these so I could remove the T-case drop and I'm loving the extra clearance, I don't turtle it as much, but the best part about putting these mounts on is that if you do a body lift at the same time you don't have to mess with fan shroud or T-case linkage.
attackcammel
attackcammel's Reviews
03-11-2009, 09:34 PM
Price: $100.00
Recommended? Yes
Comments: works great!!!! way more beefier then the stock ones. holding up great and went in easy supper product wod buy again if needed for another build
mtr5360
mtr5360's Reviews
01-18-2009, 02:10 AM
Price: $74.95
Recommended? Yes
Comments: Awesome product, Outstanding customer service. Ordered the mounts on the internet at 1:30 PST and recieved e-mail saying that they were shipped at 2:45 PST same day!!! But.....they are yellow.
easytim
easytim's Reviews
11-09-2008, 11:28 PM
Price: $79.00
Recommended? Yes
Comments: These are the poly type, very tuff,much tuffer than the rubber type. VERY well built made to last for years
Takota
Takota's Reviews
10-13-2008, 12:57 AM
Recommended? Yes
Comments: These are great! I recommend these to those who lift their rigs! These are a must have!
TJ-xtreme
TJ-xtreme's Reviews
08-25-2008, 05:51 PM
Price: $74.00
Recommended? Yes
Comments: Great Product, Very strong and a straight forward install. no more drivetrain vibes at take-off or highway speeds.
rnemovr
Have Cummins, Will tow.
rnemovr's Reviews
07-30-2008, 06:11 PM
Recommended? Yes
Comments: great products and great guy to deal with, i talked to him when doing my motor swap and he mixed a engine mount and MML kit for me and threw in extra bolts, even stickers, great customer service
thedirt
thedirt's Reviews
06-09-2008, 09:02 PM
Price: $80.00
Recommended? Yes
Comments: Awesome motor mounts. Well built, quality product, and Brown Dog is an awesome company to deal with.
stangman68inftc
stangman68inftc's Reviews
04-19-2008, 10:04 PM
Price: $65.00
Recommended? Yes
Comments: Got it to match my body lift. Good construction.
stoverdr
stoverdr's Reviews
03-31-2008, 01:28 PM
Price: $75.00
Recommended? Yes
Comments: AWESOME product, excellent alternative to a SYE for the light offroad user.
Wshift
Wshift's Reviews
03-07-2008, 02:00 PM
Pros: Unbreakable, Great customer service
Cons: None
Recommended? Yes
Comments: All i have to say is if you need to replace those old motor mounts don't bother with anything other than Brown Dog's mounts. Awesome product and great people to deal with
GLANGA88
GLANGA88's Reviews
02-27-2008, 10:55 PM
Price: $70.00
Recommended? Yes
Comments: Solid product.
bdf1783
bdf1783's Reviews
02-27-2008, 10:02 PM
Price: $79.00
Recommended? Yes
Comments: awsome product easy to install great tech help
FireMedicZ
FireMedicZ's Reviews
12-10-2007, 09:17 PM
Pros: Good design, Great welds, Easy install, perfect color
Cons: none
Recommended? Yes
Comments: I went searching for MML and settled on Brown Dog because I couldn't find anyone that had problems with theirs. I put mine in along with a BL after the Nth TT. Install was a snap, just don't forget to undo the fan shroud. Also, loosen the drivers side block bracket so you won't have issues getting the MM bolt out due to the AC compressor. You'll see what I mean.
ThreadForumRepliesLast Post
Brown Dog Offroad Standard Motor Mounts, not the 1 Motor Mounts 33 02-25-2017 09:07 PM
Daystar 1" Motor Mount Lift - KJ01005BK Motor Mounts 8 05-05-2015 07:53 PM
JKS Manufacturing JKS 1" Budget Motor Mount Lift - TJ/YJ (JKS8100) Motor Mounts 92 03-07-2014 09:39 PM
Daystar 1" riser motor mount Motor Mounts 6 11-03-2013 03:53 PM
M.O.R.E. JM600L "Bombproof" Motor Mount Lift Motor Mounts 54 10-08-2013 05:26 AM
