Go Back JeepForum.com > Reviews > Engine > Carburetors > Redline Weber 38/38 Outlaw K-551-38
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Redline Weber 38/38 Outlaw K-551-38 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Carburetors Next Product
Rating:
Product Information
Average Price: $348.11
Manufacturer: Redline Weber
Recommended?
Yes: 9 / No: 0
2 barrel carburetor
grocerw
grocerw's Reviews
01-12-2012, 10:18 AM
Price: $329.99
Pros: good, easy installation and tune
Cons: no product information on available jets
Recommended? Yes
Comments: product is a direct bolt after market carb, instruction and fit are very straight forward. carb is very easy to adjust, and adds a noticable boost to any stock motor and can be upgraded to get the most out of anymotor improvements
spottedfrog
spottedfrog's Reviews
12-24-2011, 09:55 PM
Price: $400.00
Pros: easy to work on, parts readily available. It was new. I like the electric choke.
Cons: Poor throttle spring linkage design. Encourages binding in both of 2 optional configurations.
Recommended? Yes
Comments: I would recommend this because new parts for new parts the cost is comparable to the Carter BBD. The weber seems to have the edge in tunability. I like the electric choke. It was relatively easy to set up. I did have to adjust the spacers because they were not smooth on the mating surfaces. also the bores could use some modification as they are not a smooth transition either between them selves or the manifold. Easy fix with sand paper, emery cloth, and a dremal.
The throttle linkage wanted to bind in both of the 2 optional configurations. Also in the standard (use on the Jeep linkage) version the spring would not close the throttle fully.
I fixed the linkage problems by making my own adapter, works awesome now.
CALOcruiser
CALOcruiser's Reviews
08-12-2011, 05:53 AM
Price: $389.00
Pros: Easy installation, easy to find parts.
Cons: Not all parts are machined and adjusted to the tolerance I would expect. Takes some tweaking.
Recommended? Yes
Comments: Great carb so far. I'm still trying to get it tuned correctly for my application, but that's part of it.
MosesYJ
MosesYJ's Reviews
07-05-2011, 11:23 PM
Price: $330.00
Pros: dosent stall, runs like a raped ape
Cons: pedal is quite stiff but its prolly something i did
Recommended? Yes
Comments: ordered from weber carbs direct, got here in 2 DAYS, well packed i also ordered the holley cfm, easy install with detailed instructions and legible English , runs great now that installed and definetly gave me more power/ torque
fran87yj
fran87yj's Reviews
03-06-2011, 09:07 AM
Price: $336.00
Pros: Hp is great along with throttle response
Cons: Fuel effIence in not so great with 35s and my driving style
Recommended? Yes
Comments: This is a great product. Easy install with great outcomes. Better HP, great acceleration, no flat spots. Slight decrease in fuel eff. Some to do with my driving style thus far. I am happy to have some power for the first time since starting my rebuild.
vicker
vicker's Reviews
08-21-2010, 09:54 PM
Price: $369.00
Pros: more power/better fuel economy
Cons: none
Recommended? Yes
Comments: love this carb!! big improvements in power and some improvements in fuel economy over the stock carb. highly recommended. installation instructions were good but be sure to label every hose as it comes off. you dont need a fuel regulator. just order a viton need and seat and change out the original before you install it. the viton needle and seat allows the weber carb to easily handle the slightly higher fuel pressure the stock pump puts out. if you get this carb you will not be dissapointed.
dtn8tr
dtn8tr's Reviews
05-21-2010, 07:39 PM
Price: $125.00
Pros: Easy to install and setup, got my idle back.
Cons: none
Recommended? Yes
Comments: I picked my kit up used off craigslist and was able to install it along with a Holley pressure regulator in an evening. The installation and setup instructions that I downloaded from the website were clear and concise and there was a noticeable improvement in throttle response. I coupled this with the Nutter bypass and my YJ runs great. I'm getting 17-18 mpg and I'm content with that. I would highly recommend this even at full price for anybody looking to replace there stock carb.
Tephladon
Tephladon's Reviews
10-14-2009, 04:08 PM
Price: $479.00
Pros: Noticeable HP gains. Design cleans up engine space. Reduces amount of vacuum lines. Better fuel mileage. Very easy to setup. Good instructions
Cons: It's still a carburetor
Recommended? Yes
Comments: With my old carter I could barely maintain 70 mph in 5th gear on the highway. With this carburetor upgrade alone I maintain 70 mph and then some. Even climbs light grades at speed without so much as a hiccup.
gallagher11590
gallagher11590's Reviews
09-06-2009, 10:52 PM
Price: $375.00
Pros: can really feel how mcuh more power you have a lower speeds.Was worth every penny
Cons: even worst gas milage
Recommended? Yes
Comments: greattt
ThreadForumRepliesLast Post
Redline Weber Carburetors Weber 32/36 DGEV - K551 Carburetors 19 05-26-2010 10:37 AM
Weber 34/34 Carburetors 15 02-07-2010 12:08 AM
Weber 36/36 Carburetors 1 12-02-2009 07:02 PM
Weber 34/34 DGEV Carburetors 6 09-11-2009 02:53 PM
Redline Weber Carburator 34/34DEG Carburetors 6 06-04-2009 05:22 PM
Glock Forum
