Weber 32/36 DGAV
Rating: |
Product Information
| MSRP: |
$400.00 |
| Average Price: |
$291.04 |
| Manufacturer: |
Weber |
| Recommended? |
Double barrel carb by Weber.
maxedout757's Reviews
Price: $350.00 Pros: stats up and idles better,right... it is better than stock. Cons: its always thirsty for gas Recommended? Yes
Comments: i have one , its awlways thirsty!! i agree it is better than stock, ive heard holly is better.i was just handed down a ford 2 bbl carb that have have not yet put on...... i got a long list of things to do and no cash to do it
RangerBystander's Reviews
Price: $285.00 Pros: Runs like a scalded ape Cons: Had to tweak to meet emissions Recommended? Yes
Comments: This is a great carb for the jeep. I am self taught and follow the manual and found it to be easy when I read the instructions and took my time to dial it in. I did have to have a pro re-jet it to get it within the tolerance for emissions, but otherwise it was a breeze
shotgun23's Reviews
Price: $300.00 Pros: Eliminates emissions Cons: Hard to tune Recommended? Yes
Comments: Great replacement for the Carter. Hard to tune and the Weber company is hard to reach for support.
Mp5ben's Reviews
Price: $300.00 Pros: Not familiar enough with it Cons: Not familiar enough with it Recommended? Yes
Comments: Not familiar enough with it
patde's Reviews
Price: $250.00 Pros: it's not the stock pos. hahaha. much smother more power easy install Cons: none really Recommended? Yes
Comments: if you have been thinking about one just get it.
BENLT78's Reviews
Price: $349.99 Pros: Easy install for a novice as myself. Cons: Directions lacked clarity. Recommended? Yes
Comments: It was a real easy install considering It was the first time i've ever done anything with a carb. My jeep started up right after install and already runs better than the original Carter, and this is without any tuning yet.
gnarboots's Reviews
Price: $250.00 Pros: better performance Cons: won't pass smog now Recommended? Yes
Comments: Before I had the stock carter 2bbl, after installing and using a few posts on here along the way, my YJ will fire up instantly every time and runs much smoother. Before, my jeep would sometimes die at a stop sign from the idle jet tubes being packed full of crud, and hasn't happened since. Would recommend this product to anyone fed up with the jank carter or looking for more performance out of their jeep.
Fernando's Reviews
Price: $300.00 Pros: Reliable, good fuel economy Cons: not very tuneable Recommended? Yes
Comments: Good replacement carb, reliable and good fuel economy
scott5star's Reviews
Price: $300.00 Pros: Everything Cons: None, should have done it sooner Recommended? Yes
Comments: Great upgrade. I would stall at every stop and it would not idle without the 2 foot 3 pedal shuffle. Wish I had more info on what to do with all of the extra vacuum line that are no longer needed.
mosshopper's Reviews
Price: $1.00 Pros: Nothing I can think of Cons: Cant ever get the thing to run right Recommended? No
Comments: I have tried everything I could think of and everything the forum has thought of and it still wont run right
skip-yj's Reviews
Price: $245.00 Pros: motor runs and puurreesssss Cons: can never really find a filter Recommended? Yes
Comments: iv had this carb before but just wanted to put a new one in and its even better then the last one
mcmud's Reviews
06-04-2009, 08:15 AM |
Price: $340.00 Pros: Refined, responsive and respected, Easy to tune and should satisfy the user on any four or six cylinder Jeep application. Cons: None that I have expeienced in over twelve years of using this Series of Weber. Recommended? Yes
Comments: I had the pleasure of installing this carb in '96. Since then have had several and currently have two installed on AMC 258's. Extremely pleased and would recommend it to anyone shopping for a genuine up grade to their Jeep. If you are looking for a manual choke set rather than the Elect. (signified by the 'E' in the Series DGEV) then a manual cup could easily be adapted in place of the Bi metal spring cup or you would save bucks by shopping for the DGV 32/36 instead by saving you the cost of the Choke Assembly entirely. Either of these carbs, DGEV 32/36 or the DGV 32/36 would be a wise choice to make.
If your Jeep has the water heated intake manifold then you may want to check out this DGAV 32/36 same distinct quality as the DGEV, DGV 32/36 but with the Aqua Choke. Select one of these and I assure you it would be your pleasure to spread the good news as these other users have.
donm66's Reviews
03-23-2009, 11:02 PM |
Weber 32/36 DGAV
Price: $400.00 Recommended? Yes
Comments: Had it installed by a pro. I love that I was able to clean up a lot of the old wiring and vacuum. Better mileage and improved HP. Seems to work well in off-angle dispite what I have heard.
90JWYJ's Reviews
02-02-2009, 05:20 AM |
Weber 32/36 DGAV
Price: $300.00 Recommended? Yes
Comments: Improved Power/Fuel Economy 10 fold, and got rid of 80% of the vacumn lines!
Jumphog's Reviews
01-01-2009, 09:59 AM |
Weber 32/36 DGAV
Recommended? Yes
Comments: Performed well to date. Keep it cleaned, and it works! Easy to maintain and set. I have had no problems with it to date.
Neighborbill's Reviews
12-06-2008, 11:26 PM |
Weber 32/36 DGAV
Price: $289.00 Recommended? Yes
Comments: I LIKE IT GREAT CARB EASY INSTALL.i like it ALOTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT TTTTTTTTTTTTTTTT!
cpundsack's Reviews
11-10-2008, 01:40 PM |
Weber 32/36 DGAV
Comments: I love this Carburetor, have not experienced any problems . . . only 4 months old though. Seems like a great improved over the stock carb
jeepnfun's Reviews
10-19-2008, 09:03 PM |
Weber 32/36 DGAV
Price: $378.64 Recommended? Yes
Comments: This is one of the best upgrade i have made so far. i would recommend this to any YJ owner.
finfan297's Reviews
06-21-2008, 09:13 PM |
Weber 32/36 DGAV
Comments: The difference over the carter is day and night, there's literally no comparison, no more stalling, more power, and about the same gas mileage.
